Author Topic: Access to a UserControl  (Read 2843 times)
hellios8502
« on: March 24, 2011, 04:43:29 PM »
Hi
I have a bit of a dum question, but it's been a great headache for the last couple of days  :-o
I implemented a Palette with a DataGridView on it but I can't access the Grid control through a CommandMethod.
For example:
Private Sub Add5000RowsToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Add5000RowsToolStripMenuItem.Click
        dgv.Rows.Clear()
        dgv.Columns.Clear()
        dgv.RowCount = 5000
        dgv.ColumnCount = 100
    End Sub
This adds a couple  :roll:  of rows in the grid control via a ToolStripMenu, but when I write something like:
  <CommandMethod("ccc")> _
    Public Sub cl()
do something whit the datagridview
End Sub
follows:
Error   6   Cannot refer to an instance member of a class from within a shared method or shared member initializer without an explicit instance of the class.
Any help would be greatly appreciated.
Thanks in advance.
mohnston
  • CAD Programmer
Re: Access to a UserControl
« Reply #1 on: March 24, 2011, 05:09:22 PM »
Not a VB.NET guy but is your CommandMethod in the same class as your form?
If it is, it shouldn't be.
If it is not, then there is no datagridview to do stuff with.
CAD Programming Solutions
hellios8502
« Reply #2 on: March 24, 2011, 05:18:51 PM »
Yes it is in the same class and I have other subs using CommandMethod that work just fine.
The problem is that I can't access the grid control.
For example when I try msgbox(me.DayaGridView1.rowscount) the msgbox displays nothing .
Why you think I shouldn't be using CommandMethod grom within the UserControl class?
jgr
« Reply #3 on: March 24, 2011, 05:59:38 PM »
Shared..., variables at module level...?
Please, post the full code.
hellios8502
« Reply #4 on: March 24, 2011, 06:29:00 PM »
There is not a lot of code for posting  :oops: i have just made a palette on a user control with a datagridview on it.
Public MyDataGridView As Autodesk.AutoCAD.Windows.PaletteSet = _
   New PaletteSet("DataGridView", New Guid("676900AF-16FC-43b2-931E-715DD8F96460"))
  <CommandMethod("AddDataGridView")> _
Public Sub AddDataGridView()
        Dim TextDIS As New Palette_GridControl
        Dim cont As Boolean
        cont = False
        For i As Integer = 0 To MyDataGridView.Count - 1
            If MyDataGridView(i).Name = "DataGridView" Then
                MyDataGridView.Visible = True
                cont = True
            End If
        Next
        If cont = False Then
            MyDataGridView.Add("DataGridView", TextDIS)
        End If
    End Sub
This part starts the palette, I am using more than one palette and they are defined in a separate class.
Public Class Palette_GridControl
        dgv.Rows.Clear()
        dgv.Columns.Clear()
        dgv.RowCount = 5000
    End Sub
    Public Sub cl()
        MsgBox(dgv.RowCount)----Here is the problem :?  (dgv=DaraGridView :-) such a long name)
    End Sub
End Class
This code is in the usercontroll class
edit:kdub - code tags added
« Last Edit: March 24, 2011, 06:37:37 PM by Kerry »
Jeff H
« Reply #5 on: March 24, 2011, 06:39:02 PM »
How and where is dgv declared?
jgr
« Reply #6 on: March 24, 2011, 07:01:39 PM »
hellios8502, Do you not undertand this???: Please post full (vs .net) project
other subs...?
It seems you do not understand., read firt's 3 lines.
Sorry i do not speak English and did not explain better
Note:
The first paragraph is to hellios8502, but appears otherwise
« Last Edit: March 24, 2011, 07:10:33 PM by jgr »
hellios8502
« Reply #7 on: March 25, 2011, 07:59:11 AM »
Public Class Class_Palettes
    Public FileName As String
    <CommandMethod("hellios")> _
   Public Sub Palette()
        If myPaletteSet.Count = 0 Then
            Dim textTools As Palette_TextTools = New Palette_TextTools
            Dim polyllineTools As Palette_PolylineTools = New Palette_PolylineTools
            Dim layoutools As Palette_Layout_Tools = New Palette_Layout_Tools
            myPaletteSet.Add("Text Tools", textTools)
            myPaletteSet.Add("Polyline Tools", polyllineTools)
            myPaletteSet.Add("Layout Tools", layoutools)
        Else : myPaletteSet.Visible = True
        End If
    End Sub
        End If
    End Sub
    <CommandMethod("RemoveDataGridView")> _
  Public Sub RemoveDataGridView()
        MyDataGridView(0).PaletteSet.Visible = False
    End Sub
End Class
        dgv.Rows.Clear()
        dgv.Columns.Clear()
        dgv.RowCount = 5000
    End Sub
    Public Sub cl()
    End Sub
End Class
With a button in the main palette set I am calling the datagridview palette on which
there is a grid control defined directly (dragged from the toolbox) :-)
hellios8502
« Reply #8 on: March 26, 2011, 12:36:39 PM »
I knew it was a dum question bu I asked it :-).
I solved my problem by declaring the elements I needed access to in a Module instead in the class.
Thanks again for the help
« Reply #9 on: March 29, 2011, 04:13:36 AM »
You could have also just added a property or two to the class
