Author Topic: Sort list of numbers (vl-sort not allowed)  (Read 33841 times)
Jeff H
« on: May 14, 2011, 09:22:04 PM »
Trying to pick up some Lisp and thought this would be good thing to try.
I have messed with it a little but not yet there.
Sorting a list of numbers with just AutoLisp.
(8 5 2 7 4 3)
(2 3 4 5 7 8 )
I did not see a example without vl-sort used.
Peter Jamtgaard
Re: Sort list of numbers (vl-sort not allowed)
« Reply #1 on: May 14, 2011, 10:57:34 PM »
Its been a few years since I wrote my last bubble sort function.
(bubblesort '(8 5 2 7 4 3))  returns '(2 3 4 5 7 8 )
(defun BubbleSort (lstItems / blnFlag item1 item2 lstItems2)
 (setq item1 (car lstItems))
 (foreach item2 (cdr lstItems)
  (if (<= item1 item2)
   (setq lstItems2 (cons item1 lstItems2)
         item1     item2
   (setq lstItems2 (cons item2 lstItems2)
         blnFlag   T
 (if blnFlag
  (BubbleSort (reverse (cons item1 lstItems2)))
« Last Edit: May 15, 2011, 09:18:45 AM by peterj »
« Reply #2 on: May 14, 2011, 11:18:44 PM »
  (if (< item1 item2)
         item1     item2
         blnFlag   T
 (if blnFlag
Hello Peter,
What does this give you ??
(bubblesort '(8 6 5 2 7 4 6 3))
pBe
« Reply #4 on: May 15, 2011, 12:58:15 AM »
what about good 'ol acad_strlsort? would that be considered cheating?  :lol:
(mapcar '(lambda (y)
               (ascii y))
        (acad_strlsort
              (mapcar '(lambda (x)
                             (chr x))
                      '(8 6 5 2 7 4 6 3))))
(2 3 4 5 6 6 7 8 )
works only for single digit integers though
as you can see here
               (ascii y))
        (acad_strlsort
                             (chr x))
                      '(8 227 101 6 5 2 12 37 7 28 4 6 3 105 10 13))))
(2 3 4 5 6 6 7 8 28 10 12 13 37 227 101 105)
bummer
« Last Edit: May 15, 2011, 01:16:25 AM by pBe »
gile
  • Marseille, France
« Reply #5 on: May 15, 2011, 05:06:46 AM »
Here're some of the most famous sorting algorithms implementation examples (using 'functional style' rather than looking for 'brute performance'):
EDIT: revised codes
Bubble sort
(defun bubblesort (lst / bubble)
  (defun bubble (ele lst)
      ((null lst) ele)
      ((< (car lst) ele) (bubble (car lst) (cdr lst)))
      ((bubble ele (cdr lst)))
  ((lambda (b)
     (if lst
       (cons b (bubblesort (vl-remove b lst)))
Insertion sort
(defun insertsort (lst / insert)
  (defun insert (ele lst)
      ((null lst) (list ele))
      ((< ele (car lst)) (cons ele lst))
      ((cons (car lst) (insert ele (cdr lst))))
  (if lst
    (insert (car lst) (insertsort (cdr lst)))
Quick sort
(defun quicksort (lst / left right)
  (defun left (ele lst)
      ((null lst) nil)
      ((< ele (car lst)) (left ele (cdr lst)))
      (T (cons (car lst) (left ele (cdr lst))))
  (defun right (ele lst)
      ((null lst) nil)
      ((< (car lst) ele) (right ele (cdr lst)))
      (T (cons (car lst) (right ele (cdr lst))))
  (if lst
    (append (quicksort (left (car lst) (cdr lst)))
    (cons (car lst)
  (quicksort (right (car lst) (cdr lst)))
Merge sort
(defun mergesort (lst / merge brklst)
  (defun merge (l1 l2)
      ((null l1) l2)
      ((null l2) l1)
      ((if (< (car l1) (car l2))
(cons (car l1) (merge (cdr l1) l2))
(cons (car l2) (merge l1 (cdr l2)))
  (defun brklst (lst acc n)
    (if (= 0 n)
      (list acc lst)
      (brklst (cdr lst) (cons (car lst) acc) (1- n))
  (if (cdr lst)
      (setq lst (brklst lst nil (/ (length lst) 2)))
      (merge (mergesort (car lst))
     (mergesort (cadr lst))
    lst
« Last Edit: May 22, 2011, 04:02:45 PM by gile »
highflyingbird
  • Later equals never.
