Author Topic: Trying to insert block in current UCS  (Read 16637 times)
Jeff H
Re: Trying to insert block in current UCS
« Reply #45 on: December 20, 2011, 07:01:01 PM »
The exact same behavior happens if you do it through the UI.
Maybe call
Database.ReloadXrefs
kaefer
« Reply #46 on: December 20, 2011, 07:07:23 PM »
Maybe call
Database.ReloadXrefs Method
Description
This function reloads the xrefs whose BlockTableRecord ObjectIds are in xrefIds
Database.ResolveXrefs Method
Description
This function resolves existing xrefs in the working database.
TJK44
« Reply #47 on: December 21, 2011, 10:14:15 AM »
Thank you kaefer and Jeff! I modified my code to use Database.ResolveXrefs and it reloaded the new ones. Here is the new code.
<CommandMethod("ImportPart")> _
Public Sub ImportPart()
                Dim fname As String = "R:\TEST\X-REF MASTER FILES\000022-01-01 TEST\000022-01-01 test drawing.dwg"
                Dim doc As Document = Application.DocumentManager.MdiActiveDocument
                Dim db As Database = doc.Database
                Dim ed As Editor = doc.Editor
                'Dim fname As String = "C:\Users\Jeff\Documents\Drawing1.dwg"
                Dim ObjId As ObjectId
                Using trx As Transaction = db.TransactionManager.StartTransaction
                    Using docLoc As DocumentLock = doc.LockDocument
                        Dim bt As BlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
                        Dim btrMs As BlockTableRecord = bt(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite)
                        Using dbInsert As New Database(False, True)
                            dbInsert.ReadDwgFile(fname, IO.FileShare.Read, False, "")
                            ObjId = db.Insert(Path.GetFileNameWithoutExtension(fname), dbInsert, True)
                        End Using
                        Dim ppo As New PromptPointOptions(vbCrLf & "Insertion Point")
                        Dim ppr As PromptPointResult
                        ppr = ed.GetPoint(ppo)
                        If ppr.Status <> PromptStatus.OK Then
                            ed.WriteMessage(vbCrLf & "You decided to QUIT!")
                            Exit Sub
                        End If
                        Dim insertPt As Point3d = ppr.Value
                        Dim bref As New BlockReference(insertPt, ObjId)
                        btrMs.AppendEntity(bref)
                        trx.AddNewlyCreatedDBObject(bref, True)
                        trx.Commit()
                        bref.ExplodeToOwnerSpace()
                        db.ResolveXrefs(False, False)
                    End Using
                End Using
            End If
        Catch ex As Exception
        End Try
    End Sub
