Author Topic: [Challenge] Point set inscribed the max area triangle  (Read 14707 times)
chlh_jd
Re: [Challenge] Point set inscribed the max area triangle
« Reply #15 on: March 16, 2011, 07:19:59 AM »
hi , all
hi , Evgeniy
about pt in or at the triangle , I tested result is
函数:EE:PITP运行10000次测试结果00:00:00:108函数:SS-PITP运行10000次测试结果00:00:00:061函数:SS-PITP0运行10000次测试结果00:00:00:921函数:SS-PITP1运行10000次测试结果00:00:00:360
use cal number of intersections method is the fastest , is it a wrong test ?
(defun EE:pitp (p l)
  ;; check is a point inside the triangle.
  ;; by ElpanovEvgeniy
  (if (< (sin (- (angle (last l) p) (angle (last l) (car l))))
-1e-6
    (vl-every
      (function
(lambda (a b) (< (sin (- (angle a p) (angle a b))) -1e-6))
      l
      (cdr l)
    (vl-every
      (function
(lambda (a b) (> (sin (- (angle a p) (angle a b))) 1e-6))
      l
      (cdr l)
;;;number of intersection
;;;fastest
(defun ss-pitp (p l)
  ;;check point inside triangle .
  ;;by GSLS(SS)
  ((lambda (a b c)
     (eq (+ (length (inters p a b c nil))
   (length (inters p b a c nil))
   (length (inters p c a b nil))
9
    (car l)
    (cadr l)
    (caddr l)
;;;with the same direction method
(defun ss-pitp0 (p l / foo)
  ;;by GSLS(SS)
  (defun foo (a b c p / ac ab ap)
    (setq ac (mapcar '- c a)
  ab (mapcar '- b a)
  ap (mapcar '- p a)
    (>= (vxv (v^v ab ac) (v^v ab ap)) 0.0)
  ((lambda (a b c)
     (and (foo a b c p) (foo b c a p) (foo c a b p))
    (car l)
    (cadr l)
    (caddr l)
;;;by trans
(defun ss-pitp1 (p l)
  ;;by GSLS(SS)
  ((lambda (a b c)
     (and (<= (* (car (trans (mapcar '- p a) 0 (mapcar '- b a)))
       (car (trans (mapcar '- p a) 0 (mapcar '- c a)))
    0
(<= (* (car (trans (mapcar '- p b) 0 (mapcar '- a b)))
       (car (trans (mapcar '- p b) 0 (mapcar '- c b)))
    0
    (car l)
    (cadr l)
    (caddr l)
chlh_jd
« Reply #16 on: March 16, 2011, 07:22:21 AM »
forget func .
;;; gile
;;; vxv returns the dot product of 2 vectors
;;; dot product
(defun vxv (v1 v2)
  (apply
    (mapcar
      v1
      v2
;;; gile
;;; cross product
(defun v^v (v1 v2)
  (list (- (* (cadr v1) (caddr v2)) (* (caddr v1) (cadr v2)))
(- (* (caddr v1) (car v2)) (* (car v1) (caddr v2)))
(- (* (car v1) (cadr v2)) (* (cadr v1) (car v2)))
chlh_jd
« Reply #17 on: March 16, 2011, 08:38:48 AM »
to cal area of triangle ,
Uses conventional formula, but slower than Heron Formula.
is it no compile reason or the codes written to bad ?
(defun ss-aat (p1 p2 p3)
  ;;area triangle
  ;;Uses conventional formula, but slower than Heron Formula.
  (* 0.5
     (sqrt
       (apply (function +)
     (mapcar (function (lambda (a b c)
 (expt (- (+
    (* (car a) (cadr b))
    (* (car b) (cadr c))
    (* (car c) (cadr a))
    (* (car a) (cadr c))
    (* (car b) (cadr a))
    (* (car c) (cadr b))
2.
     (list p1 (cdr p1) (list (caddr p1) (car p1)))
     (list p2 (cdr p2) (list (caddr p2) (car p2)))
     (list p3 (cdr p3) (list (caddr p3) (car p3)))
Stefan
  • The most I miss IRL is the Undo button
« Reply #18 on: March 16, 2011, 08:47:19 AM »
Area of triangle
(defun ph:area (p1 p2 p3)
  (* 0.5
     (abs (+
    (* (cadr p1) (- (car p2) (car p3)))
    (* (cadr p2) (- (car p3) (car p1)))
    (* (cadr p3) (- (car p1) (car p2)))
alanjt
  • Standby for witty remark...
« Reply #19 on: March 16, 2011, 08:53:02 AM »
Area of triangle
  (* 0.5
     (abs (+
http://www.theswamp.org/index.php?topic=37455.msg424735#msg424735
Dropbox
« Reply #20 on: March 16, 2011, 09:17:14 AM »
Another...
