Author Topic: Excel library subs  (Read 5257 times)
adalea03
  • Wow
Re: Excel library subs
« Reply #60 on: March 30, 2012, 03:42:41 pm »
Thanks Gile,
Not as hard as I thought.
I cant test it until Monday, though.
No Cad or Excel here.
Have a great weekend.
Tony
"Prescriptive Planning - Precision Performance - Providential Product."
Windows 7  64 bit
AutoCad 2012 64 bit
MS Office 2010  64 bit
codered8x
  • Mosquito
« Reply #61 on: April 27, 2012, 03:35:44 am »
Hi all ! is there function to open any excel file if it exist, otherwise create it with path and name are specified in function.
fixo
  • Pietari, Venäjä
« Reply #62 on: April 27, 2012, 02:30:38 pm »
You can try this code, just change your logic to suit:
(defun C:XLO(/ as gkw newpath path xlapp xlbook xlbooks xlcell xlrange xlsheet xlsheets)
    (alert "I recommend to choose \"Add\" first")
     (setq xlapp (xlgetapp))
  (_set xlapp 'visible :vlax-false)
   ;;(xlbooksaveas xlbook path)
  (if (xlhasbooks xlapp)
     (setq xlbook (xlgetactivebook xlapp))
      (initget 1 "Add Open")
      (setq gkw (getkword "\nAdd new Excel document or Open existing file? [Add/Open] <Add> : "))
      (if (eq "Open" gkw)
     (setq path (getfiled "Select Excel file :"   (getvar "dwgprefix")   "xls;xlsx"  16))
     (setq xlbooks (xlgetbooks xlapp))
     (setq xlbook (xlopenbook xlbooks path))
     (setq as T)
     (setq xlbook (xladdbook xlapp))
     (xlshout xlapp :vlax-true)
;| do your work here |;
;;;     (setq xlsheets (xlgetsheets xlbook))
;;;     (setq xlsheet (xlgetsheet xlsheets 1)) ;or any sheet name
;;;     (setq xlsheet  (xlactivate xlsheet))
;;;     (_set xlapp 'visible :vlax-true)
  (if (not as)
(xlbooksave xlbook)
(xlbookclose xlbook nil))
(setq newpath (getfiled "To save Enter file name w/o extension:"
"xls;xlsx"
1))
(if newpath
  (xlbooksaveas xlbook newpath)
    (xlshout xlapp :vlax-false)
     ;|next three lines of code are constant for all programs which will be use 'XLFIXOLIB' library |;
     (xlshout xlapp :vlax-true); - 1
     (xlquit xlapp); - 2
     (xlcleanup  (list xlcell xlrange xlsheet xlsheets xlbook xlapp)); - 3
     (setq xlapp nil)
~'J'~
\\\"Always drink upstream from the herd."\\\ - Will Rogers, was died in 1935 plane crash
--> Donate to TheSwamp <--
codered8x
  • Mosquito
« Reply #63 on: April 28, 2012, 01:24:21 pm »
Thank Fixo, special for your library file, it help me so much  :laugh:
fixo
  • Pietari, Venäjä
« Reply #64 on: April 28, 2012, 01:39:38 pm »
I'm glad if this helps to somebody
Happy computing :)
~'J'~
