Author Topic: Object ID and Entity  (Read 19501 times)
Helsinki_Dave
Re: Object ID and Entity
« Reply #15 on: May 13, 2011, 09:52:24 AM »
Well, I went back to some code that Jeff put out some place; I thought it might clarify the problem in my head and with you guys.
I believe that what is below will get a single Classification on a single Entity (thanks Jeff) but what I can't understand is how to pull a value off this. I can get as far as finding the ObjectID of exactly one classification on exactly one entity. Very cool.
But now it is not clear to me how to find the assigned value of the Classification. This value is assigned within ACA by the user. As you know, there is no such thing as ObjectID.Value
To be concise - how can I can determine what Category each AecDbSpace has. I can get each AecDbSpace's 'Category', but I can't see where I can read what the actual Category is (eg Building, Block etc)
'many thanks to Jeff H
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports ObjectId = Autodesk.AutoCAD.DatabaseServices.ObjectId
Imports AecDbSrvcs = Autodesk.Aec.DatabaseServices
Imports ArchDbSrvcs = Autodesk.Aec.Arch.DatabaseServices
Imports Autodesk.Aec.PropertyData.DatabaseServices
Imports Autodesk.Aec.DatabaseServices
<Assembly: CommandClass(GetType(MEPExamplesVB.MyCommands))>
Namespace MEPExamplesVB
    Public Class MyCommands
        <CommandMethod("GetSpaceDataVB")> _
        Public Sub GetSpaceDataVB()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim mdlSpace As BlockTableRecord = SymbolUtilityServices.GetBlockModelSpaceId(db).GetObject(OpenMode.ForRead)
                For Each objId As ObjectId In mdlSpace
                    If objId.ObjectClass.Name = "AecDbSpace" Then
                        Dim spce As ArchDbSrvcs.Space = trx.GetObject(objId, OpenMode.ForRead)
                        Dim Ret_TClass As ObjectId = GetClassifID("Category")
                        Dim RetrClassID As ObjectId = Autodesk.Aec.DatabaseServices.ClassificationDefinition.GetClassification(spce, Ret_TClass)
                        'I dont what to do from here. I need to find the value of this Classficiation.
                        Dim spceStyle As ArchDbSrvcs.SpaceStyle = trx.GetObject(spce.StyleId, OpenMode.ForRead)
                        'ed.WriteMessage(String.Format("{0}This Space Name: {1} Area: {2} and is on Stlye?: {3}", _
                        'vbCrLf, spce.Name, spce.Area, spceStyle.Name))
                        Dim spc_ownerID As ObjectId = spce.OwnerId
                        If spc_ownerID.ObjectClass.Name = "AecDbSpace" Then
                            Dim plg As AecDbSrvcs.Polygon = trx.GetObject(spc_ownerID, OpenMode.ForRead)
                        End If
                    End If
                Next
            End Using
        End Sub
#Region "GetClassficationId"
    'we need to
    'takes the AecDbSpace object <id>
    'takes the ClassficiationName <TargClasName>
    'returns the objectid for the targeted classification
    Public Function GetClassifID(ByVal TargClasName As String) As ObjectId
        Dim TargetClassID As ObjectId
                Dim classDefDictionary As New DictionaryClassificationDefinition(db)
            Dim objectIds As Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection = classDefDictionary.Records
            For Each objId As ObjectId In objectIds
                Dim classDef As ClassificationDefinition = trx.GetObject(objId, OpenMode.ForRead)
                If classDef.AppliesToFilter.Contains("AecDbSpace") Then
                        'ed.WriteMessage(vbCrLf & classDef.Name)
                    If classDef.Name = TargClasName Then
                        TargetClassID = classDef.ObjectId
                        'GetClassifications(classDef.ClassificationTree)
                    End If
                End If
            Next
            trx.Commit()
        End Using
        Return TargetClassID
    End Function
#End Region
    End Class
End Namespace
Jeff H
« Reply #16 on: May 13, 2011, 07:57:21 PM »
This is probably not the best way I was just looking at it with AECMgd and the function you were trying to use.
Since the classifications are set with style it seems there will be a easy way to grab it using the style.
Here is what this does it searches the DictionaryClassificationDefinition for "Category" and once found assigns the ObjectID to a variable that will be used as ClassificationDefinition ID.
Then it iterates through model space and if it is a space object it gets the classification using GetClassification() with the space object and ClassificationDefinition ObjectId as its arguments
        <CommandMethod("GetClassificationWithDefinition")> _
        Public Sub GetClassificationWithDefinition()
            Dim classficationDefId As ObjectId
                    If classDef.Name = "Category" Then
                        classficationDefId = classDef.ObjectId
                        Exit For
                    End If
                Next
                        Dim cls As Classification = trx.GetObject(ClassificationDefinition.GetClassification(spce, classficationDefId), OpenMode.ForRead)
                        ed.WriteMessage(String.Format("{0}This Classification is: {1} ", vbCrLf, cls.Name))
                    End If
                Next
                trx.Commit()
            End Using
        End Sub
Output from your drawing
This Classification is: Block
This Classification is: Building
« Last Edit: May 14, 2011, 09:26:48 PM by Jeff H »
Helsinki_Dave
« Reply #17 on: May 16, 2011, 05:17:40 AM »
Gents,
It works.
with many thanks to mohnston, kaefer and special thanks to Jeff H
