Author Topic: Get ID of clipped Viewport  (Read 6603 times)
Nibster
« on: March 28, 2011, 03:23:47 PM »
I'm having trouble here finding what I need in lisp (i think i found it in vba or vlisp, but i'm not entirely sure), and if i search any more on my own I fear i'll upset the 'ignorance is bliss' mentality.
It's a simple layer setup routine for a simple drafter who does some funny and not so simple things, like use clipped viewports that are perfectly rectangular.  :?
Anyway, is there a way to modify this code so it doesn't bomb out when it is forced to pick a clipped viewport?
;; start of FPM-DH function
(defun c:FPM-DH (/ ss Vpid)
(setvar "cmdecho" 0)
(command "_.pspace")
(setq ss (car (entsel "\nselect viewport: ")))
(setq Vpid (cdr (assoc 69 (entget ss))))
(command "_.mspace")
(setvar "cvport" Vpid)
(command "vplayer" "f" "*|M*,*LS|*,*|P*" "" "t" "*|E*" "" "")
(command "_.regenall")
(command "_.zoom" "E")
(alert "Door Holders tab \nsetup is complete!")
;; end of FPM-DH function
or, if there's another way to transparently go around the issue (like unclip the vport using lisp) that would be fine by me too!
Nibster
Re: Get ID of clipped Viewport
« Reply #1 on: March 28, 2011, 03:36:50 PM »
seem to have found my answer HERE.  i think.... now to see how to blend that in as neatly as possible...
« Reply #2 on: March 28, 2011, 03:40:16 PM »
Use a filtered selection set. Here's the command line entry showing what happens when I select in the same place:
Command: (entget (car (entsel)))
Select object: ((-1 . <Entity name: -1f00d0>) (0 . "LWPOLYLINE") (5 . "10996")
(102 . "{ACAD_REACTORS") (330 . <Entity name: -1d1c70>) (102 . "}") (330 .
<Entity name: -1d92c0>) (100 . "AcDbEntity") (67 . 1) (410 . "Layout1") (8 .
"C-TOPO-TEXT") (100 . "AcDbPolyline") (90 . 5) (70 . 129) (43 . 0.0) (38 . 0.0)
(39 . 0.0) (10 12.9127 11.024) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10
13.2893 7.59882) (40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 21.0855 8.05049)
(40 . 0.0) (41 . 0.0) (42 . 0.0) (91 . 0) (10 20.8971 11.4756) (40 . 0.0) (41 .
0.0) (42 . 0.0) (91 . 0) (10 15.0971 14.2985) (40 . 0.0) (41 . 0.0) (42 . 0.0)
(91 . 0) (210 0.0 0.0 1.0))
Command: (setq ss (ssget ":S" '((0 . "Viewport"))))
Select objects:
<Selection set: 9c2>
Command: (setq ent (entget (ssname ss 0)))
((-1 . <Entity name: -1d1c70>) (0 . "VIEWPORT") (330 . <Entity name: -1d92c0>)
(5 . "886A") (100 . "AcDbEntity") (67 . 1) (410 . "Layout1") (8 . "VP") (100 .
"AcDbViewport") (10 16.9991 10.9487 0.0) (40 . 8.17273) (41 . 6.69973) (68 . 2)
(69 . 2) (12 -2424.01 -544.43 0.0) (13 0.0 0.0 0.0) (14 0.5 0.5 0.0) (15 0.5
0.5 0.0) (16 0.0 0.0 1997.26) (17 1.78181e+006 290121.0 0.0) (42 . 50.0) (43 .
0.0) (44 . 0.0) (45 . 267.989) (50 . 0.0) (51 . 0.0) (72 . 10000) (90 . 901120)
(340 . <Entity name: -1f00d0>) (281 . 0) (71 . 1) (74 . 0) (110 0.0 0.0 0.0)
(111 1.0 0.0 0.0) (112 0.0 1.0 0.0) (79 . 0) (146 . 0.0) (170 . 0) (61 . 5)
(348 . <Entity name: -1f5560>) (292 . 1) (282 . 1) (141 . 0.0) (142 . 0.0) (63
. 250) (421 . 3355443))
« Reply #3 on: March 28, 2011, 03:41:16 PM »
Heh, or the way shown in that other thread :-)
« Reply #4 on: March 28, 2011, 03:52:10 PM »
Select object: ((-1 . <Entity name: -1f00d0>) (0 . "LWPOLYLINE") ... )
Select objects:
((-1 . <Entity name: -1d1c70>) (0 . "VIEWPORT") ... )
Ooo! Didn't know you could do that - Thanks Jeff - that'll certainly save a lot of legwork in the future.
Nibster
« Reply #5 on: March 28, 2011, 04:09:31 PM »
Select objects:
yeah... that's WAY over my head.
I replaced lines 3,4,&5 in my original post with CAB's input found in the link in my second post.  I am still new at this game, but at least I could follow along better that way too.
Thanks guys!
