Author Topic: Feet and Inches... concatinating and passing into an if then statement.  (Read 8075 times)
DIW_CADtech
  • Push limits, embrace success, & discard failure.
I have been working on creating a BOM with formula based columns that include all items in a view file. This BOM {schedule} automaticaly updates, and includes all new items
I have used an if then else statement to control what is placed in the cell, and 3 other DataSetDefinitions to Concatenate Text, Length, and Style for each outcome outlined in the if then statement.
Here is the problem...
I've concatinated [text][length][style][text]
(FC ) (6'-0") (12 Inch D.I. Pipe) (Guaged)
FC 72 12 INCH DI MECH JOINT-TYTON JOINT CEMENT MORTAR LINED ASPHALT COATED (GUAGED)
However.. the [Length] posts in inches.. even more confusing to the client and contractor is the decimal values 17.937 inches.. they expect 1'-5 15/16"  the only value that drives them more insane is feet in decimal 1.49475 Feet.  They don't care about automated schecules and CAD issues, they just want the length in a term they understand, and think we're idiots if we can't type in the correct format of the length.
So if you have any ideas how to correct this I'd like to know... I have great difficulty understanding where to set, and how to control the formatting of the data in the DataSetDefinitions window in the style manager.. and or schedule editor.
See this file.
http://dl.dropbox.com/u/20790817/testing09.dwg
I also attempted to use Chr() to insert ( " ) ( ' ) and ( - )
See this file
http://dl.dropbox.com/u/20790817/testing07.dwg
Any help you could provide will be greatly appreciated.
I am very  trainable....   (forgive my spelling)
I guess this is what you are wanting to see?
There were a few things I did to get this...
1. Created a new DataSetDefinition to return the CutLength formatted as feet & inches. I then changed style3 to use this in the output
2. Edited the Property Data "Unit - Distance Feet-Inches" to include a " as the suffix. This was key in getting the table to display the result instead of the formula....this is due, I'm thinking, to VBScript seeing the inch symbol and stopping evaluation of the formula. As soon as I added the suffix it all displayed correctly.
If this doesn't help you figure it out I'll post the modified drawing.
DIW_CADtech
This is closer.. I need the fractions of an inch as well
It would help to see the file...  I've been looking online at VB Code to convert decimal inches to feet & inches, but I'm not sure how to implement that in the Dataset definitions
Did you break apart [cutlength] into feet and inches and concatonate?  I would like to see how you did that as I have seen some VB code on the net, but not sure how to utilize DIM in the Formula Property Definition
DIW_CADtech
Yes I noticed this befor.. and utilized Chr(34) and it worked in the editor, but when applied to the schedule it busted.
DIW_CADtech
I will admit for this type of pipe this accuracy is probably good enoug.. but when I use this schedule and datasetdefinition  to do flanged pipe... I need to be accurate within 1/16th of an inch.. and If I'm to 16th of an inch on this pipe it's excessive.. but not wrong or confusing to the contractor cutting the pipe....
But the shop creating the flanged spools will make them exactly 1'-3" and then there will be problems in the field.. especially if I have 6 spools and the true required measurment is 1'-2 1/2"  Pipe just doesn't strech or compress nearly enough to handle that. And I can't just ship a handfull of extra gaskets.. So a 1/16th inch accuracy is crucial here.
DIW_CADtech
VB code i was looking at
DIW_CADtech
I would like to post the file anyway to those who may follow the thread in the future... If you can't host it on your Dropbox acount.. sent it and I will post it to mine.
DIW_CADtech
I am trying to do what you suggested above and having little success.. I created a new DataSetDefinition called
Inches2FTnIN
Result = [cutlength]
then I applied that clicked ok and applied the Unit - Distance Feet and Inches, no comma, high precision.
Then I went into the Data Set Definitions and added the (") to the suffex of Feet and inches, No comma, high precision.
I get forumulas in the schedule.. so I removed the (") from the suffex and still posts formula's.
Am I changing the formatting in the wrong location?
DIW_CADtech
Ugggg...
I've separated the Feet, Inches, and fraction into their own Property Set Definition  and When I bring them together in [STYLE3] it seem to work in the formula editor.  That is if I enter in correct data in place of the "sampe"
I used {select case} to determin the fractions
It's still just pumping out CODE...
See attached file
http://dl.dropbox.com/u/20790817/testing11.dwg
Jeff M.. could you look at this and see if you can find where I went wrong...
I avoided using " i the inches instead I opted for (2) " ' " using Chr(39)
I thought that would eliminate the issue..   I may have other issues.
DIW_CADtech
Would it be possible to do this all inside of [STYLE3]
instead of breaking feet,inches, and fractions into other DataSetDefinitions?
I initially thougth this would make the process simpler, but I'm getting confused.
It's killing me that it is soo close... I have to be right on the edge of it...
Sorry, I'm on vacation and was driving all day each of the last 2 days. Now in the middle of Nebraska...
Attached is the drawing I used with the modified/added items mentioned before. I did make one change so it goes to 1/16"
Hope it helps.
DIW_CADtech
Will Look hard at this tomorrow.
I thank you again for your help.  I hope more people will look at this.  Thank you for your assistance.  I can now move on to a new thread. I removed the unused DataSetDefinitions.
End of Thread File
http://dl.dropbox.com/u/20790817/testing13.dwg
Sorry to have interrupted your Vacation.
 :-o
DIW_CADtech
I have continued to modify this schedule.  But it would not be where it is without the help of those in the VB Forum.  Thanks Team.
I hope this also helps others.
Glad I could be of some assistance. In so doing it forced me to look at the MEP product, which I've been wanting to do for some time.
