Author Topic: curiosity question, what does the number mean ?  (Read 4221 times)
Hangman
« on: March 28, 2011, 12:49:53 PM »
So I am running this code:
(setq path "\"c:\\Program Files\\somewhere not that important\\VBScript File.vbs\"")
(startapp "wscript.exe" path)
The file runs, and I get this little number below on the command line, "33".
Command: (startapp "wscript.exe" path)
33
What does this "33" number mean ?
Hangman  8)
alanjt
  • Standby for witty remark...
Re: curiosity question, what does the number mean ?
« Reply #1 on: March 28, 2011, 01:10:02 PM »
Half of 66.
Dropbox
« Reply #2 on: March 28, 2011, 01:10:16 PM »
I have never looked into it further than what the docs say.
startapp
<snip>
Return Values
An integer greater than 0, if successful, otherwise nil.
Examples
The following code starts the Windows Notepad and opens the acad.lsp file.
Command: (startapp "notepad" "acad.lsp")
33
alanjt
« Reply #3 on: March 28, 2011, 01:13:19 PM »
startapp
Starts a Windows application
(startapp appcmd[file])
Arguments
appcmd
A string that specifies the application to execute. If appcmd does not include a full path name, startapp searches the directories in the PATH environment variable for the application.
file
A string that specifies the file name to be opened.
Return Values
An integer greater than 0, if successful; otherwise nil.
Dropbox
Hangman
« Reply #4 on: March 28, 2011, 01:42:50 PM »
Half of 66.
:-D
How 'bout a Third of 99, or perhaps 15x2.2, or it could be the square root of 5x(y-12)(z+3).
 :wink:
startapp
Return Values
So it isn't 33 milliseconds to complete, or 33 characters in the string before it comes across a space, ...
it's just plain ol'  "... greater than 0, if successful; ..."?
:shrug:   Ok.
Thanks guys.
Hangman  8)
alanjt
« Reply #5 on: March 28, 2011, 01:45:18 PM »
Half of 66.
:-D
 :wink:
Now you're just being silly.  8-)
Dropbox
jbuzbee
« Reply #6 on: March 28, 2011, 02:06:31 PM »
From the secret docs that are not distributed to the public:
Return Values
33: application is scanning for a communications device.  Refer to values 60 to 72 for more information.
69: application is contacting Microsoft of illegal use of product.
Sounds like you've done something wrong - sorry dude.
James Buzbee
Windows 8
« Reply #7 on: March 28, 2011, 03:33:41 PM »
Standard Enum value to signal a successful execution of the application?  /guess
dgorsman
« Reply #8 on: March 28, 2011, 06:01:29 PM »
Internally, likely either an enumerated constant or integer equivalent of a bit-coded value.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
JCTER
« Reply #9 on: March 28, 2011, 06:18:24 PM »
It's a sign that they are unaware the answer is 42.
« Reply #10 on: March 28, 2011, 06:19:00 PM »
