Author Topic: Simple Example for reactor needed?  (Read 8456 times)
HasanCAD
« on: April 15, 2011, 12:18:10 PM »
I am searching for simple example for reactor.
How to move an object related to another object?
Re: Simple Example for reactor needed?
« Reply #1 on: April 15, 2011, 02:14:53 PM »
Should be something here:
-----------  Reactor  ----------------
http://www.theswamp.org/index.php?topic=26380.0  Length Rector by CAB
http://www.theswamp.org/index.php?topic=8710.0  Object Reactor
http://www.theswamp.org/index.php?topic=10248.0  AreaReactor Thread
http://www.theswamp.org/index.php?topic=22733.msg273953#msg273953  Layer Create Reactor CAB
http://www.theswamp.org/index.php?topic=28604.msg349372#msg349372
http://www.theswamp.org/index.php?topic=30943.0  LeeMac text2object
-----------   Close DWG Reactors  -----------
http://www.theswamp.org/index.php?topic=12986.msg157991#msg157991
http://www.theswamp.org/index.php?topic=12986.msg158077#msg158077
http://www.theswamp.org/index.php?topic=26752.msg322500#msg322500
« Reply #2 on: April 15, 2011, 03:59:21 PM »
An example of using an Object Reactor to link a Circle and Text object, original code by Kerry, all credit to him.
;; Original Code by Kerry:
;; http://www.theswamp.org/index.php?topic=33215.msg386624#msg386624
;; Modified by Lee Mac to serve as an example.
(defun c:test ( / acdoc acspc p1 rad vla-circle vla-text ) (vl-load-com)
  (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object))
        acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
  (if (or *ex:circle->text *ex:text->circle)
      (foreach reactor '(*ex:circle->text *ex:text->circle)
        (if (boundp reactor) (vlr-remove (eval reactor)))
        (set reactor nil)
      (princ "\n--> Reactors Disabled.")
      (and
        (setq p1  (getpoint "\nSpecify Point for Circle: "))
        (setq rad (getdist p1 "\nSpecify Circle Radius: "))
        (setq p1 (vlax-3D-point (trans p1 1 0)))
        (setq VLA-Circle (vla-addCircle acspc p1 rad))
        (vla-put-color VLA-Circle acgreen)
        (setq VLA-Text (vla-addText acspc (rtos rad 2 2) p1 (* rad 0.3)))
        (vla-put-color VLA-Text acyellow)
        (vla-put-alignment VLA-Text acalignmentmiddlecenter)
        (vla-put-textalignmentpoint VLA-Text p1)
        (setq *ex:circle->text (vlr-object-reactor (list VLA-Circle) VLA-Text '((:vlr-modified . ex:circle->text))))
        (setq *ex:text->circle (vlr-object-reactor (list VLA-Text) VLA-Circle '((:vlr-modified . ex:text->circle))))
(defun ex:circle->text ( owner reactor params )
  (ex:update-text-for-circle (vlr-data reactor) owner)
(defun ex:text->circle ( owner reactor params )
  (ex:update-circle-for-text (vlr-data reactor) owner)
(defun ex:update-text-for-circle ( VLA-Text VLA-Circle / rad p1 )
    (and
      (vlax-write-enabled-p  VLA-Text)
      (vlax-read-enabled-p VLA-Circle)
      (not (vlax-erased-p   VLA-Text))
      (not (vlax-erased-p VLA-Circle))
      (setq rad (vla-get-radius VLA-Circle))
      (setq p1  (vla-get-center VLA-Circle))
      (vla-put-insertionpoint VLA-Text p1)
      (vla-put-height VLA-Text (* rad 0.3))
      (vla-put-textstring VLA-Text (rtos rad 2 2))
(defun ex:update-circle-for-text ( VLA-Circle VLA-Text / rad p1 )
    (and
      (vlax-write-enabled-p VLA-Circle)
      (vlax-read-enabled-p    VLA-Text)
      (setq rad (atof (vla-get-textstring VLA-Text)))
      (setq  p1 (vla-get-textalignmentpoint VLA-Text))
      (not (eq rad (vla-get-radius VLA-Circle)))
      (> rad 0.0)
      (vla-put-Radius VLA-Circle rad)
      (vla-put-center VLA-Circle p1)
Type 'test' to start and stop the reactors.
« Last Edit: August 04, 2011, 03:57:05 PM by Lee Mac »
barc
« Reply #3 on: April 16, 2011, 12:57:51 PM »
That's cool, Thanks for the legwork Alan
« Reply #4 on: April 16, 2011, 01:26:56 PM »
You're welcome.
