Author Topic: Linetype load not working in 2012 works 2011  (Read 3122 times)
BIGAL
  • 40 + years of using Autocad
« on: May 12, 2011, 11:19:10 PM »
The following line works ok in VBA all versions up to 2011 but will not work with 2012 checked linetype does not exist hence load. VBA enabler loaded etc remove this line and rest of code works in 2012.
Any ideas ?
for testing
Sub test()
ThisDrawing.Linetypes.Load "DASHED2", "s:\autodesk\supportfiles\ACAD.lin"
End Sub
RickyD302
Re: Linetype load not working in 2012 works 2011
« Reply #1 on: May 14, 2011, 02:55:35 PM »
is s: a mapped drive...maybe use full path
Growing OLD is mandatory; Growing UP is optional
BIGAL
« Reply #2 on: May 15, 2011, 10:30:50 PM »
After a bit of a trial this works but linetype must be located in search paths.
ThisDrawing.Linetypes.Load "DASHED2", "ACAD.lin"
