Author Topic: List in Lists--(alanjt)  (Read 10521 times)
Jeff H
« on: May 08, 2011, 06:39:10 PM »
If someone has a second can they explain the logic here
From this Link
OP wanted
((1 2 3) (2 3 4) ((5 7 3)) (((G))) ((((A)))))
to list
(1 2 3 2 3 4 5 7 3 G A)
alanjt posted this code
(defun AT:ListCondense (lst)
  ;; Condense list of sublists to a single list
  ;; lst - list of lists to process
  ;; Alan J. Thompson, 08.10.10
  (if lst
    (if (listp lst)
      (append (AT:ListCondense (car lst)) (AT:ListCondense (cdr lst)))
      (list lst)
Re: List in Lists--(alanjt)
« Reply #1 on: May 08, 2011, 07:05:24 PM »
lol, I have the test in reverse.
The logic would be something like the following:
(defun AT:ListCondense ( lst )
[color=green]  ;; Condense list of sublists to a single list
  ;; Alan J. Thompson, 08.10.10[/color]
  (if lst
[color=green]    ;; If we have data to work with...[/color]
    (if (listp lst)
[color=green]      ;; If such data is a List (consider that (listp nil)=T, but we have already
      ;; tested for nil, so we won't enter a recursive black hole...[/color]
      (append
[color=green]        ;; Then Append the result of processing the first item...
        ;; [ If the first item is a list, it will be recursively processed again, else
        ;;   see below for 'else' condition ][/color]
[color=green]        ;; ...With the result of processing the rest of the list
        ;; [ If we have a dotted pair, (cdr lst) will return an atom, hence
        ;;   we skip again to the 'else' condition, otherwise we will just
        ;;   iterate through each item of the list, until nil. ][/color]
[color=green]
      ;; Else we don't have a list, so list the item, so that
      ;; the function returns a list to be either appended or returned.[/color]
      (list lst)
[ I hope I'm not stepping on your toes Alan ]
« Last Edit: May 08, 2011, 07:49:56 PM by Lee Mac »
VovKa
  • Ukraine
« Reply #2 on: May 09, 2011, 03:53:06 AM »
be careful guys :)
(AT:ListCondense '((1 2) (3 nil 4)))
(LM:Flatten '((1 2) (3 nil 4)))
gile
  • Marseille, France
« Reply #3 on: May 09, 2011, 06:01:42 AM »
A way to understand how recursive functions work is to use the 'trace' LISP function and the vlide 'Trace' window.
Try:
(trace AT:ListCondense)
Then run:
(AT:ListCondense '((1 2) (3 (4 5))))
In the vlide 'Trace' window you can see all recursive calls and their results:
Saisie (AT:LISTCONDENSE ((1 2) (3 (4 5))))
  Saisie (AT:LISTCONDENSE (1 2))
    Saisie (AT:LISTCONDENSE 1)
    Résultat:  (1)
    Saisie (AT:LISTCONDENSE (2))
      Saisie (AT:LISTCONDENSE 2)
      Résultat:  (2)
      Saisie (AT:LISTCONDENSE nil)
      Résultat:  nil
    Résultat:  (2)
  Résultat:  (1 2)
  Saisie (AT:LISTCONDENSE ((3 (4 5))))
    Saisie (AT:LISTCONDENSE (3 (4 5)))
      Saisie (AT:LISTCONDENSE 3)
      Résultat:  (3)
      Saisie (AT:LISTCONDENSE ((4 5)))
        Saisie (AT:LISTCONDENSE (4 5))
          Saisie (AT:LISTCONDENSE 4)
          Résultat:  (4)
          Saisie (AT:LISTCONDENSE (5))
            Saisie (AT:LISTCONDENSE 5)
            Résultat:  (5)
            Résultat:  nil
          Résultat:  (5)
        Résultat:  (4 5)
        Résultat:  nil
      Résultat:  (4 5)
    Résultat:  (3 4 5)
    Résultat:  nil
  Résultat:  (3 4 5)
Résultat:  (1 2 3 4 5)
Here's another way for the same task.
The code isn't so concise but may run a little faster because of less recursive calls and the use of 'cons' instead of 'append' (which is more expansive).
The main function: gc:flatlist uses an auxiliary recursive function: foo.
foo is 'tail recursive' (AFAIK AutoLISP do not optimize tail recursion, but many othe functional languages as F# do) and uses an accumilator (acc) to store the result (in reverse order due to the use of cons).
foo requires two arguments: the list to be processed (lst) and the the list to be returned (acc).
The fuction first evaluates if lst is not nil (empty list)
- if so, calls foo passing it the list tail (cdr) as first argument and, for the second argument, evaluates if the list head (car) is an atom or a list.
-- if it's an atom, just had it to the top of the current accumulator
-- if it's a list, calls foo passing it this list and the current accumulator
- if the list is empty, returns the accumultator
gc:flatlist calls foo passing it the list to process and an empty list as accumulator and reverses the returned list.