More here http://www.theswamp.org/index.php?topic=24700.msg359343#msg359343
I need to update the list though.
HasanCAD
« Reply #5 on: April 18, 2011, 08:26:30 AM »
I cant get whats :vlr-modified for?
(defun c:reac () (vl-load-com)
  (setq [color=blue]ent1VL[/color] (vlax-ename->vla-object (car (entsel)))) ; select a block
  (setq [color=brown]ent2VL[/color] (vlax-ename->vla-object (car (entsel)))) ; select a block
  (setq *gv-reactor-circle->text (vlr-object-reactor
   (list [color=blue]ent1VL[/color])
   '((:vlr-modified . xxx))
The relation is the block ent2VL moves refering to block ent1VL.
Please be bear with silly
« Reply #6 on: April 18, 2011, 08:42:14 AM »
:vlr-modified is an event that will trigger the evaluation of the reactor call-back function associated with that event - in your code: 'xxx'.
Take a look at the documentation for the vlr-object-reactor function:
Quote from: VLIDE Help Docs
(vlr-object-reactor owners data callbacks)
Arguments
owners
An AutoLISP list of VLA-objects identifying the drawing objects to be watched.
data
Any AutoLISP data to be associated with the reactor object; otherwise nil if no data.
callbacks
A list of pairs of the following form:
(event-name . callback_function)
where event-name is one of the symbols listed in the "Object Events" table and callback_function is a symbol representing a function to be called when the event fires. Each callback function accepts three arguments:
owner The owner of the VLA-object the event applies to.
reactor_object The VLR object that called the callback function.
list A list of extra data elements associated with the particular event.
Object events
... <snip> ...
:vlr-modified
 The object has been modified. If the modification was canceled, also :vlr-cancelled and :vlr-modifyUndone will be fired.
... <snip> ...
« Reply #7 on: April 18, 2011, 12:35:13 PM »
Another more simple example, linking two blocks at their insertion points:
(defun c:test ( / _select block1 block2 ) (vl-load-com)
  ;; Example by Lee Mac  -  www.lee-mac.com ;;
  (defun _select ( message predicate / selection ) (setq predicate (eval predicate))
    (while
      (progn (setvar 'ERRNO 0) (setq selection (car (entsel message)))
          ( (= 7 (getvar 'ERRNO))
            (princ "\n--> Missed, Try Again.")
          ( (and (eq 'ENAME (type selection)) (not (predicate selection)))
            (princ "\n--> Invalid Object Selected.")
    selection
  (if (or *object-reactor-block1 *object-reactor-block2)
      (foreach reactor '(*object-reactor-block1 *object-reactor-block2)
        (set reactor nil)
      (and
        (setq block1 (_select "\nSelect Block 1: " '(lambda ( x ) (eq "INSERT" (cdr (assoc 0 (entget x)))))))
        (setq block2 (_select "\nSelect Block 2: " '(lambda ( x ) (eq "INSERT" (cdr (assoc 0 (entget x)))))))
      (setq block1 (vlax-ename->vla-object block1)
            block2 (vlax-ename->vla-object block2)
            *object-reactor-block1 (vlr-object-reactor (list block1) block2 '((:vlr-modified . update-block)))
            *object-reactor-block2 (vlr-object-reactor (list block2) block1 '((:vlr-modified . update-block)))
(defun update-block ( block1 reactor params / block2 ) (setq block2 (vlr-data reactor))
    (and
      (vlax-read-enabled-p  block1)
      (vlax-write-enabled-p block2)
      (not (or (vlax-erased-p block1) (vlax-erased-p block2)))
    (foreach property '(insertionpoint rotation xscalefactor yscalefactor zscalefactor)
      (vlax-put-property block2 property (vlax-get-property block1 property))
« Last Edit: August 04, 2011, 03:56:25 PM by Lee Mac »
HasanCAD
« Reply #8 on: April 18, 2011, 12:44:00 PM »
Thanks for great example.
« Reply #9 on: April 18, 2011, 12:48:16 PM »
Just noticed I could combine the callback functions - updated above.
Tharwat
  • Hypersensitive
« Reply #10 on: April 18, 2011, 02:22:41 PM »
Definitely great work Lee .
Thanks a lot .
« Reply #11 on: April 18, 2011, 06:20:50 PM »
Thanks guys, and thanks Kerry for a great example also.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #12 on: April 18, 2011, 07:00:24 PM »
If I was to rework my example I'd change the VLA-variable variable names to something like  ax-variable ( ax for ActiveX)
The use I made of the VLA- prefix can be visually confused with the vl- and vla- function names built into Visual Lisp.
