Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
VB(A)
Topic:
Schedules - Forulas - VB if then statement to check object is pipe HELP
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Schedules - Forulas - VB if then statement to check object is pipe HELP (Read 10562 times)
Jeff H
Needs a day job
Re: Schedules - Forulas - VB if then statement to check object is pipe HELP
Reply #15 on:
May 19, 2011, 08:04:21 PM »
Just figured out how to do public links with dropbox
and when you get it and it works let me know and I will remove it from mine since it is almost full
*******************************Edit**********************
Removed old file link
Last Edit: May 19, 2011, 09:29:30 PM by Jeff H
Logged
--> Donate to TheSwamp <--
DIW_CADtech
Bull Frog
Push limits, embrace success, & discard failure.
Reply #16 on:
May 19, 2011, 09:22:22 PM »
This is soo CLOSE...
I need to work out the lengths... they need to post in feet and inches
i.e. 120 = 10'-0"
Link to the current file is.....
http://dl.dropbox.com/u/20790817/testing04.dwg
thanks again Jeff
Logged
I am very trainable.... (forgive my spelling)
Jeff H
Needs a day job
Reply #17 on:
May 19, 2011, 09:52:49 PM »
Quickest way and if just wanting to show in schedule.
---Select schedule
---Edit Style
---Select Length Column
---Modify
---Change Data Format
Logged
Jeff H
Needs a day job
Reply #18 on:
May 19, 2011, 10:00:51 PM »
Next step is to get Jeff_M away from Civil and into MEP so we would have someone to teach us VB and how to use MEP .NET API
Logged
King Gator
C3D user & customizer
Reply #19 on:
May 19, 2011, 10:08:40 PM »
Now that is humorous and flattering
Although in my brief perusal of MEP (20 minutes or so) I'm seeing things I wish we had IN C3D. I'm leaving on a 2+ week vacation Sunday, perhaps I'll find some time to play around in the MEP world.
Logged
DIW_CADtech
Bull Frog
Reply #20 on:
May 19, 2011, 10:21:16 PM »
http://dl.dropbox.com/u/20790817/testing05.dwg
The point is to only have 3 columns
and the proper format for the length in the Description is feet and inches
i.e. 120 = 10'-0"
I have the extra columns because i'm trying to understand how it works, but I don't want those.
Need to get it into the description correctly. I hope this is still possible.
Logged
DIW_CADtech
Bull Frog
Reply #21 on:
May 19, 2011, 10:22:05 PM »
Seriously.. the more people in the MEP forum the better... feel like I'm swimming with weights...
Logged
DIW_CADtech
Bull Frog
Reply #22 on:
May 19, 2011, 10:47:14 PM »
Unit Feet and inches does NOT seem to work either.. it seems to round to the nearest foot and does not include the marks ( ' ) or ( " )
Logged
DIW_CADtech
Bull Frog
Reply #23 on:
May 20, 2011, 02:35:54 AM »
I even tried to break out the feet inches and 1/16ths to seperate DataSetDefinitions from the [length] and then concatenate them in a DataSetDefinition [PIPELEN]
I did have to use Chr(34) Chr(39) and Chr(47) and it worked as a stand alone.. but once I introduced [PIPELEN] as a separate column... pthh... it went bust
So never got it to concatinate in the first place...
I'm bushed... calling it a night...
http://dl.dropbox.com/u/20790817/testing06.dwg
is the polished ver of 5
http://dl.dropbox.com/u/20790817/testing07.dwg
is my foolish attempt at using Chr()
take a look... or skip if you have a better idea and post that....
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
VB(A)
Topic:
