Author Topic: Don't know why this lisp doesn't work  (Read 3481 times)
Brick_top
« on: March 23, 2011, 06:23:19 AM »
Hi there I found a routine but don't know why it doesn't work.
I took it from here http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/delaunay-triangulation/m-p/871300
Here is the error I get "; error: Automation Error. Problem in loading application"
the debugger points to this section ->
(vla-getinterfaceObject
(vlax-get-acad-object)
"AcadX.Application"
(if (not *acadx*)
(setq *acadx*
"AcadX.Application"
(defun VarIsArray (var)
(and
(eq (type var) 'variant)
(eq vlax-vbArray
(logand
(vlax-variant-type var)
vlax-vbArray
(not (zerop (VarArrayLen var)))
(defun VarArrayLen (var / array)
(setq array (vlax-variant-value var))
(- (vlax-safearray-get-u-bound array 1)
(vlax-safearray-get-l-bound array 1)
-1
(defun List->Coordinates (plist)
(vlax-make-variant
(vlax-safearray-fill
(vlax-make-safearray
vlax-vbDouble
(cons 0 (1- (* (length (car plist))
(length plist))))
(apply 'append plist)
(defun Coordinates->List (array dims / vlist rslt)
(if (eq (type array) 'variant)
(setq array (vlax-variant-value array))
(setq vlist (vlax-safearray->list array))
(if (eq dims 2)
(while vlist
(setq rslt
(cons
(list
(car vlist)
(cadr vlist)
rslt
vlist (cddr vlist)
(while vlist
(setq rslt
(cons
(list
(car vlist)
(cadr vlist)
(caddr vlist)
rslt
vlist (cdddr vlist)
(reverse rslt)
;; Generates a triangular mesh from selected AutoCAD POINT
;; entities. All points must lie in the XY plane.
(defun Celaunay2D ( / x ss points i p triangles)
(setq x *acadx*)
(setq ss (ssget '((0 . "POINT"))))
(if (zerop (sslength ss))
(exit)
(repeat (setq i (sslength ss))
(setq p (cdr (assoc 10
(entget
(ssname ss (setq i (1- i)))))))
(setq points
(cons
(list (car p) (cadr p))
points
(setq triangles
(coordinates->list
(vlax-invoke-method x
'Triangulate2d
(list->coordinates points)
3
(foreach triangle triangles
(gr-triangle triangle)
(defun gr-triangle (triangle / verts)
(setq verts
(mapcar
'(lambda (i)
(nth i points)
triangle
(grdraw (car verts) (cadr verts) 1)
(grdraw (cadr verts) (caddr verts) 1)
(grdraw (caddr verts) (car verts) 1)
;;;;;;;;;;;;;;;;;;; DELAUNAY2D.LSP ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
Don't know how to fix it.
thanks
Re: Don't know why this lisp doesn't work
« Reply #1 on: March 23, 2011, 06:53:57 AM »
*Tony Tanzillo
Re: Copy of Tony Tanzillo's ACADX activex extension library
 2007-12-01 07:05 AM in reply to:gmyroup
 >> I am looking for a copy of Tony Tanzillo's ACADX activex extension.
AcadX is a copyrighted work that you cannot purchase
 a copy of. If you did manage to get your hands on a
 copy, and you distribute it, you will be facing a lawsuit.
Besides that, it's retired and does not work in any
release after 2006, and never will.
If you need something it offers, hire a programmer.
added :
http://forums.autodesk.com/t5/Visual-Basic-Customization/Copy-of-Tony-Tanzillo-s-ACADX-activex-extension-library/m-p/2125922/thread-id/85910
http://www.caddzone.com/acadx/
« Last Edit: March 23, 2011, 07:03:15 AM by Kerry »
Brick_top
« Reply #2 on: March 23, 2011, 07:26:19 AM »
oh  :cry:
Thanks a lot for that info though
« Reply #3 on: March 23, 2011, 07:36:15 AM »
TT = Ledge
Brick_top
« Reply #4 on: March 23, 2011, 07:53:43 AM »
Ledge = Slang for Legend or Legendary
« Reply #5 on: March 23, 2011, 08:08:13 AM »
Indeed
