Author Topic: Hatching  (Read 2140 times)
rktect3j
Hatching
« on: January 26, 2005, 10:10:37 AM »
Why is it that sometimes autocad says that it cant show hatch because "hatch pattern is too dense or dash size too small".  I have to zoom in real close add some hidden lines that don't plot to break up the space and then hatch it in pieces.  Any solution to this?  I am using ar-conc at scale 1 over a foundation footprint of about 45'x50' with some nooks, not rectagular.
Hatching
« Reply #1 on: January 26, 2005, 10:40:39 AM »
There must be some threshold that ACAD considers the points within the hatch too close together.
I created a rectangle 45x50 feet offset another to the inside 24" and tried to hatch ar-conc
but had to use scale of 1.5 before it would hatch. I did not try below 1.5 except 1 will not work.
CADaver
Hatching
« Reply #2 on: January 26, 2005, 11:38:10 AM »
(setenv "MaxHatch" "100000")
maybe??
Artisan
Hatching
« Reply #3 on: January 26, 2005, 12:05:31 PM »
Quote from: CADaver
maybe??
CADaver,
I was always told not to set the MaxHatch number higher than 100000 due to the fact that it could alter the performance of the program, in a bad way. Is this true?
CADaver
Hatching
« Reply #4 on: January 26, 2005, 12:15:40 PM »
Quote from: Artisan
Quote from: CADaver
maybe??
CADaver,
Depends on your machine and how much time you have.  If it's set to a very large number on a slow machine, and you noodle up a selection, it could be a while before it gets back to you.  But if you have a fast machine, and you NEVER noodle up a selection, go for it.  Mine has been set as you see it here for quite some time and I've suffered no ill effects.
whdjr
Hatching
« Reply #5 on: January 26, 2005, 01:38:06 PM »
Is there anywhere all the environment variables are listed with their uses?
Hatching
« Reply #6 on: January 26, 2005, 02:00:18 PM »
http://theswamp.org/phpBB2/viewtopic.php?t=1191&highlight=environment+variable
http://theswamp.org/phpBB2/viewtopic.php?t=3613&highlight=environment+variable
I also have a pdf file from Autodesk. *removed*
*edit by MST*
removed link to local file.
LINK to source document.
whdjr
Hatching
« Reply #7 on: January 26, 2005, 02:05:52 PM »
Thanks CAB, but I didn't see much there on Environment variables.  I'm not talking about sysvars.  How about that PDF, what does it have?
Ah! Did you add that link or did I just miss it?
Hatching
« Reply #8 on: January 26, 2005, 02:44:16 PM »
Well I added the link as it took me a minuite to upload it after the fact. :D
whdjr
Hatching
« Reply #9 on: January 26, 2005, 02:54:00 PM »
Thanks, the PDF is what I wanted.
MikePerry
Hatching
« Reply #10 on: January 27, 2005, 04:54:03 PM »
Hi
Personally I think it would be better to link directly to the Authors web site (purely for ethical reasons) -
Direct link to HyperPics web site - AutoCAD Environment Variables PDF
Have a good one, Mike
