Author Topic: [Challenge] Point set inscribed the max area triangle  (Read 14689 times)
gile
  • Marseille, France
Re: [Challenge] Point set inscribed the max area triangle
« Reply #30 on: March 17, 2011, 02:45:44 PM »
While using a function which returns the triangle algebraic area (signed area) as Alanjt's AT:TriangleArea or algeb-area for the triangle area, the same routine can be used to evaluate if a point is inside the triangle:
(defun algeb-area (p1 p2 p3)
  (/ (- (* (- (car p2) (car p1)) (- (cadr p3) (cadr p1)))
(* (- (car p3) (car p1)) (- (cadr p2) (cadr p1)))
     2.0
(defun isInside (pt p1 p2 p3)
  ((lambda (a1 a2 a3)
     (or
       (and (<= 0.0 a1) (<= 0.0 a2) (<= 0.0 a3))
       (and (<= a1 0.0) (<= a2 0.0) (<= a3 0.0))
    (algeb-area pt p1 p2)
    (algeb-area pt p2 p3)
    (algeb-area pt p3 p1)
This will return T if the point is strictly inside or lies on the triangle.
Replacing '<=' with '<' will evaluate only strictly inside point.
« Reply #31 on: March 17, 2011, 04:04:41 PM »
Or perhaps another method:
(defun isInside ( pt p1 p2 p3 )
    (lambda ( a1 a2 a3 )
      (or
    (sin (- (angle p1 pt) (angle p1 p2)))
    (sin (- (angle p2 pt) (angle p2 p3)))
    (sin (- (angle p3 pt) (angle p3 p1)))
[ Used some of your code Gile ]
chlh_jd
« Reply #32 on: March 18, 2011, 04:23:50 AM »
hi Gile , Lee ,
to judge a point in or at triangle ofcause can use area method , but it take a lot cal , I think the intersetion method is fastest .
hi Evgeniy , in the routine it can be
(defun ss-pitp (p l)
    ;;check point inside triangle .
    ;;by GSLS(SS)
    (< ((lambda (a b c)
  (+ (length (inters p a b c nil))
     (length (inters p b a c nil))
     (length (inters p c a b nil))
(car l)
(cadr l)
(caddr l)
       9
however yours 'ins' is Excellent ! but the wholl routine is too slow if the points nums is more , e.g. 528 points in my often dwg .
chlh_jd
« Reply #33 on: March 18, 2011, 04:34:22 AM »
by the way , in this routine , the area cal is for Comparison , so it can be simplified like this
(defun ss-aat (p1 p2 p3)
  ;;area triangle
  ;;Uses conventional formula.
  (apply (function +)
      (mapcar (function (lambda (a b c)
  (expt (- (+
     (* (car a) (cadr b))
     (* (car b) (cadr c))
     (* (car c) (cadr a))
     (* (car a) (cadr c))
     (* (car b) (cadr a))
     (* (car c) (cadr b))
2.
      (list p1 (cdr p1) (list (caddr p1) (car p1)))
      (list p2 (cdr p2) (list (caddr p2) (car p2)))
      (list p3 (cdr p3) (list (caddr p3) (car p3)))
chlh_jd
« Reply #34 on: March 18, 2011, 05:45:59 AM »
is it possible to use Mesh method ?
chlh_jd
« Reply #35 on: March 18, 2011, 05:51:14 AM »
Perhaps , We can solve it from 2D first
gile
  • Marseille, France
« Reply #36 on: March 18, 2011, 06:21:18 AM »
hi Gile , Lee ,
    ;;by GSLS(SS)
    (< ((lambda (a b c)
(car l)
(cadr l)
(caddr l)
       9
It seems to me that the ss-pitp routine do not return right results, for example:
(ss-pitp '(2. 1. 0.) '((0. 0. 0.) (5. 0. 0.) (3. 2. 0.))) returns nil even (2. 1. 0.) is inside the triangle.
