Author Topic: DWG size being compressed  (Read 2126 times)
MSTG007
« on: January 31, 2005, 09:20:21 AM »
Whats the best way to have a drawing with lots of info and lines to be compressed?
Civil3D 2020
pmvliet
« Reply #1 on: January 31, 2005, 09:40:27 AM »
As in file size compression?
Or are you talking purging of unwanted items?
Pieter
« Reply #2 on: January 31, 2005, 09:40:37 AM »
If the dwg is in the 2004 format it's already compressed. If you are compressing them for your own use them try bzip2 or rar.
jwisherd
« Reply #3 on: January 31, 2005, 11:34:15 AM »
I turn all layers on and thawed, zoom to extents, erase all (then remove all the objects with a crossing window), delete duplicate objects, cdgpurge, purge, audit, and save. I have been able to clean drawings up from 10 megs to 2 or 3. If sending it out to someone, I'll use winzip or rar, to compress it even more for sending.
acad 2002
« Reply #4 on: January 31, 2005, 12:04:52 PM »
Here are some stats for ya.
01/31/2005  11:55 AM  (orginal)  231696 compress_test.dwg
01/31/2005  11:55 AM  (bzip2)    99978 compress_test.dwg.bz2
01/31/2005  11:59 AM  (rar)      79275 compress_test.rar
pmvliet
« Reply #5 on: January 31, 2005, 12:57:41 PM »
Mark,
is that a raw 2004/2005 file type?
« Reply #6 on: January 31, 2005, 01:14:53 PM »
Quote from: pmvliet
Mark,
Yes.
Forgot to add .zip to the list.
01/31/2005  01:13 PM            111048 compress_test.zip
MSTG007
« Reply #7 on: January 31, 2005, 03:04:55 PM »
nice.....  thxs guys. you are all smart
Civil3D 2020
t-bear
« Reply #8 on: January 31, 2005, 03:30:06 PM »
So are you....you came here for help, right?
