Author Topic: Why is vl-directory-files crashing the strcat?  (Read 3018 times)
Krushert
  • FREE BEER Tomorrow!!
« on: April 25, 2011, 09:39:44 PM »
Why is results from vl-directory-files crashing the (strcat UserPath2 "\\" DCTCUST-list)
(setq DCTCUST-list (vl-directory-files UserPath2  "*.cus" 1))
(vl-file-rename (strcat UserPath2 "\\" DCTCUST-list) DictFilePath)
Command: TEST
; error: bad argument type: stringp ("TED KRUSH SpellDict - Copy.cus")
; reset after error
Command:
alanjt
  • Standby for witty remark...
Re: Why is vl-directory-files crashing the strcat?
« Reply #1 on: April 25, 2011, 11:20:49 PM »
vl-directory-files returns a list of files within the specified directory, not a string.
Dropbox
Krushert
« Reply #2 on: April 26, 2011, 09:48:47 AM »
So I need to convert it to a string. *sigh*
Thanks.
alanjt
« Reply #3 on: April 26, 2011, 09:51:37 AM »
Thanks.
No, it will return a list of strings. It could return a list with 1 item or 100 items.
Dropbox
« Reply #4 on: April 26, 2011, 09:52:07 AM »
Consider 'car' perhaps, or 'mapcar' to process the whole list.
Krushert
« Reply #5 on: April 26, 2011, 09:59:49 AM »
Thanks.
That is is just it.  There should be just one item being returned.  But I suppose I should throw in some error trap if there happens to be more than one item.  I will make a note to do that in the second wave.  Right now it is just to get it working.
Will do.  Thanks.  And IIRC you did a tutorial on working with list.  I will go check that out.
Thanks again Guys.
alanjt
« Reply #6 on: April 26, 2011, 10:01:05 AM »
There you go, listen to Lee; he likes to talk more than I do. :-D
Dropbox
Krushert
« Reply #7 on: April 26, 2011, 11:20:49 AM »
Hey? What?  I thought I was listening you too.  Sooooorrrrrrreeeeeee!  :-P :-)
I got it working with car function.  It took me a little bit of trial and error.  I can not say that Autodesk help files are of much help on this subject.  But then I realize that vl-directory-files is the right function.  :oops:  I think vl-file-copy might be better suited when it comes to my users.  I am not sure, I will have to look into it some more.
alanjt
« Reply #8 on: April 26, 2011, 11:22:40 AM »
You were/are. I wasn't pissed, I was mostly laughing at my ambiguity.
Dropbox