« Reply #6 on: May 15, 2011, 05:28:40 AM »
Hi,Here're some of the most famous sorting algorithms implementation examples (using 'functional style' rather than looking for 'brute performance'):
Really wonderful code. I like it.
I am a bilingualist,Chinese and Chinglish.
pBe
« Reply #7 on: May 15, 2011, 06:07:10 AM »
(defun BubbleSort  (nlst / loopnum lownum next sorted nlst)
(defun loopnum  (low lst /  )
    (if (setq a low
              b (cdr lst))
          (if (minusp (- (car b) a))
                (loopnum (car b) b)
                (if b (loopnum a b)))
    a
      (while (setq Lownum (car nlst))
            (setq next (cdr nlst))
            (setq Sorted (cons (loopnum Lownum nlst) Sorted))
            (setq nlst (vl-remove (car sorted) nlst))
            (if (member Lownum sorted)
                  (setq nlst (vl-remove lownum nlst))
      (reverse sorted)
(BUBBLESORT '(8 5 2 7 4 3))
(2 3 4 5 7 8 )
(BUBBLESORT '(6 5 3 8 10 25 712 13 37 4 105 ))
(3 4 5 6 8 10 13 25 37 105 712)
(BUBBLESORT '(-1 6 5 3 6 -34  111 3  3 4 1  5 1258 10 23 52.3 6 2015 712 8 13 37 4 105 ))
(-34 -1 1 3 4 5 6 8 10 13 23 37 52.3 105 111 712 1258 2015)
Removes duplicates as well
Still brute force though  :-)
should've use (< (car b) a) instead of  (minusp (- (car b) a)), what was i thinking!!! it just shows variety i guess  :-)
EDIT: (> (car b) a)<------- retarded (no need for reverse)  :loco:
« Last Edit: May 15, 2011, 08:33:18 AM by pBe »
gile
  • Marseille, France
« Reply #8 on: May 15, 2011, 06:29:22 AM »
Thanks highflybird ,
We had a funny challenge with this task on a French Web site.
« Last Edit: July 12, 2017, 03:17:54 PM by gile »
« Reply #9 on: May 15, 2011, 08:15:28 AM »
Great code Gile - I shall certainly be taking some time to study it  :-)
pBe
« Reply #10 on: May 15, 2011, 08:25:41 AM »
Another....
(defun MinSort (lst / sortedlist)
(while lst
       (setq SortedList (cons (apply 'min lst) SortedList))
               (setq lst (vl-remove (car SortedList) lst))
(reverse SortedList)
for some reason this somehow crash when you use floating numbers
(MINSORT'(-1 6 5 3 6 -34  111 3  3 4 1  5 1258 10 23 52 6 2015 712 8 13 37 4 105 ))
(-34 -1 1 3 4 5 6 8 10 13 23 37 52 105 111 712 1258 2015)
(MINSORT'(8 5 3.36 2 7 4 3 1 12))<--------
Why do you think that happens?
EDIT: Shouldve been this way.. no need to reverse the list
(while lst
      (setq SortedList (cons (apply 'max lst) SortedList))
SortedList
« Last Edit: May 15, 2011, 08:30:02 AM by pBe »
« Reply #11 on: May 15, 2011, 08:32:26 AM »
Because when you use:
(apply 'min <list>)
All numbers within the list are converted to the same datatype with accuracy preserved, hence, if you have any doubles in the list, all the other integers are converted to a double:
(apply 'min '(4 2 3.36 1))
Returns:  1.0
From this result I'm sure you can work out why your code loops continuously  ;-)
Perhaps add some tolerance:
(defun MinSort ( lst / m )
  (if lst
    (cons (setq m (apply 'min lst))
      (MinSort (vl-remove-if '(lambda ( x ) (equal x m 1e-8)) lst))
« Last Edit: May 15, 2011, 08:35:44 AM by Lee Mac »
pBe
« Reply #12 on: May 15, 2011, 08:40:36 AM »
(apply 'min '(4 2 3.36 1))..
lst will never be nil as the result is nowhere on the list
Thanks for the heads up Lee
pBe
« Reply #13 on: May 15, 2011, 08:44:27 AM »
  (if lst
Will comply  :-)
Thanks my friend
Peter Jamtgaard
« Reply #14 on: May 15, 2011, 09:20:37 AM »
I changed the < to <= in the code above.
returns
'(2 3 4 5 6 6 7 8 )
