Author Topic: Get all blocks in modelspace except XREF, how?  (Read 9925 times)
alanjt
  • Standby for witty remark...
Re: Get all blocks in modelspace except XREF, how?
« Reply #15 on: March 16, 2011, 08:40:46 AM »
To get block references w/out using ssget, you can use gc:GetReferences.
In the following example returns a list of all block references inserted in model space.
The list type is: ((blockName1 (refEname refEname ...)) (blockName2 (refEname refEname ...)))
((lambda (/ name refs blst)
   (while (setq bl (tblnext "block" (not bl)))
     (setq name (cdr (assoc 2 bl)))
     (if (setq refs (gc:GetReferences name 2))
       (setq blst (cons (list name refs) blst))
   blst
Nice work, Gile!
Dropbox
Andrea
« Reply #16 on: September 12, 2011, 11:18:17 AM »
well,...by searching one of my post...I see this post..
I know it is an old one..
but no one consider the AI_TABLE as an option.
so, just to add this idea.
(ai_table "BLOCK" 4)
Keep smile...
GDF
« Reply #17 on: September 12, 2011, 02:23:36 PM »
Be sure the routine ai_utils.lsp is loaded.
