Author Topic: (Challenge - Advanced)  (Read 8170 times)
whdjr
« on: January 27, 2005, 08:52:35 AM »
This is an advanced challenge (or at least I thought it was).  Please allow 4 hours from the time of this post before submitting your answers.  You may post a comment saying you're finished or you may post a question, but no answers until the buzzer sounds.
Challenge:
Turn a supplied point list (assume it is an even length) into a 2d point list.
Ex. '(1 2 3 4 5 6 7 8 9 10) would become '((1 2) (3 4) (5 6) (7 8) (9 10)).
An application for this would be to take a point list from a lightweight polyline and turn it into a 2d list of coordinates.
Please respect this forum by not posting an answer until the allotted time has expired.
SMadsen
« Reply #1 on: January 27, 2005, 09:10:11 AM »
What does the buzzer sound like?
« Reply #2 on: January 27, 2005, 09:23:56 AM »
Hey, this sounds familiar. Hey Stig werent you and i working somthing like this at one time? (By that i mean, didnt i ask you for code and when you gave me some i claimed it as my own.)
SMadsen
« Reply #3 on: January 27, 2005, 09:34:30 AM »
Quote from: Se7en
.. and when you gave me some i claimed it as my own.
Probably, .. you always do!  :lol:  :lol:
whdjr
« Reply #4 on: January 27, 2005, 09:47:24 AM »
Quote from: SMadsen
I can't do it now because everyone will think the challenge is over.
Quote from: Se7en
Ok you two are not allowed to post your answers because you confessed to already looking at the answers.
MARK!  STIG AND SE7EN ARE CHEATERS!:P
« Reply #5 on: January 27, 2005, 10:18:21 AM »
Well Stig and i (read: Stig) may have already figured this out (read: i claimed it as my own.) but i just created my very own. (Just now) the one we worked on was a little more complicated then this. It was for picking points and creating a list on the fly... but anyways
I have mine ready.
Total of 5 lines of code. (Its meats your criteria exactly.)
Re: (Challenge - Advanced)
« Reply #6 on: January 27, 2005, 11:01:49 AM »
Quote from: whdjr
I have mine that will accept a list returned from LWPlines or 3dPlines..... :D
whdjr
« Reply #7 on: January 27, 2005, 11:13:24 AM »
Quote from: Jeff_M
Quote from: whdjr
That means you didn't follow directions. :?
Show Off!  :wink:
« Reply #8 on: January 27, 2005, 11:14:32 AM »
Hey, no way Jeff. Thats cheeting! You have to meet the criteria not the application!?
I demand a recount!!
:P
« Reply #9 on: January 27, 2005, 11:28:45 AM »
Quote from: whdjr
Show Off!  :wink:
Wait, the directions stated:
Quote from: whdjr
So if mine takes a list and converts it to a 2d point, then it's just as requested.....it's just that mine can ALSO do 3d.... :D
whdjr
« Reply #10 on: January 27, 2005, 11:32:18 AM »
So what are using to determine if an even numbered list is 2d or 3d?
whdjr
« Reply #11 on: January 27, 2005, 11:50:18 AM »
I have to go to an AIA luncheon, so if I fall asleep and don't get back in time you guys go ahead and post your code when the buzzer hits 4 hours.
SMadsen
« Reply #12 on: January 27, 2005, 01:00:06 PM »
Gotta catch a train and I think the buzzer went (?) .. so:
(defun pairup (lst)
  (cond ((null lst) nil)
        ((cons (list (car lst) (cadr lst)) (pairup (cddr lst))))
(setq alst '(1 2 3 4 5 6 7 8 9 10))
(pairup alst) -> ((1 2) (3 4) (5 6) (7 8 ) (9 10))
« Reply #13 on: January 27, 2005, 01:02:11 PM »
Ahh recursion. I went the direct route.
;;; Command: (setq alst '(1 2 3 4 5 6 7 8 9 0))
;;; (1 2 3 4 5 6 7 8 9 0)
;;; Command: (lstoftwo alst)
;;; ((1 2) (3 4) (5 6) (7 8) (9 0))
;;; Command: (setq alst '(1 2 3 4 5 6 7 8 9))
;;; (1 2 3 4 5 6 7 8 9)
;;; ((1 2) (3 4) (5 6) (7 8) (9 nil))
(defun lstoftwo (x / nlst)
  (while (> (length x) 0)
     (setq nlst (cons (list (car x) (cadr x)) nlst))
       (setq x (cddr x))) (reverse nlst) )
whdjr
« Reply #14 on: January 27, 2005, 02:01:49 PM »
Very Good.
I also went the recursive route.
(defun lst->2dlst (lst / a b)
  (setq a (list (car lst) (cadr lst)))
  (if (setq b (cddr lst))
    (append (list a) (lst->2dlst b))
    (list a)
