Ok thanks, I will play around with that one.
I had another question though....I have other Lisp routines I wan tto run in this one.
How do I load a Lsp file within one and then run it.
I tryied the...
(command "(load LFD.lsp)" "lfd")
This is the code I use in my macro's (buttons) but I want to run this form a LISP file, sort of a master routine that will run everything at once.
