Author Topic: Sample off a ODCL  (Read 16279 times)
alanjt
  • Standby for witty remark...
Re: Sample off a ODCL
« Reply #15 on: May 16, 2011, 01:53:13 PM »
Dropbox
Atwist
« Reply #16 on: May 16, 2011, 01:54:01 PM »
Thanks Matt,
But this code is for a dcl not for opendcl,or I'm wrong.
I have a make a textbutton
(defun c:start_Start_Tekstlayer25_OnClicked (/)
  (dcl_MessageBox "To Do: code must be added to event handler\r\nc:start_Start_Tekstlayer25_OnClicked" "To do")
But where put I the code to start the lisp.
I'm do not find in the samples of opendcl.
« Reply #17 on: May 16, 2011, 01:55:12 PM »
start here
Atwist
« Reply #18 on: May 16, 2011, 02:01:06 PM »
Thanks MP,
But this is not what I'm looking for.
I'm need a simple answere on my Question, or is that a problem
Matt__W
  • I like my water diluted.
« Reply #19 on: May 16, 2011, 02:06:35 PM »
Autodesk Expert Elite
« Reply #20 on: May 16, 2011, 02:07:22 PM »
Thanks MP,
Unless my crystal ball is in need of a battery upgrade you do not have a simple question. You currently have one seemingly simple question based upon no experience with OpenDCL, but as you foray into OpenDCL dev't you will have many many more questions. Based on that assumption you would highly benefit from working thru the tutorial a couple times, writing a couple modest applications based on the tutorial samples and then come back and ask questions to cement you knowledge. If however you are not capable of working thru tutorials no amount of serial question posting herein will help you. Candidly yours, MP.
Matt__W
« Reply #21 on: May 16, 2011, 02:09:37 PM »
Thanks MP,
HIP! HIP!  FORAY!!!
HIP! HIP!  FORAY!!!
Atwist
« Reply #22 on: May 16, 2011, 02:18:06 PM »
I thought I was sitting in a forum opendcl.  :ugly:
But it is a forum for fun people :cry: :cry: :cry:
« Reply #23 on: May 16, 2011, 02:21:42 PM »
Brother I'm just trying to help you get to your objective the best and fastest way possible, sorry you don't interpret it that way.
Matt__W
« Reply #24 on: May 16, 2011, 02:22:44 PM »
And it kinda sounds like you need help creating a custom toolbar so I provided a link for that.  Baby steps... baby steps.
