A way to understand how recursive functions work is to use the 'trace' LISP function and the vlide 'Trace' window.
Try:
(trace AT:ListCondense)
Then run:
(AT:ListCondense '((1 2) (3 (4 5))))
In the vlide 'Trace' window you can see all recursive calls and their results:
Saisie (AT:LISTCONDENSE ((1 2) (3 (4 5))))
Saisie (AT:LISTCONDENSE (1 2))
Saisie (AT:LISTCONDENSE 1)
Résultat: (1)
Saisie (AT:LISTCONDENSE (2))
Saisie (AT:LISTCONDENSE 2)
Résultat: (2)
Saisie (AT:LISTCONDENSE nil)
Résultat: nil
Résultat: (2)
Résultat: (1 2)
Saisie (AT:LISTCONDENSE ((3 (4 5))))
Saisie (AT:LISTCONDENSE (3 (4 5)))
Saisie (AT:LISTCONDENSE 3)
Résultat: (3)
Saisie (AT:LISTCONDENSE ((4 5)))
Saisie (AT:LISTCONDENSE (4 5))
Saisie (AT:LISTCONDENSE 4)
Résultat: (4)
Saisie (AT:LISTCONDENSE (5))
Saisie (AT:LISTCONDENSE 5)
Résultat: (5)
Résultat: nil
Résultat: (5)
Résultat: (4 5)
Résultat: nil
Résultat: (4 5)
Résultat: (3 4 5)
Résultat: nil
Résultat: (3 4 5)
Résultat: (1 2 3 4 5)
Here's another way for the same task.
The code isn't so concise but may run a little faster because of less recursive calls and the use of 'cons' instead of 'append' (which is more expansive).
The main function: gc:flatlist uses an auxiliary recursive function: foo.
foo is 'tail recursive' (AFAIK AutoLISP do not optimize
tail recursion, but many othe functional languages as F# do) and uses an accumilator (acc) to store the result (in reverse order due to the use of cons).
foo requires two arguments: the list to be processed (lst) and the the list to be returned (acc).
The fuction first evaluates if lst is not nil (empty list)
- if so, calls foo passing it the list tail (cdr) as first argument and, for the second argument, evaluates if the list head (car) is an atom or a list.
-- if it's an atom, just had it to the top of the current accumulator
-- if it's a list, calls foo passing it this list and the current accumulator
- if the list is empty, returns the accumultator
gc:flatlist calls foo passing it the list to process and an empty list as accumulator and reverses the returned list.
(defun gc:flatlist (lst / foo)
(defun foo (lst acc)
(if lst
(foo
(cdr lst)
(if (atom (car lst))
(cons (car lst) acc)
(foo (car lst) acc)
acc
(reverse (foo lst nil))
Tracing the 'foo' subfunction with the same list as upper:
Saisie (FOO ((1 2) (3 (4 5))) nil)
Saisie (FOO (1 2) nil)
Saisie (FOO (2) (1))
Saisie (FOO nil (2 1))
Résultat: (2 1)
Résultat: (2 1)
Résultat: (2 1)
Saisie (FOO ((3 (4 5))) (2 1))
Saisie (FOO (3 (4 5)) (2 1))
Saisie (FOO ((4 5)) (3 2 1))
Saisie (FOO (4 5) (3 2 1))
Saisie (FOO (5) (4 3 2 1))
Saisie (FOO nil (5 4 3 2 1))
Résultat: (5 4 3 2 1)
