Author Topic: Get Document from Database  (Read 4644 times)
Fred Tomke
  • [ Mr. Bad Guy ]
« on: April 11, 2011, 06:44:04 PM »
Hello,
I can get the database from the document using
Document oDoc = Application.DocumentManager.MdiActiveDocument;
Database oDb = oDoc.Database
I can get the database from a database resistent entity using
Entity oEnt;
Database oDb = oEnt.Database;
But how can I get the document where the entity was created in?
In VisualLisp there was a (vla-get-document oLine);
Thanks and regards,
Fred
Fred Tomke
Dipl.-Ing. (FH) Landespflege
[ landscaper - landscape developer - digital landscape and urban design]
Jeff_M
  • C3D user & customizer
Re: Get Document from Database
« Reply #1 on: April 11, 2011, 10:18:11 PM »
Look into this:
Document oDoc = Application.DocumentManager.GetDocument(oDb);
« Reply #2 on: April 11, 2011, 11:14:30 PM »
Hello Fred,
As Jeff Indicated ;
// CodeHimBelonga kdub@theSwamp 20110412
// http://www.theswamp.org/index.php?topic=37860.msg428862#msg428862
using System;
using System.IO;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using AcUtils = Autodesk.AutoCAD.Internal.Utils;
[assembly: CommandClass(typeof(KdubTesting.WhoIsYouDaddy))]
namespace KdubTesting
    public class WhoIsYouDaddy
        [CommandMethod("DADDY_1")]
        public void WhoIsYouDaddy_1()
            Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            PromptEntityResult peResult = ed.GetEntity("\nSelect an entity: ");
            if( peResult.Status != PromptStatus.OK )
                return;
            Document daddyDoc = WhoIsYourDaddyO(peResult.ObjectId);
            if( daddyDoc != null ) {
                ed.WriteMessage(daddyDoc.Name.ToString());
        /// <summary>
        /// Determine the Document ( Owner ) of objID
        /// </summary>
        /// <param name="objID"> ObjectId </param>
        /// <returns>Document </returns>
        private static Document WhoIsYourDaddyO(ObjectId objID)
            Document oDoc = Application.DocumentManager.GetDocument(objID.Database);
            return oDoc;
Fred Tomke
  • [ Mr. Bad Guy ]
« Reply #3 on: April 12, 2011, 12:34:19 AM »
Hi guys,
I was sure that there is a method for this.
Thank you!
Fred
Fred Tomke
