Author Topic: Layer Creator : Old lisp don't work  (Read 6728 times)
Atwist
« on: March 21, 2011, 11:15:12 AM »
I would like to use the following lisp from Tim Spangler but I get an error message.
Can anyone see what is going on.
Error ***Program Error: Bad Argument Type: consp nil  ****cancel*
« Last Edit: January 05, 2012, 10:24:21 PM by CAB »
Re: Old lisp don't work
« Reply #1 on: March 21, 2011, 11:18:08 AM »
Perhaps you can identify the source of the error by following this tutorial:
http://lee-mac.com/debugvlide.html
Atwist
« Reply #2 on: March 21, 2011, 11:37:07 AM »
Thanks Lee
But my knowledge of lisp and DCL is very small. :cry:
« Reply #3 on: March 21, 2011, 11:48:43 AM »
Now's your chance to expand it  :-)
Atwist
« Reply #4 on: March 21, 2011, 12:11:48 PM »
Lee
I've tried it through your lesson, but what I get is an error sound and only that.
And Acad is down.
TimSpangler
  • CAD Naked!!
« Reply #5 on: March 21, 2011, 12:45:01 PM »
Try this one...
ACA 2015 - Windows 7 Pro
Atwist
« Reply #6 on: March 21, 2011, 12:58:14 PM »
Hello Tim
Thanks for your update.
I've tried this but get an error
Atwist
« Reply #7 on: March 21, 2011, 01:23:26 PM »
My mistake :roll:
've Found the problem
The layer file folder was not in the autocad directory
Atwist
« Reply #8 on: March 21, 2011, 02:42:07 PM »
It works very well thanks again for sharing :laugh:
TimSpangler
  • CAD Naked!!
« Reply #9 on: March 21, 2011, 03:14:41 PM »
You're very welcome!
Sam
« Reply #10 on: March 22, 2011, 06:51:19 AM »
Try this one...
Dear Sir,
Error on lisp use autocad 2006
copy all autocad support folder
AIA Layer v3.lyr
AIA Layer v3 EXST.lyr
AIA Layer v3 NEWW.lyr
LAYER_CREATOR.dcl
LAYER_CREATOR.lsp
LAYER_CREATOR.slb
Command: lc ; error: Automation Error. No database
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
TimSpangler
  • CAD Naked!!
« Reply #11 on: March 22, 2011, 07:31:46 AM »
There should be a file named "Layer Files" in the same folder as the LayerCreator.lsp.  This file will/should contain all of the .lyr files.
Try that.
Try this one...
Dear Sir,
AIA Layer v3.lyr
LAYER_CREATOR.dcl
LAYER_CREATOR.lsp
LAYER_CREATOR.slb
Sam
« Reply #12 on: March 23, 2011, 12:40:33 AM »
Try that.
Try this one...
Dear Sir,
AIA Layer v3.lyr
LAYER_CREATOR.dcl
LAYER_CREATOR.lsp
LAYER_CREATOR.slb
Dear sir,
thx for reply
problem solved
one more request can u split dialog box
see attached file
