Author Topic: can anyone please help me with this code?  (Read 5632 times)
andrew_nao
« on: April 13, 2011, 04:28:08 PM »
I found this code on the web, for searching an excel file and the code pops up a window with the results
however instead of the window i would like to have the results appear in excel cells on the same sheet as the find function, for copy and pasting purposes.
i dont know VB code so if anyone can help me out i would appreciate it
attach is in the excel file for reference on what it does
thanks
« Last Edit: April 13, 2011, 04:34:29 PM by andrew_nao »
linhoreka
Re: can anyone please help me with this code?
« Reply #1 on: April 13, 2011, 10:48:19 PM »
Will this work ? http://www.mediafire.com/?2xylkvfy167wtdf
(I cannot attach the new file "Find.xls", so I upload it to my MediaFire account)
« Last Edit: April 13, 2011, 10:55:19 PM by linhoreka »
andrew_nao
« Reply #2 on: April 14, 2011, 10:00:32 AM »
thanks for you help, however can you make it have the search function on sheet1 and keep the data to be search on sheet 2
and also have the actual info in the cell displayed instead of row/cell combo?
I appreciate your help
Matt__W
  • I like my water diluted.
« Reply #3 on: April 14, 2011, 10:40:05 AM »
I have a custom time sheet that has a search function.  It will search all tabs and then displays the results in a dialog box.  As you click on the search results, it brings you to the cell on whatever sheet the searched text was found on.  From there you could simply copy the text, the click back to the dialog box and go to another result.
Autodesk Expert Elite
andrew_nao
« Reply #4 on: April 14, 2011, 01:19:20 PM »
are you able to share it? maybe i can modify it to suit my needs?
linhoreka
« Reply #5 on: April 14, 2011, 01:40:19 PM »
Why don't you use Find (Ctrl+F) instead ?
Can you show me what do want to do next with those data on found cells ? I'll format the data to suit your needs.
Matt__W
« Reply #6 on: April 14, 2011, 02:46:29 PM »
Have a look-see at this.
andrew_nao
« Reply #7 on: April 14, 2011, 03:53:14 PM »
its a long winded explaination on why ctrl+f isnt used, that would be the easy option out, i agree but lets just say you cant teach an old dog new tricks...
anyway if you can have the info in the cells from sheet2 appear in the results of the popup when using it on sheet1 instead of the row and column number when found and for it to search sheet 2 exclusively and not be selectable i think would do the trick.
thanks again for your help
andrew_nao
« Reply #8 on: April 14, 2011, 03:54:03 PM »
im using office 2000 any chance to save down?
im unable to open this.
thanks
Matt__W
« Reply #9 on: April 14, 2011, 03:56:49 PM »
Saved down version.
linhoreka
« Reply #10 on: April 14, 2011, 10:09:38 PM »
Here it is, just a few thing to do to put the cell's value to the popup http://www.mediafire.com/?bcvbsondy3y5s01
andrew_nao
« Reply #11 on: April 15, 2011, 01:31:08 PM »
thanks all ill let you all know how it works after i play with it