(defun gc:flatlist (lst / foo)
  (defun foo (lst acc)
    (if lst
      (foo
(cdr lst)
(if (atom (car lst))
  (cons (car lst) acc)
  (foo (car lst) acc)
      acc
  (reverse (foo lst nil))
Tracing the 'foo' subfunction with the same list as upper:
Saisie (FOO ((1 2) (3 (4 5))) nil)
  Saisie (FOO (1 2) nil)
    Saisie (FOO (2) (1))
      Saisie (FOO nil (2 1))
      Résultat:  (2 1)
    Résultat:  (2 1)
  Résultat:  (2 1)
  Saisie (FOO ((3 (4 5))) (2 1))
    Saisie (FOO (3 (4 5)) (2 1))
      Saisie (FOO ((4 5)) (3 2 1))
        Saisie (FOO (4 5) (3 2 1))
          Saisie (FOO (5) (4 3 2 1))
            Saisie (FOO nil (5 4 3 2 1))
            Résultat:  (5 4 3 2 1)
« Reply #4 on: May 09, 2011, 07:36:02 AM »
be careful guys :)
One could argue it returns the correct result since nil = empty list, i.e.:
(LM:Flatten '((1 2) (3 nil 4)))  ==  (LM:Flatten '((1 2) (3 ( ) 4)))  ==  '(1 2 3 4)
 :evil:
VovKa
  • Ukraine
« Reply #5 on: May 09, 2011, 08:27:15 AM »
one could argue that nil = empty atom i.e.:
(atom nil):)
gile
  • Marseille, France
« Reply #6 on: May 09, 2011, 08:35:25 AM »
As is, the code I posted consider nil as an atom.
To consider nil as an empty list (and remove it from the result), just replace:
(if (atom (car lst)) ...)
with:
(if (and (car lst) (atom (car lst))) ...)
« Reply #7 on: May 09, 2011, 08:53:04 AM »
I've reached the age where the happy hour is a nap. (°ż°)
« Reply #8 on: May 09, 2011, 09:02:21 AM »
Should dotted pairs be considered also?
_$ (AT:ListCondense '((1 . 2) (3 (4 5))))
(1 2 3 4 5)
_$ (LM:Flatten '((1 . 2) (3 (4 5))))
(1 2 3 4 5)
_$ (gc:flatlist '((1 . 2) (3 (4 5))))
; error: bad argument type: consp 2
« Reply #9 on: May 09, 2011, 09:06:05 AM »
A variant of mine to consider nil as an 'empty atom':
(defun LM:Flatten ( l )
  (if (atom l) (list l)
    (append (LM:Flatten (car l)) (if (cdr l) (LM:Flatten (cdr l))))
_$ (LM:Flatten '((1 . 2) (3 (4 nil 5))))
(1 2 3 4 nil 5)
alanjt
  • Standby for witty remark...
« Reply #10 on: May 09, 2011, 09:30:57 AM »
Not at all. I completely forgot about that thread. That's funny that we have almost the method, you just test with atom and I used listp. LoL
Dropbox
gile
  • Marseille, France
« Reply #11 on: May 09, 2011, 09:38:27 AM »
This one deals with dotted pairs too.
    (if lst
      (foo
(if (listp (cdr lst))
  (cdr lst)
  (list (cdr lst))
  (foo (car lst) acc)
      acc
chlh_jd
« Reply #12 on: May 09, 2011, 12:34:35 PM »
Nice ALL , I suggest do not expand a dotted pair consisting because it has no practical significance .
Here's a function to get all combinations which like a reverse process .
(defun powerset (s / foo)
  (defun foo (p s)
    (if s
      (foo (append (mapcar (function (lambda (x)
      (cons (car s) x)
  p
  p
  (cdr s)
      p
  (reverse (foo (list nil) s))
(powerset (list 1 2 3))returns
((1 2 3) (1 2) (1 3) (1) (2 3) (2) (3) nil)
Jeff H
« Reply #13 on: May 12, 2011, 03:11:50 PM »
Thanks for all the replies,
Is this how you break down the problems???
You can recieve a empty list, atom, or sublist.
Terminating case:
A empty list return nil
Recursive cases:
1. You recieve a atom then add to begining of list then recursivley call function with rest of the list
2. You recieve a sublist then recursivley append the first to the rest of list.
(defun LispThingy (lst)
  (if lst
        ;; Check to see if atom and if so put it at the
;;the front and recursivley call on rest of the list
((atom (car lst))
     (cons (car lst) (LispThingy (cdr lst)))
        ;; If it is a sublist recursivley append first item to
        ;; to recursivley called on rest of the list
((append (LispThingy (car lst)) (LispThingy (cdr lst)))
At first I was using cons in last recursive case and it just re-built list(I am sure you know that)
Using same breakdown to count the number of atoms
Terminating case:
A empty list return 0
Recursive cases:
1. You recieve a atom then add 1 to recursive call with rest of the list
2. You recieve a sublist then add the recursive call with the first to the recursive call with rest of list.
(defun CountAtoms ( lst )
        ((null lst) 0)
        ((atom (car lst))
   (+ 1 (CountAtoms (cdr lst)))
        (T ( + (CountAtoms (car lst))(CountAtoms (cdr lst)))
In the link Cab provided I noticed the code looked very similar to this which I picked up same form or layout from here http://art2.ph-freiburg.de/Lisp-Course
(defun flatten ( lst )
    ;;  by Doug Broad
        ((null lst) nil)
        ((atom lst) (list lst))
        ((atom (car lst)) (cons (car lst) (Flatten (cdr lst))))
        ((append (Flatten (car lst))(Flatten (cdr lst))))
What case is this for?
« Reply #14 on: May 12, 2011, 03:19:22 PM »
Try yours with a dotted pair.  :wink:
Another example for the 'CountAtoms' function:
  (if (atom lst) 1
    (+ (CountAtoms (car lst)) (if (cdr lst) (CountAtoms (cdr lst)) 0))
« Last Edit: May 12, 2011, 03:33:22 PM by Lee Mac »
