I don't know what to say, I guess I was not holding my tounge the right way...
(LoadPageSetup) with out the S::Startup works now.
the load function is after the call, the only thing I did different was save and close the acaddoc.lsp before running vs. just saving it then seeing if it worked.
I am not happy about this because all weekend I banged my head trying to figure this out when I could have been enjoying the sunshine.
But since I am here
What reason would you use S::STARTUP for, if you advise against using it. Was it primarly for older versions of ACAD?
and
Is there a way to trick a reactor to use a command?
