Author Topic: Derived Exception Question  (Read 1786 times)
Jeff H
« on: April 01, 2011, 08:46:01 PM »
Can anyone think of a reason why this solution might need a class like this?
using System;
using System.Linq;
using System.Text;
namespace BlockTesting2011
    public class DocumentIsNullException : ApplicationException
        private string _fileName;
        public string fileName
            get { return _fileName; }
        public DocumentIsNullException(string message, Exception inner, string filename) : base(message, inner)
            _fileName = filename;
        public DocumentIsNullException(string message, Exception inner) : base(message, inner)
Re: Derived Exception Question
« Reply #1 on: April 01, 2011, 09:45:43 PM »
Sorry Jeff, I inadvertently split the Topic  :oops:
Jeff of course meant this Solution
http://www.theswamp.org/index.php?topic=37686.msg427172#msg427172
