That one is better, even though I have to use midpoint or endpoint snaps to dimension the thing, or measure it. It -looks- a lot better in Autocad as well, as I only see the edge lines of the 'body' but... I really second Plankton.
Solids is really the only way I would want to see parts in Autocad. I could work with what you have, PROBABLY, if I had to. It depends on who you are delivering it to, and how you want it to look for them. If it's someone in your own company, I'd say go solids. If it's someone you need to impress or do your best for, I'd go solids. If it's someone who just needs to be able to do their job and are too defiant to download a model viewer for your software so they can measure the native file... I'm usually less inclined to accommodate them for sake of their convenience.