« Reply #6 on: March 28, 2011, 05:02:50 PM »
Don't worry, its not as scary as it looks  :-)
This was Jeff's intention:
(defun c:FPM-DH ( / cm ss vpid )
  (setq cm (getvar 'CMDECHO))
  (setvar 'CMDECHO 0)
  (if (setq ss (ssget "_+.:S:E" '((0 . "VIEWPORT"))))
      (setq vpid (cdr (assoc 69 (entget (ssname ss 0)))))
      (setvar 'CVPORT vpid)
      (command "_.vplayer" "_f" "*|M*,*LS|*,*|P*" "" "t" "*|E*" "" "")
      (command "_.regenall" "_.pspace" "_.zoom" "E")
  (setvar 'CMDECHO cm)
Also, since you are changing system variables (I know, its only CMDECHO), consider adding an error handler.
Lee
Nibster
« Reply #7 on: March 29, 2011, 09:28:36 AM »
oh yeah, i keep forgetting about 'resets'.  I see in the link that you provided that i also need to look at the osnaps, which can sometimes be a pain.
would you also be so kind and explain line 4 in the code you provided?  I want very much to understand how you got done in 1 line what needed more than 4 in previous searches.
Thanks!!
« Last Edit: March 29, 2011, 09:31:56 AM by Nibster »
Nibster
« Reply #8 on: March 29, 2011, 10:08:08 AM »
yeah, how did you do this Lee?  I just discovered that I don't have to pick the viewport frame, I can pick inside frame and the dang thing and it works!  (I was testing if your version had a "nothing selected, try again" feature)
OR not need to be in pspace?!?  wow....
:not_worthy:
« Last Edit: March 29, 2011, 10:19:33 AM by Nibster »
Nibster
« Reply #9 on: March 29, 2011, 10:38:15 AM »
anyway, this is what I've settled on.  since there's more than one vport in the file and they each need their own layer settings, I made Lee's contribution a subroutine (i think that's what it's called, please correct my terminology as required) and this is the format i created:
;start of VPORT selection function
(defun c:vpselect (/ ss vpid)
) ;end progn
  )  ;end if
)  ;end defun
;end of VPORT selection function
;; start of FPM-SD function
(defun c:FPM-SD (/ cm)
(c:vpselect)
(command "vplayer" "f" "*|E*,*|M*,*LS|*,*|P*,*|A-FLOR-RMNA" "" "t" "*|E*FIRE*SMDT*SURV*" "" "")
(alert "Smoke Detector tab \nsetup is complete!")
;; end of FPM-SD function
Thanks again to all who chimed in
« Reply #10 on: March 29, 2011, 10:49:24 AM »
Just keep in mind that before changing System Variables, store their original values and reset them afterwards; and, if there is a point at which the user could press Esc (like at a selection prompt) or there is some code that could error, include an error handler (*error* function) to reset the System Variables should either of these scenarios arise.
This was utilising the idea that Jeff demonstrated in his earlier post: that Viewports and Clipped Viewports may be selected using a filtered ssget call.
The '+.' forces point mode only (similar to setting PICKAUTO = 0), the ':S' forces a single selection, the ':E' selects everything in the pickbox aperture. So with these options enabled we are effectively replicating the behaviour of entsel.
Nibster
« Reply #11 on: March 29, 2011, 12:01:45 PM »
Thanks for the explanation Lee.
I'm still confused on how it seems to work properly when nothing is picked and the vport is active.
edit: ok, it doesn't work when you don't pick the viewport frame.  I need to add something in there to loop until an object is selected.... hmmm.
« Last Edit: March 29, 2011, 12:24:28 PM by Nibster »
« Reply #12 on: March 29, 2011, 02:27:48 PM »
Perhaps change it to something along these lines:
(defun vpselect ( / ss vpid )
  (while (not (setq ss (ssget "_+.:S:E" '((0 . "VIEWPORT")))))
    (princ "\n** Please Select a Viewport **")
(defun c:FPM-SD ( / cm )
  (setvar 'CMDECHO 0)
  (vpselect)
  (command "_.vplayer" "_f" "*|E*,*|M*,*LS|*,*|P*,*|A-FLOR-RMNA" "" "_t" "*|E*FIRE*SMDT*SURV*" "" "")
  (command "_.regenall" "_.pspace" "_.zoom" "_E")
Nibster
« Reply #13 on: March 29, 2011, 02:31:44 PM »
~sigh~
i hope i can get it to click soon where i look at this stuff and I can just see how all the pieces fall together.
Thanks a ton (imperial) Lee.  That's quite a bit cleaner than what I was attempting!
« Reply #14 on: March 29, 2011, 02:38:09 PM »
~sigh~
Don't worry, one day you'll look back on this thread and be amazed at how far you will have progressed :-)
You're welcome :-)
I'm not overly keen on my solution however, since, should the user wish to exit the selection prompt, he/she must hit Esc, else be trapped in the while loop 'til the heat death of the universe...
