Author Topic: Who is good in math...  (Read 4240 times)
huiz
  • Certified Prof C3D
« on: May 26, 2011, 03:19:19 PM »
I've not seen a school from inside the last 20 years (besides kindergarten where my kids are playing around) and I did not pay much attention when I had math lessons... So who can help me with a formula?
I have 3 points (Point2D objects), let's say A, B and C. I have an imaginary line between A and B. I want to project C on the line A-B (C can be before A or after B on that line) and I would like to know the coordinates of the projected point C. And all that in plain VB or C#.
I know I could draw two rays, get the intersection and remove the rays but there is some formula for. Anyone with a quick help?  :-)
Re: Who is good in math...
« Reply #1 on: May 26, 2011, 03:30:44 PM »
I would use the vector dot product of the vector AC and the unit vector AB, this will give you the distance of the projection of C along AB as measured from A
« Reply #2 on: May 26, 2011, 03:38:08 PM »
Here is a great resources for catching back up on math http://www.theswamp.org/index.php?topic=37552.0
*********Edit*******
Link to the videos http://www.khanacademy.org/#browse
sinc
« Reply #3 on: May 26, 2011, 06:22:52 PM »
Have you looked at Curve.GetClosestPointTo()...?
« Reply #4 on: May 26, 2011, 07:10:53 PM »
Another, using a crafty coordinate transformation:
(defun LM:ClosestPointToLine ( pt p1 p2 / n )
  (setq n  (mapcar '- p2 p1)
        p1 (trans p1 0 n) pt (trans pt 0 n)
  (trans (list (car p1) (cadr p1) (caddr pt)) n 0)
pt  -  given point
p1  -  first point of line
p2  -  second point of line
 :wink:
jgr
« Reply #5 on: May 26, 2011, 08:01:01 PM »
Public Shared Sub ClosestPointOnSegmentFromPoint(ByVal x1 As Double, _
                                                  ByVal y1 As Double, _
                                                  ByVal x2 As Double, _
                                                  ByVal y2 As Double, _
                                                  ByVal px As Double, _
                                                  ByVal py As Double, _
                                                  ByRef nx As Double, _
                                                  ByRef ny As Double)
     Dim vx As Double = x2 - x1
     Dim vy As Double = y2 - y1
     Dim wx As Double = px - x1
     Dim wy As Double = py - y1
     Dim c1 As Double = vx * wx + vy * wy
     If c1 <= 0# Then
         nx = x1
         ny = y1
         Return
     End If
     Dim c2 As Double = vx * vx + vy * vy
     If c2 <= c1 Then
         nx = x2
         ny = y2
         Return
     End If
     Dim Ratio As Double = c1 / c2
     nx = x1 + ratio * vx
     ny = y1 + ratio * vy
                                                  ByVal z1 As Double, _
                                                  ByVal z2 As Double, _
                                                  ByVal pz As Double, _
                                                  ByRef ny As Double, _
                                                  ByRef nz As Double)
     Dim vz As Double = z2 - z1
     Dim wz As Double = pz - z1
     Dim c1 As Double = vx * wx + vy * wy + vz * wz
     If c1 <= 0# Then
         nx = x1
         ny = y1
         nz = z1
         Return
     End If
     Dim c2 As Double = vx * vx + vy * vy + vz * vz
     If c2 <= c1 Then
         nx = x2
         ny = y2
         nz = z2
         Return
     End If
     Dim ratio As Double = c1 / c2
     nz = z1 + ratio * vz
gile
  • Marseille, France
« Reply #6 on: May 27, 2011, 01:27:05 AM »
Using the dot product, returns the 'pt' point projection on 'p1 p2' unbounded line.
        private Point3d ProjectPointOnLine(Point3d pt, Point3d p1, Point3d p2)
            Vector3d v1 = p1.GetVectorTo(p2);
            Vector3d v2 = p1.GetVectorTo(pt);
            double scale = v1.DotProduct(v2) / p1.DistanceTo(p2);
            return p1 + v1.GetNormal().MultiplyBy(scale);
huiz
« Reply #7 on: May 27, 2011, 04:01:20 AM »
Wow, all different solutions :-) Thanks all! I will play with all this to find out which is the best for me.
I had searched Google first but after 3 hours of examing complicated formulas I quit.
bieres
« Reply #8 on: May 27, 2011, 04:06:03 AM »
Returns the point or distance perpendicular to the direction formed by two points.
       /// <summary>
        /// Devuelve el punto o distancia perpendicular a la direccion formada por dos puntos.
        /// </summary>
        /// <param name="pto">Punto a calcular.</param>
        /// <param name="p1">Primer punto alineación.</param>
        /// <param name="p2">Segundo punto alineación.</param>
        /// <param name="modo">[True] punto, [False] distancia.</param>
        /// <returns></returns>
        static internal object PntPrpndclr(Point3d pto, Point3d p1, Point3d p2, bool modo)
            Vector3d vect1 = pto.GetVectorTo(p1);
            Vector3d vect2 = vect1.GetPerpendicularVector();
            Plane plano = new Plane(pto, vect1, vect2);
            Point3d pt = p2.OrthoProject(plano);
            if (modo == true){return pt;}else{return pt.DistanceTo(pto);}
gile
  • Marseille, France
« Reply #9 on: May 27, 2011, 04:28:29 PM »
The same as in reply #6 in a more concise way.
            Vector3d vect = (p2 - p1).GetNormal();
            return p1 + vect * vect.DotProduct(pt - p1);
gile
  • Marseille, France
« Reply #10 on: May 27, 2011, 04:47:39 PM »
But IMO the simplest way is to use a Geometry.Line3d instance and the Curve3d.GetClosestPont method.
            return new Line3d(p1, p2).GetClosestPointTo(pt).Point;
huiz
« Reply #11 on: May 29, 2011, 04:06:40 PM »
Simplicity has power!!! :)
Gile, you are brilliant! This function works great and it is really simple. Thanks for your advice! :-)
sinc
« Reply #12 on: May 30, 2011, 11:07:47 AM »
Guess I was a little too vague, eh?   ;-)
huiz
« Reply #13 on: May 30, 2011, 01:59:48 PM »
Hehe :) Not really, I had in mind to examine this one too but at first sight I thought this routine would give back the closest node of a line. I still had in mind that a mathematical formula was the best way till I saw the routine of Gile. Then I tried that and found out that this returned a perpendicular point instead of the nearest point. You also thanks, if Gile didn't post his solution I would find out your solution after I got stuck with complicated formulas :)
« Reply #14 on: May 30, 2011, 02:02:10 PM »
Replace 'instead of' with 'which is, of course,;-)
