(defun c:InsPC (/ ent blk blkang blkangD blkins blkinsX blkinsY blkinsZ
ThisOne InsList
pt inspt insptX insptY insptZ insblk) ;pBe
(setq ent (entget (car (entsel))))
(setq blk (tblobjname "block" (cdr (assoc 2 ent))))
(setq blkang (cdr (assoc 50 ent)))
(setq blkangD (/ (* blkang 180.0) pi))
(setq blkins (cdr (assoc 10 ent)))
(if (not (tblsearch "block" "Point-0"))
(command "insert" "C:/EC-Menu/Blocks/EC-Coord.dwg" '(0.0 0.0 0.0) "1" "1" "0")
(command "erase" "last" "")
(while
(setq blk (entnext blk))
(if (and
(eq (cdr (assoc 0 (setq ThisOne (entget blk)))) "INSERT")
(eq (cdr (assoc 2 (setq ThisOne (entget blk)))) "PileSymbol")
(setq InsList (cons (list (cdr (assoc 2 ThisOne))
(cdr (assoc 10 ThisOne))) InsList))))
(foreach pt InsList
(setq inspt (trans (cadr pt)1 0))
(setq insblk (entmakex (list (cons 0 "INSERT")
(cons 2 "Point-0")
(cons 10 (list (+ (nth 0 (trans (cadr pt)1 0)) (nth 0 (cdr (assoc 10 ent))))
(+ (nth 1 (trans (cadr pt)1 0)) (nth 1 (cdr (assoc 10 ent))))
(+ (nth 2 (trans (cadr pt)1 0)) (nth 2 (cdr (assoc 10 ent))))
(cons 41 0.25)
(cons 42 0.25)
(cons 43 0.25))))
(command "._rotate" "last" "" blkins blkangd)
