Author Topic: Sort list of numbers (vl-sort not allowed)  (Read 35781 times)
xiaxiang
Re: Sort list of numbers (vl-sort not allowed)
« Reply #45 on: June 24, 2012, 09:20:58 PM »
This is the lisp file. includes  my code,gile's ,Stefan's,ireb's ,ElpanovEvgeniy's code.
I compiled this file,then run the test.
Nicely work,HighflyingBird
Thank you!
chlh_jd
« Reply #46 on: October 17, 2014, 12:10:53 PM »
Hi, Gile
After revisit this site , I found a bug in the quicksort function you post .
(quicksort '(6 5 4 3 3 2 1)) ;;--> '(1 2 3 3 3 4 5 6)It more out a number 3 .
« Reply #47 on: October 17, 2014, 06:27:10 PM »
Hi, Gile
Change:
((< ele (car lst)) (left ele (cdr lst)))to:
((<= ele (car lst)) (left ele (cdr lst)))
« Reply #48 on: October 17, 2014, 07:43:38 PM »
FWIW, the function could also be written:
  1. (defun qs ( l ) (if l (fn (car l) (cdr l))))
  2. (defun fn ( x l / m )
  3.     (setq l (vl-remove-if '(lambda ( y ) (if (< x y) (setq m (cons y m)))) l))
  4.     (append (qs l) (cons x (qs (reverse m))))
  5. )
  1. _$ (qs '(6 5 4 3 3 2 1))
  2. (1 2 3 3 4 5 6)
chlh_jd
« Reply #49 on: October 18, 2014, 01:42:09 PM »
Thanks Lee Mac  , thank you a lot .
« Reply #50 on: October 18, 2014, 01:43:35 PM »
You're most welcome chlh_jd  :-)
