Author Topic: Draw perpendicular line both side from point on curve  (Read 3562 times)
kruuger
« on: March 17, 2011, 03:15:37 AM »
Hello Everyone,
Can some give me some tips how to draw two line like described in subject (please see also picture for clarification).
I guess my answer is here:
http://www.theswamp.org/index.php?topic=32789.0
But it is hard to extract what i want (to much information for me now  :-()
kruuger
Stefan
Re: Draw perpendicular line both side from point on curve
« Reply #1 on: March 17, 2011, 05:25:23 AM »
Some start point
  (setq dist1 (getreal)
dist2 (getreal))
  (setq enti           (entsel)
curve          (vlax-ename->vla-object (car enti))
point_on_curve (vlax-curve-getClosestPointTo curve (cadr enti))
param          (vlax-curve-getParamAtPoint curve point_on_curve)
tangential_dir (vlax-curve-getFirstDeriv curve param)
perp_angle1    (+ (angle '(0 0) tangential_dir) (* 0.5 pi))
perp_angle2    (+ perp_angle1 pi)
your_point_1   (polar point_on_curve perp_angle1 dist1)
your_point_2   (polar point_on_curve perp_angle2 dist2)
kruuger
« Reply #2 on: March 17, 2011, 05:51:40 AM »
Thank you VERY VERY MUCH phanaem . Good start for me with "curve"   :-)
(defun C:P2P (/ dist1 dist2 enti curve point_on_curve
                param tangential_dir perp_angle1 perp_angle2
                your_point_1 your_point_2)
  (setq dist1 (getreal "\nFirst distance: ")
        dist2 (getreal "\nSecond distance: ")
  (setq enti (entsel "\nSelect object: ")
  (foreach % (list your_point_1 your_point_2)
    (entmakex
      (list
        (cons 0 "LINE")
        (cons 10 point_on_curve)
        (cons 11 %)
hava a good day
kruuger
EDIT: awesome variable name. very helpfull
« Last Edit: March 17, 2011, 06:21:36 AM by kruuger »
« Reply #3 on: March 17, 2011, 06:17:10 AM »
phanaem,
excellent reply !!
Stefan
« Reply #4 on: March 17, 2011, 06:49:08 AM »
kruuger, I am glad it helps you.
Thank you Kerry.
ScottMC
« Reply #5 on: November 03, 2023, 10:31:16 PM »
Sorry this to be so old, it was a worthwhile learner though.
Just wanted to include re.usability of vars. Comments Please!
(defun c:p2p (/ *error*
              enti    curve     point_on_curve wdst wdlt
              perp_angle2    your_point_1   your_point_2
             ) ;; https://www.theswamp.org/index.php?topic=37522.msg425311#msg425311
  (defun *error* ( msg )
    (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
    (if qaf (setvar 'qaflags qaf))
    (if msg (prompt msg))
          (setvar 'osmode snw)
             (setvar 'cmdecho 1)
(setq snw (getvar 'osmode))
(setvar 'osmode (boole 6 (getvar 'osmode) 512)) ;; add nearest osnap to existing
;; first perp line
      (if dst1 ;; set default if first run [nil]
           (setq wdst 1.0)
  (setq dst1 (getdist (strcat "\n First/Inner Distance: < was: " (rtos wdst 2 3)" > "))) ;; get offset, else <enter> for 1.0
       (if dst1                   ;; test for new entry
          (setq wdst 1.0) ;; if not new entry, use 1
          (setq dst1 wdst) ;; else use last/saved
      (setq wdst dst1) ;; set next use prompt
 ;; second perp line
          (if dst2             ;; set default if first run [nil]
               (setq wdlt 1.0)
    (setq dst2 (getdist (strcat "\n Second/Outer Distance: < was: " (rtos wdlt 2 3)" > "))) ;; get offset, else <enter> for 1.0
              (if dst2                   ;; test for new entry
                (setq wdlt 1.0) ;; if not new entry, use 1
                 (setq dst2 wdlt) ;; else use last/saved
                (setq wdlt dst2) ;; set next use prompt
          (if (and          ;; both 0 quit
            (= dst1 0)
            (= dst2 0)
            (quit)
          (princ (strcat " 1st: " (rtos dst1 2 3) " | 2nd: " (rtos dst2 2 3)))
 (while
     (setq pt (getpoint "\n Select object: " )
              enti (nentselp pt) ;
            your_point_1   (polar point_on_curve perp_angle1 dst1)
            your_point_2   (polar point_on_curve perp_angle2 dst2)
      ) ;_ end of setq
    (entmakex
      (list
        (cons 0 "LINE")
        (cons 11 %)
      ) ;_ end of list
    ) ;_ end of entmakex
  ) ;_ end of foreach
 ) ;_ end of  while
 (setvar 'osmode snw) ;; restore osmode
 (*error* nil)
) ;_ end of defun
« Last Edit: November 03, 2023, 11:10:38 PM by ScottMC »
ScottMC
« Reply #6 on: November 05, 2023, 09:06:23 PM »
OOPs - correction on variables from 'was'
     Any suggestions greatly appreciated.
(defun c:p2p (/ *error* ;; https://www.theswamp.org/index.php?topic=37522.msg425311#msg425311
             ) ;;  wdst wdlt <'was' entries for next use
             (setvar 'cmdecho 1)
(setvar 'osmode (boole 6 (getvar 'osmode) 512)) ;; 'just add nea'
;; first perp line
      (if (= wdst nil) ;; set default if first run [nil]
           (setq wdst 1.0)
       (if (= dst1 nil)                   ;; test for new entry
            (setq dst1 wdst) ;; if not new entry, use previous
 ;; second perp line
          (if (= wdlt nil)             ;; set default if first run [nil]
               (setq wdlt 1.0)
              (if (= dst2 nil)                   ;; test for new entry
                (setq dst2 wdlt) ;; if not new entry, use previous
          (if (and          ;; both 0.0 ?  quit
            (= dst1 0)
            (= dst2 0)
            (quit)
          (princ (strcat " 1st: " (rtos dst1 2 3) " | 2nd: " (rtos dst2 2 3))) ;; show entries
 (while
      ) ;_ end of setq
    (entmakex
      (list
        (cons 0 "LINE")
        (cons 11 %)
      ) ;_ end of list
  ) ;_ end of foreach
 ) ;_ end of  while
 (*error* nil)
) ;_ end of defun
« Last Edit: November 07, 2023, 10:43:04 PM by ScottMC »