chlh_jd
« Reply #37 on: March 18, 2011, 07:30:28 AM »
hi Gile
that's right result , because it change into the cond that whether point out of triangle , if to judge in or at it , use this
    ;;by GSLS(SS)
    (= ;|if judge out of , ucs /= or < |; ((lambda (a b c)
(car l)
(cadr l)
(caddr l)
       9
chlh_jd
« Reply #38 on: March 18, 2011, 07:41:42 AM »
to sort point set by mesh , can use follow func , but not sure it's right
(defun sort-mesh
       (pts n / minpt maxpt dvx fsx dvy fsy i dm a b mid ptm end)
  ;;sort point set by mesh
  ;;by GSLS(SS)
  (setq minpt (apply
'mapcar
(cons 'min pts)
maxpt
     (apply
'mapcar
(cons 'max pts)
dvx   (/ (- (car maxpt) (car minpt)) n)
fsx   (car minpt)
dvy   (/ (- (cadr maxpt) (cadr minpt)) n)
fsy   (cadr minpt)
  (setq pts
(vl-sort pts
 (function
   (lambda (e1 e2)
     (< (car e1) (car e2))
  (setq i 1)
  (while pts
    (setq dm (+ fsx (* i dvx)))
    (setq a (car pts))
    (cond ((<= (- dm dvx) (car a) dm)
  (setq mid (cons a mid)
pts (cdr pts)
 ((<= dm (car a) (+ dm dvx))
  (setq ptn (cons mid ptn)
mid nil
mid (cons a mid)
pts (cdr pts)
i   (1+ i)
 (t
  (setq ptn (cons nil (cons mid ptn))
mid nil
i   (1+ i)
  (setq end nil)
  (foreach b ptn
    (if b
(setq b
 (vl-sort b
  (function
    (lambda (e1 e2)
      (< (cadr e1) (cadr e2))
     i  1
     mid nil
     ptm nil
(while b
 (setq dm (+ fsy (* i dvy)))
 (setq a (car b))
 (cond ((<= (- dm dvy) (cadr a) dm)
      b   (cdr b)
((<= dm (cadr a) (+ dm dvy))
(setq ptm (cons mid ptm)
      mid nil
      mid (cons a mid)
      b   (cdr b)
      i   (1+ i)
(t
(setq ptm (cons nil (cons mid ptm))
      mid nil
      i   (1+ i)
(setq end (cons (reverse ptm) end))
      (setq end (cons (repeat n (setq b (cons nil b))) end))
  end
;;test
(foreach a
  (sort-mesh
    (mapcar
      (function
(lambda (x) (cdr (assoc 10 (entget (cadr x)))))
      (cdr (reverse (ssnamex (ssget '((0 . "point"))))))
    20
  (princ a)
« Last Edit: March 18, 2011, 07:44:45 AM by chlh_jd »
gile
  • Marseille, France
« Reply #39 on: March 18, 2011, 07:57:38 AM »
hi Gile
    ;;by GSLS(SS)
(car l)
(cadr l)
(caddr l)
       9
Sorry, I can't understand what you mean.
Your new routine still return false result IMO.
The point (3. -2. 0.) is outside the triangle ((0. 0. 0.) (5. 0. 0.) (3. 2. 0.)) but
(ss-pitp '(3. -2. 0.) '((0. 0. 0.) (5. 0. 0.) (3. 2. 0.))) returns T
chlh_jd
« Reply #40 on: March 18, 2011, 08:03:38 AM »
hi Gile
    ;;by GSLS(SS)
(car l)
(cadr l)
(caddr l)
       9
hi gile , my test reulet return NIL
gile
  • Marseille, France
« Reply #41 on: March 18, 2011, 08:20:18 AM »
I do not know how you're making your tests, but :
(inters p a b c nil) returns (15.0 -10.0 0.0) => length = 3
(inters p b a c nil) returns (15.0 10.0 0.0) => lenght = 3
(inters p c a b nil) returns (3.0 0.0 0.0) => length = 3
Total lengthes = 9 => T
Try this little test command
(defun c:test (/ l p)
  (setq l '((0. 0. 0.) (5. 0. 0.) (3. 2. 0.)))
  (command "_.pline")
  (mapcar '(lambda (p) (command "_non" p)) l)
  (command "_close")
  (while (setq p (getpoint))
    (alert
      (if (ss-pitp p l)
"Inside"
"Outside"
chlh_jd
« Reply #42 on: March 18, 2011, 08:58:51 AM »
Nice gile !
thank you for often a nice test routine .
it really take a wrong result .
chlh_jd
« Reply #43 on: March 18, 2011, 09:04:47 AM »
by the cods , it'll return error result inside ,like the picture
    ((lambda (a b c)
  (not (or (inters p a b c) (inters p b a c) (inters p c a b)))
(car l)
(cadr l)
(caddr l)
chlh_jd
« Reply #44 on: March 18, 2011, 09:26:34 AM »
by the way , angle & inters are use in 2D plan , in 3Dplan it can't return corret reslut .
if in 3D , do it can use this func , I can't sure it because less of  'trans .
;;;with the same direction method
;;;by trans
(defun ss-pitp1 (p l)
  ;;by GSLS(SS)
  ((lambda (a b c)
     (and (<= (* (car (trans (mapcar '- p a) 0 (mapcar '- b a)))
       (car (trans (mapcar '- p a) 0 (mapcar '- c a)))
    0
(<= (* (car (trans (mapcar '- p b) 0 (mapcar '- a b)))
       (car (trans (mapcar '- p b) 0 (mapcar '- c b)))
    0
    (car l)
    (cadr l)
    (caddr l)
