Author Topic: Attribute rename  (Read 2860 times)
V-Man
  • I exist therefore I am! Finally Retired!
Attribute rename
« on: April 07, 2011, 03:18:23 PM »
I have a problem and I would like a lil help. I have a block with some attributes. This block is inserted over a thousand times in the CAD drawing and data filled in the attributes. I have since renamed some of the attributes and I want to re-define all blocks in the drawing but keep the existing data for each block. How can I accomplish this globally?
Block Name = Space
Old Block   Attributes   New Block Attributes
BLDGID         BLDG#
FLRID         FLR#
CUSTOM         SPACENAME
Any help is appreciated.
AutoCAD 9 - 2023, AutoCADMap 2008 - 2010, Revit 2012 - 2022, Autocad Civil 3D 2023
Matt__W
  • I like my water diluted.
Re: Attribute rename
« Reply #1 on: April 07, 2011, 03:22:22 PM »
Na-na-na-na-na-na-na-na-na-na  BATTMAN!!
Autodesk Expert Elite
V-Man
« Reply #2 on: April 07, 2011, 03:27:05 PM »
Ah, simple solution and it works.
alanjt
  • Standby for witty remark...
« Reply #3 on: April 07, 2011, 03:32:14 PM »
Dropbox
dgorsman
« Reply #4 on: April 07, 2011, 03:33:48 PM »
I tell users to send up the Bat-signal, just to see the look on their faces.   :-D
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
« Reply #5 on: April 07, 2011, 03:48:52 PM »
Didn't he (the first Bat man) commit suicide?
alanjt
« Reply #6 on: April 07, 2011, 03:52:21 PM »
There was one before Adam West?
Probably had to do with Autodesk using his character name as a command.
Dropbox
pBe
« Reply #7 on: April 08, 2011, 08:44:47 AM »
Holy Attributes BATTMAN! - Robin
barc
« Reply #8 on: April 08, 2011, 03:10:04 PM »
Superman Christopher Reeve commited suicide (maybe maybe not depending on who you ask) dunno 'bout no Batman.
pBe
« Reply #9 on: April 09, 2011, 03:32:18 AM »
What?!? before Adam West (which is still very much alive) there was  Lewis Wilson and Robert Lowrey, where does Christopher reeve fit in on all this  :-)
maybe they meant George Reeves (which incidentally is indeeed Superman)
barc
« Reply #10 on: April 09, 2011, 10:17:45 AM »
Got my Reeve and my Reeves cross-wired, Superman George Reeves commited suicide (depending on who you believe)
« Reply #11 on: April 09, 2011, 10:47:21 AM »
How did he do it?
Eat some Kryptonite.
