Author Topic: Object ID and Entity  (Read 19620 times)
Helsinki_Dave
« on: April 29, 2011, 09:06:19 AM »
Hi, I'm working with ACA and vb.net, could anyone clarify the Object Browser info given below.
Public Shared Function GetClassification(ByVal entity As Autodesk.Aec.DatabaseServices.Entity, ByVal classificationDefinitionId As Autodesk.AutoCAD.DatabaseServices.ObjectId) As Autodesk.AutoCAD.DatabaseServices.ObjectId
     Member of: Autodesk.Aec.DatabaseServices.ClassificationDefinition
Summary:
Get an entity's classification for a specific classification definition.
Parameters:
entity: The entity.
classificationDefinitionId: The classification definition.
Return Values:
Returns an entity's classification for a specific classification definition.
Exceptions:
Autodesk.AutoCAD.Runtime.Exception: Autodesk.AutoCAD.Runtime.Exception.
I think that what this is saying here is that I need to isolate an entity (which the classifcation is attached to - which is my case is a AecDbSpace. Then I need to  add to this isolate the Object ID for the classfication that I'm want to read.
What I'm not sure about is if I have the AecDbSpace ObjectID, how do I turn this into an entity or are they in effect, the same kind of thing. Currently my code is not reading any classfications in the count property (spobj.Classifications.Count) when I just use a straight objectID - where there should be four classfications available on these AecDbSpace objects.
The mere fact that Intellisense gave me the option of writing spobj.Classifications suggests to me that MSExpress considers spobj to be an Entity - so maybe I have got this right - which then would mean that I'm using the wrong Entity to create a collection of classifications from.
Thanks in advance!
#Region "Namespaces"
Imports System
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.Aec.DatabaseServices
Imports Autodesk.Aec.PropertyData.DatabaseServices
Imports DBTransactionManager = Autodesk.AutoCAD.DatabaseServices.TransactionManager
Imports AcadDb = Autodesk.AutoCAD.DatabaseServices
Imports AecDb = Autodesk.Aec.DatabaseServices
Imports AecPropDb = Autodesk.Aec.PropertyData.DatabaseServices
Imports ObjectId = Autodesk.AutoCAD.DatabaseServices.ObjectId
Imports ObjectIdCollection = Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection
Imports AecDbSrvcs = Autodesk.Aec.DatabaseServices
Imports ArchDbSrvcs = Autodesk.Aec.Arch.DatabaseServices
#End Region
Public Class Renumber_Blocks
#Region "Command_Renumber"
    ' <summary>
    ' Command implementation for SetPropertyDataByName.
    ' </summary>
    <Autodesk.AutoCAD.Runtime.CommandMethod("AecPropertySampleMgd", "koe", Autodesk.AutoCAD.Runtime.CommandFlags.Modal)> _
    Public Sub Command_SetPropertyDataByName()
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim psetname As String = "Block_properties"
        Dim pname As String = "Block_ID"
        Dim NewValue As Integer = 0
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Dim tm As AcadDb.TransactionManager = db.TransactionManager
        Dim dbobj As AcadDb.DBObject
        Dim trans As Transaction = tm.StartTransaction()
        Dim bt As BlockTable = tm.GetObject(db.BlockTableId, OpenMode.ForRead, False)
        Dim btr As BlockTableRecord = tm.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead, False)
        Dim id As ObjectId
        For Each id In btr
            If id.ObjectClass.Name = "AecDbSpace" Then
                dbobj = tm.GetObject(id, OpenMode.ForRead, False, False)
                Dim spobj As ArchDbSrvcs.Space = tm.GetObject(id, OpenMode.ForRead, False, False)
                Dim c_classf As ClassificationCollection = spobj.Classifications
                'Dim Clasf_Entity As Autodesk.Aec.DatabaseServices.Entity = CType(tm.GetObject(dbobj, OpenMode.ForRead, True), Autodesk.Aec.DatabaseServices.Entity)
                'Dim target_clasf As Autodesk.Aec.DatabaseServices.ClassificationDefinition = ClassificationDefinition.GetClassification(Clasf_Entity)
