Author Topic: Check my code  (Read 2060 times)
V-Man
  • I exist therefore I am! Finally Retired!
Check my code
« on: May 05, 2011, 12:00:05 PM »
The following code works in 2008 but not in 2010. Any ideas?
  (setq ss (ssget "X" '((0 . "LWPOLYLINE")(8 . "0")(70 . 1))));0=Type , 8=Layer Name , 70=lypolylines closed only
(if (= ss nil)
(alert "There are NO LwPolylines!")
(if ss
  (repeat (setq n (sslength ss))
    (setq n (1- n))
    (command ".-hatch" "p" "HONEY" "140" "" (ssname ss n) "")
AutoCAD 9 - 2023, AutoCADMap 2008 - 2010, Revit 2012 - 2022, Autocad Civil 3D 2023
Re: Check my code
« Reply #1 on: May 05, 2011, 12:13:10 PM »
I don't have 2010 installed, but the code looks ok ...
Have you tried to step through the code one line at a time?
Where does it specifically fail?
V-Man
Re: Check my code
« Reply #2 on: May 05, 2011, 12:19:30 PM »
Here is what I get when stepping through code.
Command: (setq ss (ssget "X" '((0 . "LWPOLYLINE")(8 . "0")(70 . 1))))
<Selection set: 69f3>
Command: (repeat (setq n (sslength ss))
(_> (setq n (1- n))
(_> (command ".-hatch" "p" "HONEY" "140" "" (ssname ss n) "")
(_> )
2D point or option keyword required.
; error: Function cancelled
Specify internal point or [Properties/Select objects/draW boundary/remove
Boundaries/Advanced/DRaw order/Origin/ANnotative]: *Cancel*
gile
  • Marseille, France
Re: Check my code
« Reply #3 on: May 05, 2011, 12:20:07 PM »
Hi, maybe some change in the hatch command option.
Look ŕ the the error reported on command line, it's often helpfull to debug issues with the 'command' function...
(command "_.hatch" "HONEY" "140" "" (ssname ss n) "") works with A2011.
Re: Check my code
« Reply #4 on: May 05, 2011, 12:24:13 PM »
That is exactly what I was going to suggest. It looks like "" might need to be changed to "S"
(command "_.hatch" "HONEY" "140" "S" (ssname ss n) "")
efernal
Re: Check my code
« Reply #5 on: May 05, 2011, 12:29:07 PM »
I allways use
 (setq ss (ssget "X" '((0 . "LWPOLYLINE")(8 . "0")(-4 . "<OR")(70 . 1)(70 . 129)(-4 . "OR>"))))
because plinegen could be 1 instead 0 when then the polyline was created...
e.fernal
gile
  • Marseille, France
Re: Check my code
« Reply #6 on: May 05, 2011, 12:46:19 PM »
I allways use
True, by my side, I'd rather use the "&" operator:
 (setq ss (ssget "X" '((0 . "LWPOLYLINE") (8 . "0") (-4 . "&") (70 . 1))))
V-Man
Re: Check my code
« Reply #7 on: May 05, 2011, 01:32:27 PM »
Thanks to everyone.
The reason I placed a hyphen there in front of the command is for whatever reason, I have 1 machine the code does not work. The code pulls up the hatch dialog box. All other machines the code works fine.
Thanks...
alanjt
  • Standby for witty remark...
Re: Check my code
« Reply #8 on: May 05, 2011, 01:49:30 PM »
If you use -hatch instead of hatch and change your HPSEPARATE variable, you don't have to step through the selectionset.
eg.
(defun c:test (/ ov vl ss)
  (setq ov (mapcar 'getvar (setq vl '("CMDECHO" "HPSCALE" "HPNAME" "HPSEPARATE"))))
  (mapcar 'setvar vl '(0 140. "HONEY" 1))
  (if (setq ss (ssget "_X"
                        (8 . "0")
                        (-4 . "<OR")
                        (70 . 1)
                        (70 . 129)
                        (-4 . "OR>")
    (command "_.-hatch" "_S" ss "" "_A" "_H" "_Y" "" "")
  (mapcar 'setvar vl ov)
Dropbox
