Author Topic: Sort list of numbers (vl-sort not allowed)  (Read 33982 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: Sort list of numbers (vl-sort not allowed)
« Reply #30 on: June 20, 2012, 08:12:25 AM »
optimization for repetitive elements:
  1. (defun eea-sort (l / f)
  2.   (defun f (a b c i)
  3.     (cond ((not c) (append (eea-sort a) i (eea-sort b)))
  4.           ((< (car c) (car i)) (f (cons (car c) a) b (cdr c) i))
  5.           ((= (car c) (car i)) (f a b (cdr c) (cons (car c) i)))
  6.           ((f a (cons (car c) b) (cdr c) i))
  7.     )
  8.   )
  9.   (if l (f nil nil (cdr l) (list (car l))))
  10. )
(eea-sort '(3 43 2 35 23 4 3 3 53 21 32 123 12))
alanjt
  • Standby for witty remark...
« Reply #31 on: June 20, 2012, 08:30:40 AM »
wow
Dropbox
highflyingbird
  • Later equals never.
« Reply #32 on: June 20, 2012, 08:35:33 AM »
  7.     )
  8.   )
  10. )
Hard error occurred ***
internal stack limit reached (simulated)
Maybe too many recursions
I am a bilingualist,Chinese and Chinglish.
highflyingbird
« Reply #33 on: June 20, 2012, 08:36:36 AM »
This is for test:
  1. (defun c:test (/ N L)
  2.   (initget 7)
  3.   (setq N (fix (getreal "\n&#35831;&#36755;&#20837;&#25968;&#32452;&#30340;&#38271;&#24230;(Please Enter the number of list):")))
  4.   (setq L (GetRandList 0 N N))
  5.
  6.   (benchMark '(Msort L) "MyMergesort" 10)              ;--highflybird's
  7.   (benchMark '(QuickSort L) "QuickSort" 10)             ;--gile's
  8.   (benchMark '(MergeSort L) "MergeSort" 10)           ;--gile's
  9.   (benchMark '(eea-sort L) "EEA-Sort" 10)                ;-- ElpanovEvgeniy's
  10.   (benchMark '(vl-sort L '<) "vl-sort" 10)
  11. )
  12.
  1. ;;;============================================================
  2. ;;;&#27979;&#35797;&#29992;&#20989;&#25968;(benchMark function)
  3. ;;;============================================================
  4. (defun Benchmark (func funName times / t0 t1 res)
  5.   (setq t0 (getvar "TDUSRTIMER"))
  6.   (repeat times
  7.     (setq res (eval func))
  8.   )
  9.   (setq t1 (* (- (getvar "TDUSRTIMER") t0) 86400))
  10.
  11.   (princ (strcat "\n\nIt takes: " (rtos t1 2 6) " Seconds  by  " funName))
  12.   (princ (strcat ".\nTotal times: " (itoa times)))
  13.   (princ (strcat ".\nSpeed is: " (rtos (/ t1 times) 2 6) " Seconds/times."))
  14.   ;(princ "\nThe result is: ")
  15.   ;(princ res)
  16. )
  17.
  18.
  19. ;;;---------------------------------------------------------------------
  20. ;;;Definine Rand()
  21. ;;;---------------------------------------------------------------------
  22. (defun GetRandList(a b n / str scr lst)
  23.   (setq scr (vlax-create-object "ScriptControl"))                       ;Create a script
  24.   (vlax-put scr 'Language "VBS")
  25.   (setq str "Randomize\nFunction Rand(x,y)\nRand=x+Rnd*(y-x)\nEnd Function")
  26.        ;for randomize some features
  27.   (vlax-invoke Scr 'ExecuteStatement str)                               ;Execute script
  28.   (defun Rand (scr nMin nMax)                                           ;Rand function
  29.     (vlax-invoke scr 'run "Rand" nMin nMax)
  30.   )
  31.   (repeat n
  32.     (setq lst (cons (rand scr a b) lst))
  33.   )
  34.   lst
  35. )
« Last Edit: June 20, 2012, 08:56:20 AM by HighflyingBird »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #34 on: June 20, 2012, 08:41:24 AM »
  7.     )
  8.   )
  10. )
recursion is not the best approach for large lists...