                'GetClassification(ByVal entity As Autodesk.Aec.DatabaseServices.Entity, ByVal classificationDefinitionId As Autodesk.AutoCAD.DatabaseServices.ObjectId) As Autodesk.AutoCAD.DatabaseServices.ObjectId
                If c_classf.Count <> 0 Then
                    Dim classf_category As String = c_classf(0).ToString
                End If
                Dim spceStyle As ArchDbSrvcs.SpaceStyle = tm.GetObject(spobj.StyleId, OpenMode.ForRead, False, False)
                If spceStyle.Name = "Block" Then
                    'Dim values As System.Collections.ArrayList = GetValueFromPropertySetByName(psetname, pname, dbobj)
                    'Dim value_unit As AecPropDb.PropertyValueUnitPair
                    'For Each value_unit In values
                    '    Dim currentValue As Object = value_unit.Value
                    '    If Not currentValue Is Nothing Then
                    '        If (currentValue.GetType() Is GetType(Double)) Then
                    Dim trans2 As Transaction = tm.StartTransaction()
                    dbobj.UpgradeOpen()
                    Dim WasChanged As Boolean = SetValueFromPropertySetByName(psetname, pname, dbobj, NewValue)
                    If WasChanged Then
                        ed.WriteMessage(vbCrLf + "Succesfully changed value for objectId = " + id.ToString())
                        ed.WriteMessage(vbCrLf + " New Value = " + NewValue.ToString())
                        NewValue = NewValue + 1
                    Else
                        ed.WriteMessage(vbCrLf + "Failed to change value for objectId = " + id.ToString())
                    End If
                    trans2.Commit()
                    trans2.Dispose()
                    '    End If
                    'End If
                End If
            End If
        Next
        'Next
        trans.Commit()
        trans.Dispose()
    End Sub
#End Region
#Region "GetValueFromPropertySetByName"
    ' <summary>
    ' Returns the value (PropertyValueUnitPair) of a property by name on a given object.
    ' </summary>
    ' <param name="pname">The property name to find on the object.</param>
    ' <param name="dbobj">The object to find the property on. </param>
    ' <returns> An array of the values </returns>
    Public Function GetValueFromPropertySetByName(ByVal psetname As String, ByVal pname As String, ByVal dbobj As AcadDb.DBObject) As ArrayList
        Dim setIds As ObjectIdCollection = AecPropDb.PropertyDataServices.GetPropertySets(dbobj) 'this is almost like a count in that it is counting the number of psets attached to dbobj
        Dim values As System.Collections.ArrayList = New System.Collections.ArrayList() 'this sets up the collector that is returned by the function
        If setIds.Count = 0 Then
            Return values
        End If
        'at this point, where setIds.count <> 0, then we know that we have property set attached
        Dim psId As ObjectId
        Dim local_psetName As String
        'this is searching every property set looking for a single category - no need!! It may only cycle through 3 psets
        For Each psId In setIds
            'opens the propertyset found at psid in setid (where setid is the collection of psets on the dbobj) - so this is cycle one
            Dim pset As AecPropDb.PropertySet = tm.GetObject(psId, OpenMode.ForRead, False, False) 'As AecPropDb.PropertySet
            local_psetName = pset.PropertyIdToName(0)
            Try
                local_psetName = psetname 'this needs to true or else it goes to the catch
                Dim psetdef_id As Integer
                Try
                    'clever this - there is no cycling since pset is a collection and you can hunt down a name directly
                    'here it hunts down the pname
                    psetdef_id = pset.PropertyNameToId(pname)
                    'values is an arraylist since it holds any text or integer date - otherwise the function would have trouble returning a value
                    values.Add(pset.GetValueAndUnitAt(psetdef_id))
                Catch e As Autodesk.AutoCAD.Runtime.Exception
                    ' most likely eKeyNotfound.