... just an afterthought with hindsight.
Called Kerry in my other life
I live at UTC + 13.00
« Reply #13 on: April 18, 2011, 07:12:40 PM »
A fair point, although with syntax highlighting functions are easy to distinguish  :-)
Aerdvark
« Reply #14 on: April 19, 2011, 01:57:33 AM »
([color=BLUE]defun[/color] c:test ( [color=BLUE]/[/color] _select block1 block2 ) ([color=BLUE]vl-load-com[/color])
  [color=GREEN];;----------------------------------------;;[/color]
  [color=GREEN];; Example by Lee Mac  -  www.lee-mac.com ;;[/color]
  ([color=BLUE]defun[/color] _select ( message predicate [color=BLUE]/[/color] selection ) ([color=BLUE]setq[/color] predicate ([color=BLUE]eval[/color] predicate))
    ([color=BLUE]while[/color]
      ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'ERRNO 0) ([color=BLUE]setq[/color] selection ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] message)))
        ([color=BLUE]cond[/color]
          ( ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'ERRNO))
            ([color=BLUE]princ[/color] [color=MAROON]"\n--> Missed, Try Again."[/color])
          ( ([color=BLUE]and[/color] ([color=BLUE]eq[/color] 'ENAME ([color=BLUE]type[/color] selection)) ([color=BLUE]not[/color] (predicate selection)))
            ([color=BLUE]princ[/color] [color=MAROON]"\n--> Invalid Object Selected."[/color])
    selection
  ([color=BLUE]if[/color] ([color=BLUE]or[/color] *object-reactor-block1 *object-reactor-block2)
      ([color=BLUE]foreach[/color] reactor '(*object-reactor-block1 *object-reactor-block2)
        ([color=BLUE]if[/color] ([color=BLUE]boundp[/color] reactor) ([color=BLUE]vlr-remove[/color] ([color=BLUE]eval[/color] reactor)))
        ([color=BLUE]set[/color] reactor [color=BLUE]nil[/color])
      ([color=BLUE]princ[/color] [color=MAROON]"\n--> Reactors Disabled."[/color])
        ([color=BLUE]setq[/color] block1 (_select [color=MAROON]"\nSelect Block 1: "[/color] '([color=BLUE]lambda[/color] ( x ) ([color=BLUE]eq[/color] [color=MAROON]"INSERT"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] x)))))))
        ([color=BLUE]setq[/color] block2 (_select [color=MAROON]"\nSelect Block 2: "[/color] '([color=BLUE]lambda[/color] ( x ) ([color=BLUE]eq[/color] [color=MAROON]"INSERT"[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 0 ([color=BLUE]entget[/color] x)))))))
      ([color=BLUE]setq[/color] block1 ([color=BLUE]vlax-ename->vla-object[/color] block1)
            block2 ([color=BLUE]vlax-ename->vla-object[/color] block2)
            *object-reactor-block1 ([color=BLUE]vlr-object-reactor[/color] ([color=BLUE]list[/color] block1) block2 '(([color=BLUE]:vlr-modified[/color] . update-block)))
            *object-reactor-block2 ([color=BLUE]vlr-object-reactor[/color] ([color=BLUE]list[/color] block2) block1 '(([color=BLUE]:vlr-modified[/color] . update-block)))
  ([color=BLUE]princ[/color])
([color=BLUE]defun[/color] update-block ( block1 reactor params [color=BLUE]/[/color] block2 ) ([color=BLUE]setq[/color] block2 ([color=BLUE]vlr-data[/color] reactor))
      ([color=BLUE]vlax-read-enabled-p[/color]  block1)
      ([color=BLUE]vlax-write-enabled-p[/color] block2)
      ([color=BLUE]not[/color] ([color=BLUE]or[/color] ([color=BLUE]vlax-erased-p[/color] block1) ([color=BLUE]vlax-erased-p[/color] block2)))
    ([color=BLUE]foreach[/color] property '(insertionpoint rotation xscalefactor yscalefactor zscalefactor)
      ([color=BLUE]vlax-put-property[/color] block2 property ([color=BLUE]vlax-get-property[/color] block1 property))
Now this is a nice code!
Too bad it don't work for me: it puts one block on the other when moving one. The insertionpoints are layed upon each other and also the rotation of both blocks are matched.
If I knew a program to create those animated gifs I'd show you!
