Author Topic: Increase the Height of Texts in a Table  (Read 3610 times)
Coder
« on: May 24, 2011, 04:16:36 PM »
Hello everyone .
Is there any lisp routine that could increase the height of texts in a Table's cells ? or by Autocad command that I may do not know ?
Thank you.
Matt__W
  • I like my water diluted.
Re: Increase the Height of Texts in a Table
« Reply #1 on: May 24, 2011, 04:23:52 PM »
Would changing the height of the text style (text style dialog box) being used in the cells be a viable option?
Autodesk Expert Elite
Coder
« Reply #2 on: May 24, 2011, 04:35:32 PM »
Thank you Matt .
That gonna set the text height at the first time I insert the table , and if the the whole table is looks small, I have to scale it to match
the drawing scale and in that time height won't be scale as well as the table .
I noticed also the table is locked when inserted by table command , why is that ?
Many thanks
Matt__W
« Reply #3 on: May 24, 2011, 04:50:28 PM »
What do you mean it's locked?  The layer that it's on is locked?
What version of AutoCAD?
Coder
« Reply #4 on: May 24, 2011, 04:55:07 PM »
The table cells are locked and if I want to edit the text inside I have to unlock the cell to be able to edit the text inside , and not the layer .
Cad version is 2009
« Reply #5 on: May 25, 2011, 07:59:52 AM »
Window over the locked cells and click on the 'Locking' button the toolbar, set it to 'Unlocked'.
Then just modify the text height for the relevant Table Style and the change will be reflected for all tables in the drawing using that style.
Coder
« Reply #6 on: May 25, 2011, 09:53:50 AM »
Thank you Lee.
You're right .
That's why I asked for a routine , I mean it is a very long time consumption and hard work to depend on mouse to click and to enter each cell .  :cry:
Any thoughts ?
Appreciated.
Matt__W
« Reply #7 on: May 25, 2011, 12:16:22 PM »
Cad version is 2009
Huh... I never knew you could lock the cells.
When you create a table, are the cells already locked??
Coder
« Reply #8 on: May 25, 2011, 01:52:44 PM »
Thanks Matt .
I got the Table cells locked when I import a file by the use of table command , which keep me shocked in front of it . :-o
Regards
« Reply #9 on: May 25, 2011, 02:46:23 PM »
You needn't enter each cell, click on the box to the top-left to select all the cells and unlock them all at once.
alanjt
  • Standby for witty remark...
« Reply #10 on: May 25, 2011, 02:58:59 PM »
With all this 'cell' talk, I keep waiting on the prison jokes.
Dropbox
Matt__W
« Reply #11 on: May 25, 2011, 03:03:11 PM »
Just call me Moustache Girl.   :|
http://www.prisonbitchname.com/
alanjt
« Reply #12 on: May 25, 2011, 03:05:09 PM »
:lmao: :lmao:
I'm Mouth-Mangler.
Dropbox