                End Try
            End Try
        Next
        Return values
    End Function
#End Region
#Region "SetValueFromPropertySetByName"
    ' <summary>
    ' Sets the values (PropertyValueUnitPair) of a property by name on a given object.
    ' </summary>
    ' <param name="dbobj">The object to set the property on. </param>
    ' <param name="value">The value to set. </param>
    ' <returns> true if succesful, or false otherwise. </returns>
    Public Function SetValueFromPropertySetByName(ByVal psetname As String, ByVal pname As String, ByVal dbobj As AcadDb.DBObject, ByVal NewValue As Object) As Boolean
        Dim findany As Boolean = False
        For Each psId In setIds 'setids is all property sets
            Dim pset As AecPropDb.PropertySet = tm.GetObject(psId, OpenMode.ForWrite, False, False) ' As AecPropDb.PropertySet
            If pset.PropertySetDefinitionName = psetname Then
                Dim pid As Integer 'have to create this object to place the PropertyNameToId somewhere
                pid = pset.PropertyNameToId(pname) 'propertynametoid gives the id for the psetdef
                If (pset.IsWriteEnabled) Then
                    pset.SetAt(pid, NewValue) 'note the SetAt...this is vital where all factors are in place ie <pset> <pid> and <NewValue>
                End If
                findany = True
                'esential findany changes the value of the function
            End If
        Next
        trans.Commit()
        trans.Dispose()
        Return findany
    End Function
#End Region
End Class
« Last Edit: April 29, 2011, 09:18:51 AM by Helsinki_Dave »
mohnston
  • CAD Programmer
Re: Object ID and Entity
« Reply #1 on: April 29, 2011, 01:30:58 PM »
        Dim id As ObjectId
        For Each id In btr
I'm not a VB.NET guy so take this for what it's worth.
One thing I see is that you are using TransactionManger (tm) to get your object.
You should be using the running Transaction (trans) instead.
CAD Programming Solutions
Jeff H
« Reply #2 on: April 30, 2011, 02:33:51 AM »
Not quit sure what you are asking but a Space 'is a' Autodesk.Aec.DatabaseServices.Entity.
It derives(Inheritance) from a Entity.
Have you ever wondered how GetObject returns a DBObject but is used for so many objects?
Jeff H
« Reply #3 on: April 30, 2011, 07:51:31 AM »
Not sure what you after but here is a way to list all the space classifications
        <CommandMethod("Classifications")> _
        Public Sub Classifications()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using trx As Transaction = db.TransactionManager.StartTransaction()
                Dim classDefDictionary As New DictionaryClassificationDefinition(db)
                Dim objectIds As Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection = classDefDictionary.Records
                For Each objId As ObjectId In objectIds
                    Dim classDef As ClassificationDefinition = trx.GetObject(objId, OpenMode.ForRead)
                    If classDef.AppliesToFilter.Contains("AecDbSpace") Then
                        ed.WriteMessage(vbCrLf & classDef.Name)
                        GetClassifications(classDef.ClassificationTree)
                    End If
                Next
                trx.Commit()
            End Using
        End Sub
        Public Sub GetClassifications(ByRef classTree As ClassificationTree)
                If classTree Is Nothing Then
                    Exit Sub
                End If
                If Not classTree.Id.IsNull Then
                    Dim clasfction As Classification = trx.GetObject(classTree.Id, OpenMode.ForRead)
                    ed.WriteMessage("---" & vbCrLf & clasfction.Name)
                End If
                If classTree.Children.Count > 0 Then
                    For Each cTree As ClassificationTree In classTree.Children
                        GetClassifications(cTree)
                    Next
                End If
                trx.Commit()
            End Using
        End Sub
fixo
« Reply #4 on: May 01, 2011, 08:40:20 AM »
Sorry guys,
Hi Jeff,
sorry for off-topic
Can you test on your machine:
use StartOpenCloseTransaction instead of StarTransaction
and remove for this object 'using' and 'commit'
(for my own interest)
Oleg
edit kdub: change textColor
« Last Edit: May 01, 2011, 10:20:09 AM by kdub_bne »
Helsinki_Dave
« Reply #5 on: May 02, 2011, 06:41:25 AM »
Thanks a million for the reply Jeff. (ja hauska nähdä Fixo!)
