Author Topic: Get the key value of the keyboard and mouse with gread  (Read 4299 times)
xiaxiang
« on: April 18, 2011, 09:29:52 PM »
I have a code like that:
(setq roop t)
(while roop
    (princ "\n Shift+RightMouse=... / RightMouse=... / LeftMouse=... /Space;Enter=Quit:")
    (setq gr (grread nil 4 2)
  ga (car gr)
  gb (cadr gr))
      ((= ga 3);;;LeftMouse
      ((member gr '((2 13)(2 32))) ;; "" Space or Enter
(setq roop nil))
      ((=  ga 11) ;;;RightMouse
      ((member gr '((11 1000))) ;;;Shift+RightMouse
These are not all correct.For example , Sometimes (=  ga 11) represent  RightMouse, other times (=  ga 25).
So I give My question: How can I get the key value of the keyboard and mouse with gread?
I need all the keyboard value(as a,z,etc),mouse value(as  LeftMouse, RightMouse and Wheel) and combination value (as Shift+RightMouse).
I want to know whether This can be achieved or not.
This topic didn't teach me to do that:
http://www.theswamp.org/index.php?topic=12813.0
Sorry for my bad ability of Expression.
pBe
Re: Get the key value of the keyboard and mouse with gread
« Reply #1 on: April 19, 2011, 03:25:25 AM »
A fine example by Lee Mac
(defun c:test ( / pt gr code data )
  ;; Define function, localise variables.
    ;; If the following returns non-nil:
    (setq pt (getpoint "\nSpecify First Point: "))
    ;; Prompt for a point (the base point)
      ;; Wrap the following statements as one expression
      ;; to be supplied to the IF function as its 'then' argument.
      (princ "\nSpecify Next Point: ")
      ;; Print the above message to the user
      (while
        ;; While the following test expression returns true
          ;; Wrap the following expressions into one expression
          ;; so that it may be passed to the While function as its
          ;; test expression argument.
          ;; Note that *not* all of the expressions within the progn
          ;; statement need to return non-nil, the progn expression
          ;; will only return the value of the last evaluated expression
          ;; this value will then be used to control the While loop.
          [color=blue](setq gr (grread t 15 0)
            ;; Monitor user input for every pass of the While loop
            ;; GrRead pauses until it detects user input (you can test
            ;; this by executing a single instance of it at the command
            ;; line), then, when user input is detected it returned a list
            ;; encoding type of input and any data associated with that input.[/color]
 code (car gr)
       [color=blue]     ;; Get the type of input (e.g. 3=left-click, 5=drag, 2=keyboard...)[/color]
               data (cadr gr)
            ;; Get the value associated with that type of input
            ;; Still inside the progn expression (nothing as yet has been passed
            ;; to the While function.
            ;; Here we check the user input detected:
             [color=blue] (= 5 code) ;; Mouse has been dragged [/color]
              (redraw)
              ;; Clear the screen
              (grdraw  pt data -1)
              ;; Draw a vector from the base point to the current mouse position.
              ;; Vector is drawn in XOR ink (since colour is -1).
              ;; Note that both pt and data are expressed relative to the current UCS
              ;; and that grdraw takes points expressed in UCS.
              t
              ;; At this point, a condition in the COND stament has been evaluated,
              ;; so no other COND statements will be evaluated and whatever is returned
              ;; by this COND expression will be passed to the While loop as a test
              ;; condition.
              ;; We wish to stay in the loop at this point, so we pass a 't' since
              ;; grdraw returns nil.
             [color=blue] (= 2 code) ;; Keyboard has been pressed[/color]
              (alert (strcat "You pressed: " (chr data)))
              ;; Provide an Alert detailing the pressed key.
              t
              ;; Stay in the Loop.
              [color=blue](= 3 code) ;; Left-Click of the mouse[/color]
              (entmakex
                (list
                  (cons 0 "LINE")
                  (cons 10 (trans pt   1 0))
                  (cons 11 (trans data 1 0))
              ;; Create a line from the base point to the clicked point.
              ;; As previously mentioned, both 'pt' and 'data' are expressed
              ;; relative to the current UCS; however, the start and end points
              ;; in the DXF data for a LINE are expressed relative to the WCS.
              ;; Hence a transformation is required, which can be accomplished using
              ;; the trans function.
              (setq pt data)
              ;; Set the new base point as the endpoint of the last line created.
              ;; No need for an explicit 't' here, since the above will always
              ;; return a non-nil value and hence keep us in the loop.
        ) ;; End Progn
        ;; Note that the While function only has a 'test' expression.
        ;; No other statements are executed within the while loop.
  (redraw) (princ)
  ;; Finally, clear the screen and exit cleanly.
I could have sworn i've see a table for values on what key was pressed somewhere... cant quite put my finger on that. but it would be nice to code though  :-)
BTW: 25 for mouse right click
EDIT: see attached file
« Last Edit: April 19, 2011, 03:47:20 AM by pBe »
xiaxiang
« Reply #2 on: April 19, 2011, 05:05:33 AM »
Thanks pBe!
I will read this example Seriously.
It's 11 for mouse right click here.Optical Mouse.Very strange!
BTW:your attached file is downloading slowly for the reason of slow Network speed.
Thanks! It's very useful for me!!!  :angel:
gile
  • Marseille, France
« Reply #3 on: April 19, 2011, 05:09:48 AM »
The value returned for a right click (11 or 25) depends on the SHORTCUTMENU sysvar settings.
pBe
« Reply #4 on: April 19, 2011, 05:19:46 AM »
Thank you for that clarification  gile
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #5 on: April 19, 2011, 05:20:06 AM »
Excellent investigation gile !
Called Kerry in my other life
I live at UTC + 13.00
xiaxiang
« Reply #6 on: April 19, 2011, 05:29:06 AM »
Hi pBe
Any suggestion about Key combination (as Shift+Right mouse click)?
xiaxiang
« Reply #7 on: April 19, 2011, 05:32:36 AM »
Thank you Gile  :-)  :-)  :-)
pBe
« Reply #8 on: April 19, 2011, 05:36:56 AM »
Hi pBe
Not sure.   :|
Anyhoo. heres a more complete list for character code
http://en.wikipedia.org/wiki/ASCII
Maybe you can find it there  :-)
xiaxiang
« Reply #9 on: April 19, 2011, 05:52:52 AM »
Hi pBe
Thanks. I will research it . :-)
« Reply #10 on: April 19, 2011, 07:15:21 AM »
Hi
I don't think Shift / Ctrl can be detected using GrRead, instead you can perhaps use (acet-sys-shift-down) / (acet-sys-control-down).  For some other keys, (acet-sys-keystate <ascii>) may be used. - although consider these are Express Tools functions.
Lee
« Last Edit: April 19, 2011, 07:20:46 AM by Lee Mac »
alanjt
  • Standby for witty remark...
« Reply #11 on: April 19, 2011, 08:11:43 AM »
Hi
Lee
X2
Dropbox
xiaxiang
« Reply #12 on: April 19, 2011, 08:39:36 PM »
Sad...
Must use acet functions...
Using Express Tools support functions can lead to some error in the client's computer that has not been installed Express,so I must explain and clarify to the user of program.
Thanks anyway ,Lee. :-)
And I really get Shift+Right mouse click using the code like my list in this topic:
And if Ctrl+RightMouse?
