Author Topic: PAGESETUP to TXT  (Read 1833 times)
Andrea
PAGESETUP to TXT
« on: January 21, 2005, 09:26:15 PM »
Is it possible to save a pagesetup to a txt file ?
Keep smile...
PAGESETUP to TXT
« Reply #1 on: January 24, 2005, 10:15:30 AM »
Set your the pagesetup you want to use as current.
Command: -plot
Detailed plot configuration? [Yes/No] <No>: y
run through all the prompts
hit  F2 and copy paste the contents
Ron
Andrea
PAGESETUP to TXT
« Reply #2 on: January 24, 2005, 11:26:51 AM »
Quote from: ronjonp
Command: -plot
Ron
Ronjon, I know all that...;-)
I just need a program to export pagesetup.
any body know ??
Keep smile...
CADaver
PAGESETUP to TXT
« Reply #3 on: January 24, 2005, 11:30:47 AM »
You don't need to export one, PSETUPIN will import one from any file.
Andrea
PAGESETUP to TXT
« Reply #4 on: January 24, 2005, 11:57:17 AM »
Quote from: CADaver
Hey why not using this command...!?
Hmmm....not a bad idea.
thanks.
Keep smile...