You've clearly found your way around the ACA API! I didn't manage to find any examples about Classfications in AU or the like, so its great to see one in action. It works fine!
My main gist is to find the classfication of a AecDbSpace object. The name of the classfication is Category. If the Category is "Block", then I move on to further code. This can't be done in VBA as Classifications were not exposed, and as you can see in the attached file, we got around this by pulling the classification value into a Property Set definition then reading it from there. This creates other problems further down the chain.
I had hoped it would be as easy as something like this:
onto which I could use something like GetClassification function and then read it. But the above code returns a big fat zero in the count property..even though there are a number of classfications.
« Last Edit: May 16, 2011, 05:20:40 AM by Helsinki_Dave »
Jeff H
« Reply #6 on: May 02, 2011, 11:15:30 PM »
Sorry guys,
Hi Jeff,
sorry for off-topic
Oleg
The transaction should be passed in instead creating 157 transaction, but will test and see what happens
Jeff H
« Reply #7 on: May 02, 2011, 11:35:13 PM »
I had a little help
Helsinki_Dave
« Reply #8 on: May 03, 2011, 06:47:51 AM »
I had a little help
..aha, a Beetles fan.
I'll post back here when I've found a solution to the reading Classifications on a single entity. Thanks again for your help.
fixo
« Reply #9 on: May 03, 2011, 11:09:51 AM »
Sorry guys,
Hi Jeff,
sorry for off-topic
Oleg
Thanks Jeff,
that make a sense
Oleg
kaefer
« Reply #10 on: May 03, 2011, 06:12:08 PM »
Disregarding my very limited experience in ACA automation, this looks fine to me.
How? To use the classification as a tag in an annotation object would require that very procedure too.
It is, but only for values explicitly supplied; not for defaults by style.
If I get the thrust of your code and your sample drawing correctly, there are 7 spaces that meet your criteria, and, incidentally, one of them has a space style named "Block". You want them renumbered. My approach ain't pretty and is probably written in a sinister language, but here goes:
open Autodesk.AutoCAD.DatabaseServices
open Autodesk.AutoCAD.Runtime
open Autodesk.AutoCAD.Geometry
open Autodesk.AutoCAD.ApplicationServices
open Autodesk.AutoCAD.EditorInput
open Autodesk.Aec.DatabaseServices
open Autodesk.Aec.Arch.DatabaseServices
open Autodesk.Aec.PropertyData.DatabaseServices
[<CommandMethod "koe">]
let koeCmd() =
    let doc = Application.DocumentManager.MdiActiveDocument
    let db = doc.Database
    let ed = doc.Editor
    use tr = db.TransactionManager.StartTransaction()
    let blkPSetName = "Block_properties"
    let blkPName = "Block_ID"
    let catPSetName = "Object_category"
    let catPName = "Category"
    let pSetDefs = new DictionaryPropertySetDefinitions(db)
    let tryGetAt pSetName =
        if pSetDefs.Has(pSetName, tr) then pSetDefs.GetAt pSetName
        else ObjectId.Null
    let blkPSetDefId = tryGetAt blkPSetName
    let catPSetDefId = tryGetAt catPSetName
    if blkPSetDefId.IsNull || catPSetDefId.IsNull then
        ed.WriteMessage(
            "\nEither PropertySetDefinition {0} or PropertySetDefinition {1} missing from drawing. ",
            blkPSetName, catPSetName )
    else
        let bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead, false) :?> BlockTable
        let btr = tr.GetObject(bt.[BlockTableRecord.ModelSpace], OpenMode.ForRead, false) :?> BlockTableRecord
        let mutable newValue = 0
        for oid in btr do
            if oid.ObjectClass.Name = "AecDbSpace" then
                let spc = tr.GetObject(oid, OpenMode.ForRead, false, false) :?> Space
                let tryGetPSetId pSetDefId =
