Thanks,
More ideas?
You can't constrain 3D Solids, but it is possible with block references and Attribs.
See as example 3D_Hello.dwg
1) Open the drawing 3D_Hello.dwg
2) Load the program HofDriven.lsp.
3) Read in the Layout 'Info for HofDriven' the preferable settings.
4) Give in Modelspace the command DRIVEN
5) Give in your settings and click on OK
6) Select the driven dimensional constraint
7) See the moving 3D Text
Regards, HofCAD CSI.