maybe my computer is a little stronger  :-)
highflyingbird
« Reply #35 on: June 20, 2012, 08:46:52 AM »
Yes,I am working on an old machine. :oops:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #36 on: June 22, 2012, 10:06:01 AM »
new version:
  1. (defun eea-sort-1 (l)
  2.   (defun m (l) (apply (function min) l))
  3.   (defun r (l i) (if (and l (/= (car l) i)) (cons (car l) (r (cdr l) i)) (cdr l)))
  4.   (defun f (l / a) (setq a (m l)) (if l  (cons a (f (r l a)))))
  5.   (f l)
  6. )
« Last Edit: June 22, 2012, 10:11:17 AM by ElpanovEvgeniy »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #37 on: June 22, 2012, 10:41:38 AM »
  1. (defun eea-sort-2 (l)
  2.   (defun r (l i) (if (and l (/= (car l) i)) (cons (car l) (r (cdr l) i)) (cdr l)))
  3.   (defun f (l / a) (if l (cons (setq a (apply (function min) l)) (f (r l a)))))
  4.   (f l)
  5. )
Gasty
Re: Sort list of numbers (vl-ssk ort not allowed)
« Reply #38 on: June 22, 2012, 09:46:17 PM »
This one is from Vladimir Nesterovsky, an old contributor to the Autodesk Group:
;;;         Mergesort.lsp
;;;  free for non-commercial use only
;;;   1999 (C.) Vladimir Nesterovsky
;;;      vnestr@netvision.net.il
;;; http://www.netvision.net.il/php/vnestr
;;; sort a list by standard mergesort method
;;; using a user-specified comparison function
;;; which should return true if and only if its
;;; first argument is strictly less than the
;;; second (in some appropriate sense).
;;; also, define a wrapper function that'll allow
;;; for sorting by user-supplied "value function",
;;; which is a function of one argument returning
;;; some "value" recognizable by the built-in '<
;;; operator. Sorting in this way can be much much
;;; faster then the usual way of calling the
;;; comparison function for each compare, because
;;; this potentially slow and heavy value-function
;;; gets called only ONCE for each element, and later
;;; all the compares are done with very fast and
;;; efficient built-in '< calls
;;; keeping original order of equal elements
;;; in the list (what's called "stable sort")
;;; uses recursion, so potentially unsafe
;;; more code is inlined to speed up the end cases
;;; handling, like 2-, 3- or 4-elements lists,
;;; also reducing the amount of recursion,
;;; which amounts to some 45% speed gain
(defun mergesort (lst less-then?)
 ;; is it the fastest autolisp version?
 (setq less-then? (make-usubr less-then?))
 (_mrgsrt lst))
(defun make-usubr (f)
  ((and (not (atom f))
        (not (equal 'LAMBDA (car f))))
     (eval (cons 'LAMBDA f)))
  ((eval f))))
(defun _mrgsrt (ls / len a b c d l1)
  ((< (setq len (length ls)) 2)
    ;; one-element or empty list
    ls)
  ((= len 2)
    ;; 26% speed gain for 10-elems list, 18% for 250
    ;; when this special case inlined
    (if (less-then? (cadr ls) (car ls))
      (reverse ls)
      ls))
  ((= len 3)
    ;; more 10% speed gain
        ((less-then? (caddr ls) (cadr ls))
          (reverse ls))
        ((less-then? (caddr ls) (car ls))
          (list (cadr ls) (caddr ls) (car ls)))
        ((list (cadr ls) (car ls) (caddr ls))))
          (list (caddr ls) (car ls) (cadr ls)))
          (list (car ls) (caddr ls) (cadr ls)))
        ( ls ))))
  ((= len 4)
    ;; another 15% speed gain for 4*2^n initial lengths
    ;; (no impact on 3*2^n cases)
      (setq a (cadr ls) b (car ls))
      (setq b (cadr ls) a (car ls)))
    (if (less-then? (last ls) (caddr ls))
      (setq c (last ls) d (caddr ls))
      (setq d (last ls) c (caddr ls)))
      ((less-then? d a)
        (list c d a b))
      ((less-then? d b)
        (if (less-then? c a)
          (list c a d b)
          (list a c d b)))
      ((cond
          ((less-then? c a)
            (list c a b d))
          ((less-then? c b)
            (list a c b d))
          ((list a b c d))))))
  ( t
    ;; general case
    (repeat (/ len 2)
      (setq l1 (cons (car ls) l1)
            ls (cdr ls)))
    (_mrgsrt-merge
      (_mrgsrt (reverse l1))
      (_mrgsrt ls)))))
;;; merge two sorted lists in a stable manner
;;; less-then? usubr assumed to be defined globally
;;; may be used independently when needed
(defun _mrgsrt-merge (l1 l2 / rslt)
    (while (and l1 l2)     ;merge the sorted halves back
      (while (and l1 l2
               (not (less-then? (car l2) (car l1))))
        (setq rslt (cons (car l1) rslt)
               l1  (cdr l1)))
      (while (and l1 l2
        (setq rslt (cons (car l2) rslt)
               l2  (cdr l2))) )
    (foreach e l1 (Setq rslt (cons e rslt)))
    (foreach e l2 (Setq rslt (cons e rslt)))
    (reverse rslt))
;;; sort by Value function
;;;  (it's generally much faster then sorting
;;;   by compare-function because potentially
;;;   slow value-function will be called only
;;;   once for each element here)
;;; Value function is such that excepts one
;;;  argument and returns an atomic value
;;;  for which calling '< is meaningful
;;;  (numbers usually, but may be strings too).
