Author Topic: Standard Line Types  (Read 7742 times)
M-dub
Standard Line Types
« on: April 05, 2011, 01:05:56 PM »
Does anyone know of a standard linetpe to show CAT-5? cables?  All I've found is something like ----ENET-----ENET-----ENET and I don't want that.
Matt__W
  • I like my water diluted.
Re: Standard Line Types
« Reply #1 on: April 05, 2011, 01:13:41 PM »
Lemme talk to Bicsi-Boy down the hall.... BRB!
Autodesk Expert Elite
Matt__W
« Reply #2 on: April 05, 2011, 01:18:24 PM »
Well, besides that fact that CAT-5 is a thing of the past, there is no standard linetype for it that he's aware of.  The closest he's seen is a continuous line with "CAT 5E" text thrown in.
Matt__W
« Reply #3 on: April 05, 2011, 01:22:10 PM »
This may be of some help in the future if you need to do a lot of voice & data drafting.
https://www.bicsi.org/standards_faq_t.aspx?id=3362
M-dub
« Reply #4 on: April 05, 2011, 01:58:06 PM »
That's what I meant with the question mark.  Wasn't it obvious enough for you?  ;)
I'm actually after a linetype to show ethernet.  I guess I'll just pick one of the existing linetypes and adopt it as our standard.
Thanks Matt!
cmwade77
« Reply #5 on: August 26, 2011, 07:47:15 PM »
Please note that I would strongly advise at least Cat6
Jeff H
« Reply #6 on: August 26, 2011, 08:06:54 PM »
This is not too bad but is the CORP standard linetypes file.
Has a txt explaining some basics-----where to put the files, Must have certain textstyle for some to work etc.........
Has 2 .lin files one for 1/8" & 1/32" text height standard
