Author Topic: Group Project: Change item(s) to Layer [Discussion]  (Read 27399 times)
Chris
Re: Group Project: Change item(s) to Layer [Discussion]
« Reply #30 on: April 20, 2011, 01:29:28 PM »
I would tend to think the second option would be better, as there is no point in cycling through the layers if the command is just going to get canceled out.  My question would be, instead of just exiting if there is no selection set, should you first give the user the option to select a selection, and if it is still nil, exit out.  Or is that too many extra prompts and not streamlined enough?
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
« Reply #31 on: April 20, 2011, 01:30:13 PM »
The layer table needs to be iterated before '7WIP:GetLayerSelection' is called, as this function requires a list of Layer names to display in the dialog. It could be iterated after a valid selection is made I suppose, although I thought the code would look cleaner/more readable with the construction of the list of layers outside of the COND statement.
As for :
(null 7WIP:GetLayerSelection)     <---- what is this?
This is the test condition for the second COND statement, i.e. if (null 7WIP:GetLayerSelection) returns T, princ *Cancel*.
Lee
« Reply #32 on: April 20, 2011, 01:32:23 PM »
Note that the user is prompted for a selection, then this selection is tested - this would allow both an implied selection and, if no implied selection is present, will prompt the user.
Chris
« Reply #33 on: April 20, 2011, 01:36:12 PM »
Ok, makes sense.  I'm having some issues with how I'm seeing posts in the thread, I think its just a setting on my end.
Win 10
« Reply #34 on: April 20, 2011, 01:41:56 PM »
Ah, gotcha.
Okay, I moved the layer iterating below object selection and this looks good to me if you guys agree too?
;;--------------------={ Project7 }=--------------------;;
;;       Change Item(s) to Layer  -  PSEUDO CODE        ;;
+----->  Prompt for Selection of Objects (ssget), use "_:L" mode string
|        to exclude objects on locked layers.
+----->  Cycle through Layer Table (tblnext) and construct a
|        list of layer names, excluding XRef layers
|        (not (wcmatch "*|*")) and layers that are off, frozen,
|        and locked.
+--+-->  Start COND
|  +--+  Condition 1: (null SelectionSet)
|  |  +-->  Princ *Cancel* as User hasn't selected anything
|  +--+  Condition 2: Call 7WIP:GetLayerSelection with list of layer names
|  |  |               [sorted in Alphabetical order?]
|  |  |               (null 7WIP:GetLayerSelection)
|  |  +-->  Princ *Cancel* as User pressed Dialog Cancel button
|  +--+  Default Condition => Valid Selection & Selected Layer
|     +-->  Iterate through SelectionSet and call
|           7WIP:ChangeEntityLayer to change the layer of each
|           entity to the chosen layer.
+-->  Exit Cleanly
« Reply #35 on: April 20, 2011, 01:43:43 PM »
That would be no different to my original though, since the validity of the SelectionSet is tested after the Table is iterated.
EDIT: [After more thinking] I suppose it would be more efficient for those cases in which the user hits Esc at the Selection prompt - Agree.
« Last Edit: April 20, 2011, 01:47:30 PM by Lee Mac »
Chris
« Reply #36 on: April 20, 2011, 02:05:42 PM »
sounds good to me.
Win 10
« Reply #37 on: April 20, 2011, 02:12:23 PM »
great. Pseudo code is done.
Again, this group thing is fun (slow, but fun).
alanjt
  • Standby for witty remark...
« Reply #38 on: April 20, 2011, 03:18:01 PM »
Wouldn't it make more sense to:
  • Check validity of selection as it's executed (eg. if or cond)
  • create layer list and feed it to dialog selection
  • iterate through selection set and put objects on defined layer
(cond ((not (setq selectionset (ssget "_:L"))))
      ((not (setq targetlayer (7WIP:GetLayerSelection (7WIP:GetLayerList)))))
      (T step through selectionset and put entities on defined layer)
OR
(if (and (setq selectionset (ssget "_:L"))
  (progn step through selectionset and put entities on defined layer)
or am I missing something?
Dropbox
dgorsman
« Reply #39 on: April 20, 2011, 03:20:57 PM »
Is there agreement on the Psuedo code as previously posted?
Should I send my code snippet to dgorsman to be added to this SVN thing?
I would recomend that you try SVN yourself. But i dont know where dgorsman stands; i need to download SVN here so i can check out whats there (hang tight a little longer).
I'd prefer coders get used to using the SVN, if only for their own education.  Future projects may be much larger and require the diff-patch method rather than a simple check in/out.  I think the documention/assassins should be online as well so the documentation is automatically distributed.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Chris
« Reply #40 on: April 20, 2011, 03:29:59 PM »
I agree about being on line, if the help documents arnt all there, you wont be able to see images, hyperlinks wont work, etc..
little confused about the SVN thing, I think I understand the procedure file, but I'm getting a page error when I go to tortisesvn.tigris.org
Se7en, When you refer to the AutoCAD help not being structured well, are you referring to the later versions, or some of the earlier ones, or both?
« Last Edit: April 20, 2011, 03:34:42 PM by Chris »
Win 10
Chris
« Reply #41 on: April 20, 2011, 03:57:04 PM »
We could call the project: "Project7"
Sounds cool.
Well I like it but I may be a little biased. *lol*
Speaking of titles/names: Who can draw? Can we get a simple logo for the docs (or is that a bit too much)?
Perhaps?
Lee,
Can I get this png with white text/lighter text, for darker backgrounds?  that way we'll have one of each.
Thanks,
Win 10
alanjt
« Reply #42 on: April 20, 2011, 04:00:03 PM »
Sounds cool.
Perhaps?
Lee,
Can I get this png with white text, for darker backgrounds?  that way we'll have one of each.
Thanks,
I'd either set the 'Project' text to be a little more bold (washes out in some areas overlaying the "VII") and if it were me, I'd go as far to say that a "7" would look cooler. What if we follow take from hacker text and use Projec7? Although, most probably wouldn't get it.
Dropbox
Chris
« Reply #43 on: April 20, 2011, 04:22:35 PM »
the logo doesnt matter much to me.  Now that you mention it, it does look like it washes over the red text. I was just thinking if we use a dark background for our help file header area, a light colored logo would be nice, and if we have any white space areas that contain the logo, the dark logo would go there.
Win 10
« Reply #44 on: April 20, 2011, 04:22:55 PM »
Sounds cool.
Perhaps?
Lee,
Thanks,
Sure Chris:
