Author Topic: Block filter specific to an attribute  (Read 5029 times)
Re: Block filter specific to an attribute
« Reply #15 on: May 11, 2011, 08:26:50 AM »
Hi Kruuger,
There is nothing wrong with your code, but I just wanted to point out that it is more efficient to step through the SelectionSet only once, instead of twice, hence:
(defun c:test ( / ss st n )
  (if (setq ss (ssget "_X" '((0 . "INSERT") (66 . 1))))
    (if (setq st (getstring T "\nSpecify New Value: "))
      (repeat (setq n (sslength ss))
        (LM:SetAttributeValue (ssname ss (setq n (1- n))) "RAUM/GRUPPE" st)
@Hugo,
Regarding Code posting have a read of this:
http://www.theswamp.org/index.php?topic=4429.0
Hugo
« Reply #16 on: May 11, 2011, 08:40:51 AM »
So I get an error message but
So bekomme ich aber eine Fehlermeldung
Specify New Value: 1
; Fehler: Fehlerhafter Argumenttyp: VLA-OBJECT <Objektname: 7ffff6a1990>
(defun c:Raumbuch (/ SS st n)
  (if (setq SS (ssget "_x" '((0 . "INSERT") (66 . 1)))) ;"_:L"
    (if (setq ST (getstring T "\nSpecify New Value: "))
        (LM:SetAttributeValue (ssname ss (setq n (1- n))) "RAUM/GRUPPE" ST)
« Reply #17 on: May 11, 2011, 08:44:02 AM »
Use the original version of LM:SetAttributeValue that you posted.
Also, I again urge you to read this:
Hugo
« Reply #18 on: May 11, 2011, 08:53:17 AM »
@ Lee
Thanks works
How can I reach it I can make the selection with a "FPolygon.
@Lee
Danke funktioniert
Wie kann ich es erreichen das ich die Auswahl mit einer "FPolygon" erstellen kann.
« Reply #19 on: May 11, 2011, 08:57:16 AM »
Remove the '_X' from the ssget function.
Hugo
« Reply #20 on: May 11, 2011, 09:02:49 AM »
So it is not able to create FPolygon  :-(
So geht es aber nicht kann keine FPolygon erstellen
  (if (setq SS (ssget '((0 . "INSERT") (66 . 1))))
« Reply #21 on: May 11, 2011, 09:38:11 AM »
Type 'F' when prompted for selection  :-)
Hugo
« Reply #22 on: May 11, 2011, 09:42:42 AM »
Thanks Lee
It is with us "FP". : lol:
Danke Lee
Es ist bei uns "FP".  :lol:
kruuger
« Reply #23 on: May 11, 2011, 10:01:43 AM »
Hi Kruuger,
@Hugo,
yes, you are right
kruuger
Hugo
« Reply #24 on: May 11, 2011, 12:23:14 PM »
@ Kruuger, Lee
Now it works great, thank you both.   :-) :-)
Jetzt funktioniert es super, danke an beide.
