Author Topic: Block Attributes  (Read 7598 times)
krampaul82
Block Attributes
« on: April 13, 2011, 10:52:55 AM »
To whom it may concern,
I have a drawing full of blocks (which are the same but displayed on different layouts) with attributes.  If I want to change the attribute data by going into the block editor, making and saving the change. Question, is there a way to update this attribute data change without deleting and re-inserting the block? any help appreciated :-P
Rob...
Re: Block Attributes
« Reply #1 on: April 13, 2011, 10:54:24 AM »
ATTSYNC
CAD Tech
krampaul82
« Reply #2 on: April 13, 2011, 11:09:11 AM »
Thank you for the quick reply,
I changed attributes with the right click option edit attribute. Question is there any way to get this to update to the default values as well?
krampaul82
« Reply #3 on: April 13, 2011, 11:12:16 AM »
BTW
ACAD2009 32 bit Vanilla
Rob...
« Reply #4 on: April 13, 2011, 11:12:26 AM »
I don't think so. You would have to edit the default value in addition to the input value.
CAD Tech
krampaul82
« Reply #5 on: April 13, 2011, 11:40:52 AM »
Ouch! oh well, it was worth a shot. Thank you again for the quick reply.
Rob...
« Reply #6 on: April 13, 2011, 11:43:25 AM »
Your welcome.
It might be possible with a lisp routine but I'm not familiar with lisp.
CAD Tech
krampaul82
« Reply #7 on: April 13, 2011, 11:48:49 AM »
ATTSYNC
Just tested this and it does not work it still wants me to reinsert the block to update the values in the properties thank you any ways :-o
Rob...
« Reply #8 on: April 13, 2011, 12:23:07 PM »
If you were going into the block editor as stated in your first post, then it would work.
CAD Tech
Matt__W
  • I like my water diluted.
« Reply #9 on: April 13, 2011, 12:48:36 PM »
BATTMAN
Autodesk Expert Elite
Rob...
« Reply #10 on: April 13, 2011, 12:59:26 PM »
Good one Matt. How could I forget about BATTMAN?
CAD Tech
Dommy2Hotty
« Reply #11 on: April 18, 2011, 11:17:33 AM »
I'll bite...How did you forget about BATTMAN
By the way...I'm BaTTman...
