Author Topic: Viewport layer overrides? Where is the data  (Read 2119 times)
mkweaver
« on: April 19, 2011, 10:36:30 AM »
I know where to find the information for layers frozen in viewports.  How about layers with other overrides (color/lineweight/linetype)?
Thanks,
Mike
Re: Viewport layer overrides? Where is the data
« Reply #1 on: April 19, 2011, 10:37:58 AM »
It's in the extension dictionary of the layers.
mkweaver
« Reply #2 on: April 19, 2011, 11:36:45 AM »
Thanks for the reply Tim.  I haven't done much with extension dictionaries - time to do some studying.
Mike
« Reply #3 on: April 19, 2011, 11:46:57 AM »
This may help you in your quest:
http://www.theswamp.org/index.php?topic=35274.0
« Reply #4 on: April 19, 2011, 12:04:23 PM »
Here are some codes I use to dig into entity data.  If you want to step through layer 0, then call like
(ChaseEntData (tblobjname "layer" "0"))
(defun c:ChaseEntData (/ Sel)
    (if (setq Sel (entsel))
        (ChaseEntData (car Sel))
(defun ChaseEntData (Ent / DiaRtn DataList)
    (while
        (and
            Ent
            (setq DiaRtn
                (SingleSelectWide
                    (mapcar
                        '(lambda (x / tempType)
                                (and
                                    (equal (type (cdr x)) 'ENAME)
                                    (setq tempType (cdr (assoc 0 (entget (cdr x)))))
                                (strcat
                                    (vl-princ-to-string (car x))
                                    "\t\t"
                                    (vl-princ-to-string (cdr x))
                                    tempType
                                (strcat
                                    "\t\t"
                        (setq DataList (entget Ent '("*")))
                    "Select entity name to chase."
                    nil
        (if (not (equal (type (setq Ent (cdr (nth (car DiaRtn) DataList)))) 'ENAME))
            (setq Ent nil)
(defun SingleSelectWide (Listof Message Toggle / DiaLoad tmpStr tmpTog tmpList)
(setq DiaLoad (load_dialog "MyDialogs.dcl"))
(if (new_dialog "SingleSelectWide" DiaLOad)
(start_list "listbox" 3)
(mapcar 'add_list Listof)
(end_list)
(if Message
(set_tile "text1" Message)
(if (not Toggle)
(mode_tile "toggle1" 1)
(action_tile "listbox"
"(if (= $reason 4)
(setq tmpStr (get_tile \"listbox\"))
(if Toggle
(setq tmpTog (get_tile \"toggle1\"))
(done_dialog 1)
(action_tile "accept"
"(progn
(if Toggle
(done_dialog 1)
(action_tile "cancel" "(done_dialog 0)")
(if (= (start_dialog) 1)
(setq tmpList (read (strcat "(" tmpStr ")")))
(if (= tmpTog "1")
(cons T tmpList)
tmpList
mkweaver
« Reply #5 on: April 19, 2011, 04:02:30 PM »
I stand in awe.
Thanks for the links and code.  It looks like everything I might need will be covered.
Mike