(defun LM:TriangleArea ( p1 p2 p3 )
  (* 0.5 (distance p1 p2) (distance p2 p3) (abs (sin (- (angle p2 p1) (angle p2 p3)))))
chlh_jd
« Reply #21 on: March 16, 2011, 09:21:57 AM »
hi All, to cal area of 3d points triangle, please test with it
(ss-aat '(1 2 0) '(4 4 3) '(5 6 0))
(ss-aat '(1 2 0) '(2 4 3) '(3 6 0))
« Last Edit: March 16, 2011, 09:25:39 AM by chlh_jd »
« Reply #22 on: March 16, 2011, 09:23:18 AM »
Oh yes - I would note that mine was for 2D purposes....
For 3D:
  ( (lambda ( n ) (* 0.5 (sqrt (apply '+ (mapcar '* n n)))))
    (v^v (mapcar '- p2 p1) (mapcar '- p3 p1))
(defun v^v ( u v )
  (list
    (- (* (cadr u) (caddr v)) (* (cadr v) (caddr u)))
    (- (* (car  v) (caddr u)) (* (car  u) (caddr v)))
    (- (* (car  u) (cadr  v)) (* (car  v) (cadr  u)))
« Last Edit: March 16, 2011, 09:28:44 AM by Lee Mac »
alanjt
« Reply #23 on: March 16, 2011, 09:25:29 AM »
Ditto.
Dropbox
chlh_jd
« Reply #24 on: March 16, 2011, 09:45:25 AM »
Point to judge whether in atriangle and the area of ​​the triangle  has a reasonable calculation function ,
And, ElpanovEvgeniy often the corret routine , however the overall complexity of the algorithm is O(n^3),
is it possible to let down ?
chlh_jd
« Reply #25 on: March 16, 2011, 10:06:04 AM »
hi , Lee ,
that's my test result
_$
函数:AREA_GERON运行10000次测试结果00:00:00:171函数:LM:TRIANGLEAREA运行10000次测试结果00:00:00:281函数:SS-AAT运行10000次测试结果00:00:00:297
"00:00:00:297"
_$
« Reply #26 on: March 16, 2011, 10:13:41 AM »
A quick test:
_$ (setq p1 '(1. 2. 0.) p2 '(4. 4. 3.) p3 '(5. 6. 0.))
(5.0 6.0 0.0)
_$ (ss-aat p1 p2 p3)
8.7178
_$ (LM:TriangleArea p1 p2 p3)
8.7178
_$ (area_geron p1 p2 p3)
8.7178
_$ (Benchmark '((ss-aat p1 p2 p3) (LM:TriangleArea p1 p2 p3) (area_geron p1 p2 p3)))
Benchmarking ..................Elapsed milliseconds / relative speed for 32768 iteration(s):
    (AREA_GERON P1 P2 P3)..........1701 / 1.25 <fastest>
    (LM:TRIANGLEAREA P1 P2 P3).....1857 / 1.14
    (SS-AAT P1 P2 P3)..............2122 / 1.00 <slowest>
chlh_jd
« Reply #27 on: March 16, 2011, 10:21:54 AM »
here's a new test dwg for total routine
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: March 17, 2011, 06:05:52 AM »
new version
(defun c:t1 (/ A1 A2 L LST S)
 (defun ins (p a b c)  (or (inters p a b c) (inters p b a c) (inters p c a b)))
 (defun area_geron (a b c / l p)
  (setq l (cons 0 (mapcar (function distance) (list a b c) (list b c a)))
        p (/ (apply (function +) l) 2.)
  ) ;_  setq
  (sqrt (abs (apply (function *) (mapcar (function -) l (list p p p p)))))
 ) ;_  defun
 (if (setq a1 0
           s  (ssget "_x" '((0 . "point")))
     ) ;_  setq
  (foreach a (setq lst (mapcar (function (lambda (a) (cdr (assoc 10 (entget (cadr a))))))
                               (ssnamex s)
                       ) ;_  mapcar
             ) ;_  setq
   (foreach b lst
    (foreach c lst
     (if (and (> (setq a2 (area_geron a b c)) a1)
              (vl-every (function (lambda (p) (ins p a b c))) lst)
         ) ;_  and
      (setq a1 a2
            l  (list a b c)
      ) ;_  setq
     ) ;_  if
    ) ;_  foreach
   ) ;_  foreach
  ) ;_  foreach
 ) ;_  if
 (entmakex
  (append
   '((0 . "LWPOLYLINE") (100 . "AcDbEntity") (100 . "AcDbPolyline") (90 . 3) (70 . 1))
   (mapcar (function (lambda (a) (cons 10 a))) l)
  ) ;_  append
 ) ;_  entmakex
« Last Edit: March 17, 2011, 07:22:08 AM by ElpanovEvgeniy »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #29 on: March 17, 2011, 06:53:03 AM »
hi , all
hi , Evgeniy
;;;fastest
  ;;by GSLS(SS)
  ((lambda (a b c)
9
    (car l)
    (cadr l)
    (caddr l)
In your program ss-pitp error