(defun Vmergesort (lst valfun)
 (setq valfun (make-usubr valfun))
 (mapcar 'cdr
  (mergesort
   (mapcar '(lambda (e)      ;calculate results
              (cons (valfun e) e)) ; in advance
            lst)             ;store them and
   car-less?)))              ;sort by comparing CARs
(defun car-less? (a b)
 (< (car a) (car b)))
;;; one possible efficiency improvement can be
;;; to implement a special version of vmergesort
;;; hand-coded to sort its argument list elements
;;; by their CARs and also automatically strip them
;;; away with CDRs while merging half-lists back
(princ "\n   Usage: (MERGESORT list compare-function) ")
(princ "\n   Or better: (VMERGESORT list value-function)")
Stefan
  • The most I miss IRL is the Undo button
« Reply #39 on: June 23, 2012, 01:42:07 PM »
My first release
  1. (defun ph:sort (l / f g s r)
  2.   (defun f (l n)
  3.     (if l
  4.       (if (<= n (caar l))
  5.         (cons (cons n (car l)) (cdr l))
  6.         (cons (car l) (f (cdr l) n))
  7.       )
  8.       (list (list n))
  9.     )
  10.   )
  11.   (defun g (l1 l2)
  12.     (if l1
  13.       (if l2
  14.         (if (< (car l1) (car l2))
  15.           (cons (car l1) (g (cdr l1) l2))
  16.           (cons (car l2) (g l1 (cdr l2)))
  17.         )
  18.         l1
  19.       )
  20.       l2
  21.     )
  22.   )
  23.   (foreach n l (setq s (f s n)))
  24.   (foreach n s (setq r (g r n)))
  25. )
Stefan
« Reply #40 on: June 23, 2012, 02:20:58 PM »
Crap... nothing new...
It could be
  1. (defun ph:sort1 (l / f r)
  2.   (defun f (l n)
  3.     (if l
  4.       (if (<= n (car l))
  5.         (cons n l)
  7.         )
  8.       (list n)
  9.       )
  10.     )
  11.   (foreach n l (setq r (f r n)))
  12.   )
which is nothing more than a direct approach...
highflyingbird
« Reply #41 on: June 24, 2012, 07:23:35 AM »
My quick sort :
  1. ;;;=============================================================
  2. ;;;Highflybird's  Quick Sorting algorithm -- 1
  3. ;;;Considered this case: a sorted list.
  4. ;;;If the list is random,just a little slower than Quick Sort 2
  5. ;;;but the list is sorted,then is much faster than Quick Sort 2
  6. ;;;=============================================================
  7. (defun H:QSort1 (Lst / a k L R S)
  8.   (if (cddr lst)
  9.     (progn
  10.       (setq k (* (+ (car Lst) (last lst)) 0.5))                 ;the pivot,this is for the worst situation
  11.       (setq s lst)
  12.       (while s
  13.         (if (< (setq a (car S)) k)                              ;compare to the pivot
  14.           (setq L (cons a L))                                   ;put the less into the left list
  15.           (Setq R (cons a R))                                   ;put the greater into the right list
  16.         )
  17.         (setq S (cdr S))
  18.       )
  19.       (cond
  20.         ((null R) (H:QSort1 L))                                 ;the right is empty,the recurse the left
  21.         ((null L) (H:QSort1 R))                                 ;the Left is empty,the recurse the right
  22.         (T (append (H:QSort1 L) (H:QSort1 R)))                  ;otherwise,recurse both
  23.       )
  24.     )
  25.     (if (and (cdr lst) (> (car lst) (cadr lst)))                ;the length of list <= 2
  26.       (reverse lst)
  27.       lst
  28.     )
  29.   )
  30. )
  31.
take the first number as pivot:
  2. ;;;Highflybird's  Quick Sorting algorithm -- 2
  3. ;;;Based the Quick Sorting algorithm ,the worst O(N^2), the best
  4. ;;;is O(log(N)),average case performance is O(log(N))
  5. ;;;=============================================================
  6. (defun H:QSort2 (Lst / a k L R S)
  7.   (if (cddr lst)
  8.     (progn
  9.       (setq k (car Lst))                                        ;the pivot
  10.       (setq S lst)
  11.       (while (setq S (cdr S))
  12.         (if (< (setq a (car S)) k)                              ;compare to the pivot
  13.           (setq L (cons a L))                                   ;put the less into the left list
  14.           (Setq R (cons a R))                                   ;put the greater into the right list
  15.         )
  16.       )
  17.       (cond
  18.         ((null R) (reverse (cons k (reverse (H:QSort2 L)))))    ;the right is empty,the recurse the left
  19.         ((null L) (cons k (H:QSort2 R)))                        ;the Left is empty,the recurse the right
  20.         (T (append (H:QSort2 L) (cons k (H:QSort2 R))))         ;otherwise,recurse both and add the pivot.
  21.       )
  22.     )
  23.     (if (and (cdr lst) (> (car lst) (cadr lst)))                ;the length of list <= 2
  24.       (reverse lst)
  25.       lst
  26.     )
  27.   )
  28. )
  29.
use safearray:
  2. ;;;Highflybird's  Quick Sorting algorithm -- 3
  3. ;;;Because "nth" function is slower,so use safeArray.
  4. ;;;the advantage is: the space is slower ,just O(1)
  6. (defun QSort3 (low high / i j p c v)
  7.   (if (< low high)
  8.     (progn
  9.       (setq i low)
  10.       (setq j (1+ high))
  11.       (setq p (vlax-safearray-get-element a low))
  12.       (setq C T)
  13.       (while C
  14.         (while
  15.           (and (< (vlax-safearray-get-element a (setq i (1+ i))) p)
  16.                (< i high)
  17.           )
  18.         )
  19.         (while (> (vlax-safearray-get-element a (setq j (1- j))) p))
  20.         (if (< i j)
  21.           (progn
  22.             (setq v (vlax-safearray-get-element a i))
  23.             (vlax-safearray-put-element a i
  24.               (vlax-safearray-get-element a j)
  25.             )
  26.             (vlax-safearray-put-element a j v)
  27.           )
  28.           (setq C nil)
  29.         )
  30.       )
  31.       (vlax-safearray-put-element a low
  32.         (vlax-safearray-get-element a j)
  33.       )
  34.       (vlax-safearray-put-element a j p)
  35.       (QSort3 low (1- j))
  36.       (QSort3 (1+ j) high)
  37.     )
  38.   )
  39. )
  40.
  41. (defun MakeArr (L DataType / n a)
  42.   (setq n (length L))
  43.   (setq a (vlax-make-safearray DataType (cons 0 (1- n))))
  44. )
  45.
  46. (defun H:QSort3 (L / a k c)
  47.   (setq a (makearr L vlax-vbdouble))
  48.   (setq k (length L))
  49.   (QSort3 0 (1- k))
  50.   (vlax-safearray->list A)
  51. )
highflyingbird
« Reply #42 on: June 24, 2012, 07:26:41 AM »
Shell sort:
  2. ;;;Highflybird's Shell Sorting algorithm -- 1
  3. ;;;Based the Shell Sorting algorithm
  4. ;;;=============================================================
  5. (defun H:ShellSort (L / a gaps i j k temp gap x n)
  6.   (setq n (length L))
  7.   (setq a (makeArr L vlax-vbdouble))
  8.   ;;(setq gaps  '(1 4 10 23 57 132 301 701 1750))
  9.   (setq gaps '(1 5 13 43 113 297 815 1989 4711 11969 27901 84801 213331 543749 1355339
  10.                3501671 8810089 21521774 58548857 157840433 410151271 1131376761 2147483647))
  11.   (setq k 0)
  12.   (while (< (nth k gaps) n)
  13.     (setq k (1+ k))
  14.   )
  15.   (while (>= (setq k (1- k)) 0)
  16.     (setq gap (nth k gaps))
  17.     (setq i gap)
  18.     (while (< i n)
  19.       (setq temp (vlax-safearray-get-element a i))
  20.       (setq j i)
  21.       (while (and (>= j gap)
  22.                   (> (setq x (vlax-safearray-get-element a (- j gap))) temp)
  23.              )
  24.         (vlax-safearray-put-element a j x)
  25.         (setq j (- j gap))
  26.       )
  27.       (vlax-safearray-put-element a j temp)
  28.       (setq i (1+ i))
  29.     )
  30.   )
  31.   (vlax-safearray->list A)
  32. )
  33.
  34. ;;;=============================================================
  35. ;;;Highflybird's Shell Sorting algorithm -- 1
  36. ;;;Based the Shell Sorting algorithm
  37. ;;;=============================================================
  38. (defun shellSort-1 (v s / GAP I J K P X Y)
  39.   (setq gap (/ s 2))
  40.   (while (> gap 0)
  41.     (setq i gap)
  42.     (while (< i s)
  43.       (setq j (- i gap))
  44.       (while (>= j 0)
  45.         (setq k (+ j gap))
  46.         (setq x (vlax-safearray-get-element v k))
  47.         (setq y (vlax-safearray-get-element v j))
  48.         (if (< x y)
  49.           (progn
  50.             (setq p y)
  51.             (vlax-safearray-put-element v j x)
  52.             (vlax-safearray-put-element v k p)
  53.           )
  54.         )
  55.         (setq j (- j gap))
  56.       )
  57.       (setq i (1+ i))
  58.     )
  59.     (setq gap (/ gap 2))
  60.   )
  61.   v
  62. )
highflyingbird
« Reply #43 on: June 24, 2012, 07:29:36 AM »
This is the test result (on my old machine):
1,for a random list
Please Enter the length of list: 5000
Please enter the times of test:5
Statement                         Times    Elapse(s)    Average(s/time)
(VL-SORT L (QUOTE <))       5        0.094        0.0188
(H:MERGESORT L)                5        1.359        0.2718
(H:QSORT2 L)                      5        1.844        0.3688
(G:MERGESORT L)                5        2.141        0.4282
(H:QSORT1 L)                      5        2.422        0.4844
(H:QSORT3 L)                      5        2.765        0.553
(EEA-SORT L)                      5        3.078        0.6156
(G:QUICKSORT L)                5        3.766        0.7532
(H:SHELLSORT L)                 5        4.203        0.8406
(PH:SORT L)                        1        2.719        2.719
(PH:SORT1 L)                      1        22.953       22.953
(G:INSERTSORT L)                1        26.484       26.484
(EEA-SORT-1 L)                    1        33.672       33.672
(IREB:SORT-MERGE-R L (QUOTE <))   1        59.766       59.766
(IREB:SORT-MERGE-I L (QUOTE <))   1        59.797       59.797
(G:BUBBLESORT L)                  1        74.828       74.828
2, for a sorted list:
Please enter the times of test:2
(VL-SORT L (QUOTE <))        2        0.016        0.008
(H:MERGESORT L)                 2        0.375        0.1875
(G:MERGESORT L)                  2        0.407        0.2035
(H:QSORT1 L)                      2        0.562        0.281
(H:SHELLSORT L)                 2        0.719        0.3595
(H:QSORT2 L)                      2        49.547       24.7735
(H:QSORT3 L)                      2        53.125       26.5625
(G:QUICKSORT L)                   2        168.843      84.4215
3,for a large number list
Please Enter the length of list: 20000
(VL-SORT L (QUOTE <))        5        0.562        0.1124
(H:MERGESORT L)                5        11.656       2.3312
(H:QSORT2 L)                      5        14.61        2.922
(G:MERGESORT L)                5        16.579       3.3158
(H:QSORT3 L)                      5        19.047       3.8094
(H:QSORT1 L)                      5        21.172       4.2344
(G:QUICKSORT L)                5        30.218       6.0436
(H:SHELLSORT L)                 5        31.453       6.2906
« Last Edit: June 25, 2012, 06:28:05 AM by HighflyingBird »
highflyingbird
« Reply #44 on: June 24, 2012, 07:34:59 AM »
This is the lisp file. includes  my code,gile's ,Stefan's,ireb's ,ElpanovEvgeniy's code.
I compiled this file,then run the test.
