Author Topic: How do I find the location of MyDocuments folder?  (Read 11883 times)
alanjt
  • Standby for witty remark...
Re: How do I find the location of MyDocuments folder?
« Reply #15 on: April 19, 2011, 10:05:32 PM »
I'd probably go with the SpecialFolders object
Why, is the system variable too simple?
Dropbox
Krushert
  • FREE BEER Tomorrow!!
« Reply #16 on: April 20, 2011, 06:17:42 AM »
 :-D  Wow! you guys ran with this one.  :-D
Not for me it isn't.  It curls up very nicely inside my simple mind.
The more complex methods is for more complex minds.
 :-D :-D
Thanks again guys.
laidbacklarry
« Reply #17 on: April 20, 2011, 08:14:53 AM »
Nostalgia? maybe.
On the other hand... there are some things you can do faster and easier in DOS. Our application includes a simple command - DOS - which opens a DOS window. If I can get a user to DOS, I can tell him/her Type this, Type that... and before you know it, we've done what needs to be done. I tell a user to open "Windows Explorer" and they almost always start "Internet Explorer"...
« Reply #18 on: April 20, 2011, 08:46:21 AM »
I am a comand prompt junkie (well that comes froms being a *nix user though too).
AutoCAD conversations:
"type in: sh <enter> <enter> ..."
Krushert
« Reply #19 on: April 20, 2011, 08:58:41 AM »
Okay next question.
LOCALROOTPREFIX gives me this = "C:\\Users\\Ted Krush\\AppData\\Local\\Autodesk\\ACA 2010\\enu\\"
Is there something out there that will get me this = "C:\\Users\\Ted Krush\\AppData\\Local  <=== back  slashes can be present or not.
« Reply #20 on: April 20, 2011, 09:03:20 AM »
getenv TMP or TEMP may get you close  :wink:
« Reply #21 on: April 20, 2011, 09:14:33 AM »
What Lee said:
(substr (getenv "Temp") 1 (vl-string-search "\\Temp" (getenv "Temp")))
alanjt
« Reply #22 on: April 20, 2011, 09:18:00 AM »
FYI: That will abbreviate the folder names if they are too long.
eg.
Command: (getenv "Tmp")
"C:\\Users\\ATHOMP~1\\AppData\\Local\\Temp"
Dropbox
Krushert
« Reply #23 on: April 20, 2011, 11:20:18 AM »
What Lee said:
(substr (getenv "Temp") 1 (vl-string-search " \\Temp"(getenv "Temp")))
Okay how did you do that?  and by that I mean tell to "delete" the " \\Temp" from the string?
The vl-string-search function searches the string not deletes from my reading the help file on vl-string-search.
<sigh> I wish the help was little more dynamic when it comes to holding my hand.
alanjt
« Reply #24 on: April 20, 2011, 11:22:36 AM »
Look at the substr in the beginning of the call.
Dropbox
« Reply #25 on: April 20, 2011, 11:26:39 AM »
Look at the SUBSTR function (which does the trimming)
(vl-string-search " \\Temp"(getenv "Temp")) returns a number where the string "\\Temp" starts.
SUBSTR starts at a point in a string (in this case the beginning (1)) then stops at the beginning of "\\Temp" which was returned by the vl-string-search.
Maybe this will help you see it:
(setq string (getenv "Temp"))
;;If "\\Temp" is found in string
(if (setq p (vl-string-search "\\Temp" string))
  ;;Trim the string
  (substr string 1 p)
  ;;Else return the full string
  string
« Last Edit: April 20, 2011, 11:31:32 AM by ronjonp »
Krushert
« Reply #26 on: April 20, 2011, 11:37:01 AM »
Ahh the search is returning numerical position of where \\Temp starts in the string.
Me gets it now.  Thanks again.
« Reply #27 on: April 20, 2011, 11:53:43 AM »
:) Glad to help out.
Krushert
« Reply #28 on: April 26, 2011, 04:02:06 PM »
How do I trim the right side of a sting to certain known character with unknown characters in between.
"\\\\server\\users\\ted krush\\my documents\\Folder name varies\\ To be trimmed but folder name also varies \\"
I can not get either vl-string-right-trim or Substr functions to fit.
I am trying to slice it and dice it using this ginzo code and it not working.
  (setq OldUserFolder1 (vl-filename-directory (findfile "acad.pgp")))
  (setq OldUserFolder2 (vl-string-right-trim "\\" OldUserFolder1))
A little push please?
« Reply #29 on: April 26, 2011, 04:50:22 PM »
If I understand the question look into this:
(vl-string-position char-codestr [start-pos [from-end-p]])
Arguments
char-code
The integer representation of the character to be searched.
str
The string to be searched.
start-pos
The position to begin searching from in the string (first character is 0); 0 if omitted.
from-end-p
If T is specified for this argument, the search begins at the end of the string and continues backward to pos
