Hi Lee
But surely just (LoadPageSetup) in the ACADDOC.lsp will perform as needed?
I thought so too, but (LoadPageSetup) did not work for me, it kept giving me a Unknown function or I if used (command "LoadPageSetup" with a C:LoadPageSetup in my function) unknown command. I have only ever used acaddoc.lsp to load function to run from the command prompt when I call it, I wanted this to run at start up of opening files. I was confused why I could get default ACAD commands to work but not my own Lisp functions. I freakin ran my brain in circles this weekend trying to figure it out. I came across an article that was used for ACAD R14 to put (S::Startup) and it worked. So I thought that maybe default commands and custom commands loaded and ran differently at start up.
Thanks for correcting my direction. I guess I need to figure out why (LoadPageSetup) does not work.
---Edit---
But even though my function said unknown function or command at startup
If I ran it from the command prompt it worked. Which lead me to believe there was something different about custom function running when files open.
Anway it is always somthing and if not something it will be something else.
