don't use bitmaps, instead, use jpegs and/or png files
Of course, it all depends on what you are trying to do. Is the Slide.ocx source available? Perhaps it might need to be revised to correct the issue you are having or maybe look at building your own slide reader. The format is straightforward and shouldn't be too difficult to manage.
