Author Topic: List in Lists--(alanjt)  (Read 10605 times)
VovKa
  • Ukraine
Re: List in Lists--(alanjt)
« Reply #15 on: May 13, 2011, 04:02:57 AM »
Jeff thinks that
(CountAtoms nil) -> 0
Lee thinks that
(CountAtoms nil) -> 1
Who's right?
« Reply #16 on: May 13, 2011, 05:03:43 AM »
since NIL is an atom
(CountAtoms nil) should return 1
unless I misread something :)
« Reply #17 on: May 13, 2011, 05:56:50 AM »
Following the earlier examples, I offer this 'tail recursive' version:
(defun CountAtoms ( lst / _iterate )
  (defun _iterate ( lst acc )
      ( (null lst) acc )
      ( (atom lst) (1+ acc) )
      ( (atom (car lst)) (_iterate (cdr lst) (1+ acc)) )
      ( (_iterate (cdr lst) (_iterate (car lst) acc) ) )
  (_iterate lst 0)
Question: Do all tail recursive functions require an accumulator?
Jeff H
« Reply #18 on: May 13, 2011, 02:06:45 PM »
Jeff thinks that
Lee thinks that
Who's right?
I am not thinking much and have very little knowledge when it comes to lisp, so I would not assume I fully understand.
With that said I should just go back and edit the OP to say counting all atoms in a given list.
I think that would make the code I posted correct.
« Reply #19 on: May 13, 2011, 02:21:42 PM »
Jeff thinks that
Lee thinks that
Who's right?
There is no right or wrong, only ones and zeros, we have achieved a zen state as the answer is both one and zero.
« Reply #20 on: May 13, 2011, 04:59:16 PM »
<snip>
yes.
gile
  • Marseille, France
« Reply #21 on: May 13, 2011, 05:32:03 PM »
I'd say: most of the time, yes.
But here's an example of tail recursion without accumulator:
(defun some (ele lst)
  (and lst
       (or (equal (car lst) ele)
   (some ele (cdr lst))
« Reply #22 on: May 13, 2011, 06:27:37 PM »
Thanks gile, that's a good example :-)
I suppose many recursive functions which return a boolean value will be tail-recursive - your example made me think of this one:
(defun _member ( x lst )
  (vl-some
    (function
      (lambda ( e )
        (if (listp e) (_member x e) (equal x e))
    lst
gile
  • Marseille, France
« Reply #23 on: May 14, 2011, 02:48:42 AM »
Not only Boolean returns, this one mimics the native 'member' function:
(defun memb (ele lst)
  (if lst
    (if (equal (car lst) ele)
      lst
      (memb ele (cdr lst))
Jeff H
« Reply #24 on: May 14, 2011, 03:10:20 AM »
Is this a decent style or a good way of coding it? Mimicking problem solving and layout from site posted earlier
It is assumed or expected that a list will be the second parameter.
(defun My-Member (Expression lst)
    ((null lst) nil)
    ((equal Expression (car lst)) lst)
    (T (My-Member Expression (cdr lst)))
or is if stament perfered?
gile
  • Marseille, France
« Reply #25 on: May 14, 2011, 04:59:56 AM »
Yes, and probably more readable than nested if statements.
With AutoLISP, the arguments order doesn't matter more than make the code more readable (or similar to built-in functions).
For example, most AutoLISP higher order functions (mapcar, vl-some, ...) require the function argument as first argument but vl-sort take it as last argument.
The choice of arguments order is more important in F# due to the pipelining ability (as List.map or List.exists, List.sortBy or List.sortWith requires the list as last argument).
Peter Jamtgaard
« Reply #26 on: May 14, 2011, 12:11:14 PM »
I noticed this thread over at augi lisp forum,
this was what I came up with...
I figure one of you guys must have already come up with this,
but if you haven't...
Peter
Code:
(defun RecurseList (lstSublist)
 (if (= (type lstSublist) 'LIST)
  (apply 'append (mapcar 'recurselist lstSublist))
  (list lstSublist)
(recurselist '((1 2 (3 4)) (5 (6 7)) "A" nil ((8 nil 9 (10 (11)))) (((A) B) C) (D (E (F (G))))))
returns
'(1 2 3 4 5 6 7 "A" nil 8 nil 9 10 11 A B C D E F G)
Recursion is really mind bending for me  :-P
Comments?
« Reply #27 on: May 14, 2011, 12:27:43 PM »
Hi Peter,
Nice code but you'll have trouble with mapcar when faced with dotted pairs ;)
Lee
Peter Jamtgaard
« Reply #28 on: May 14, 2011, 05:57:59 PM »
It is definitely not as elegant, and one of the reasons I tend to avoid using dotted pairs in my code in lists of sublists
Any suggestions on a better way to determine if a dotted pair is a list would be interesting.
When ever I come up with any new code like that I can depend on the
members of the swamp to let some of the hot air out of my ego...
Nasty dotted pairs...   :-o
So
(defun DottedPairToList (dprItem)
 (if (and (= (type dprItem) 'LIST)
          (cdr dprItem)
          (/= (type (cdr dprItem)) 'LIST)
  (list (car dprItem) (cdr dprItem))
  dprItem
  (apply 'append (mapcar 'recurselist (dottedpairtolist lstSublist)))
  (list lstSublist)
(recurselist '((1 2 (3 4)) (5 (6 . 7)) "A" nil ((8 nil 9 (10 (11)))) (((A) B) C) (D (E (F (G . H))))))
 returns
'(1 2 3 4 5 6 7 "A" nil 8 nil 9 10 11 A B C D E F G H)
« Reply #29 on: May 14, 2011, 06:04:21 PM »
Maybe?
(defun DottedPairToList ( dprItem )
  (if (vl-list-length dprItem)
    dprItem