                    try PropertyDataServices. GetPropertySet(spc, pSetDefId) with _ -> ObjectId.Null
                let blkPSetId = tryGetPSetId blkPSetDefId
                let catPSetId = tryGetPSetId catPSetDefId
                if blkPSetId.IsNull || catPSetId.IsNull then
                    ed.WriteMessage(
                        "\n{0} has no Property Set {1} or {2}. ",
                        spc.Name, blkPSetName, catPSetName )
                else
                    let blkPSet = tr.GetObject(blkPSetId, OpenMode.ForWrite, false, false) :?> PropertySet
                    let catPSet = tr.GetObject(catPSetId, OpenMode.ForRead, false, false) :?> PropertySet
                    let blkPId = blkPSet.PropertyNameToId blkPName
                    let catPId = catPSet.PropertyNameToId catPName
                    let cat = catPSet.GetAt catPId :?> string
                    if cat <> "Block" then
                        ed.WriteMessage("\n{0} has Category {1}. ", spc.Name, cat)
                    else
                        blkPSet.SetAt(blkPId, newValue)
                        ed.WriteMessage(
                            "\nSuccesfully changed value for {0}, new value = {1} ",
                            spc.Name, newValue )
                        newValue <- newValue + 1
    tr.Commit()
Helsinki_Dave
« Reply #11 on: May 09, 2011, 08:41:17 AM »
Thanks for the posting kaefer , brilliant actually. I'll plug this is and see if any lights come on.
Draftek
« Reply #12 on: May 10, 2011, 06:12:34 AM »
My only comment would be - if your going to process that much stuff, you might consider not using a transaction at all. Performance might become an issue.
Helsinki_Dave
« Reply #13 on: May 12, 2011, 08:42:31 AM »
Just thought I should get back to a few of these questions, just in case you thought I'ld gone to sleep.
ACA has this problem when inserting AecDbSpaces via a customised toolbar - in that it automatically attaches every single property set that it can find that is relevant to 'Spaces. This means that you then need a bit of VBA that determines the type of object it is (ie, building, city block, surface etc) as well as checking that every 'Space has the right PropertySet attached (ie if during editing somebody accidentily removed a property set attached ByObject)
That last point is the problem, to check if you have the right PropertySet attached, you need to know what kind of object it is, and to know what kind of object it is, you need to know the Classification ("Category") - BUT, VBA can't read classifications, nor can it read PropertySets that are attached ByStyle. So there's not an immediate automatic answer. You can't just read the stylename since as you build up the options of Classifications (inside site area or not, use of building etc) the stylename becomes irrelevant.
We get around this by first attaching a kind of 'what am i' property set, then using that to direct what the correct PropertySet should be. To blocks go Block _Properties propertyset and to Buildings go Building_Propoerties property set.
I noticed that Kaefers code is in F#.  I'll give it a crack to bring it back to VB but it's looking ugly.
Helsinki_Dave
« Reply #14 on: May 13, 2011, 06:01:23 AM »
I can see that I'm all at sea with this...my question wasn't clear. Apologies for this - I'm not looking to waste anyones time.
Is there a way to find the value of a single classficiation on a single entity (in the file above, an Enity could be a Building or a Cityblock. It appears that I can use the Function that I list below..but I'm struggling. I'll try to use Jeff's kindly donated code to grab a classificationDefinitionId as it appears in the db. Maybe that will work. Thanks in advance for your thoughts.
Summary:
Parameters:
entity: The entity.
Return Values:
